Discuss
Kenmore 90 dryer keeps blowing fuse
 in
Dryer Repair
Kenmore 90 series dryer runs but does not heat up. So, I took it apart and and found a lot
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 90 dryer keeps blowing fuse
  #1 (permalink)
Old 11-09-2012, 11:47 AM
Junior Member
Walker717 is on a distinguished road
Default Kenmore 90 dryer keeps blowing fuse
Model Number: 110.60902990   Brand: Kenmore   Age: 5 - 10 years
Kenmore 90 series dryer runs but does not heat up. So, I took it apart and and found a lot of lint clogging the machine. Cleaned it out completely and replaced the Hi limit fuse. It ran for 2 weeks (10-loads) and the fuse blew. Thought my mistake was not replacing the Hi limit thermostat, so I replaced both on the second go. The fuse blew on one load. In taking it apart again noticed that there was a gap on the O-ring foam gasket (because I put the assembly together incorrectly) So, this time I checked the cycling thermostat on the stove burner (a 4 on a 10 scale) The cycling thermostat opened with a click and the multimeter showed no continuity. Replaced the fuse and the Hi Limit Thermostat and put the assembly together correctly. Fuse blew on one load. I also checked while the dryer ran and the flow coming out of the vent was good. I also ran the dryer with the bottom panel off and watched the coils turn red as they should. I also checked the felt gaskets which were good and the drum screws which needed to be tightened.
I am at a loss as to what to try next. Any ideas would be welcome. The wife is going to want to buy another dryer when she hears today's news.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 11-09-2012, 05:23 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Which fuse are you talking about?
The thermal cut off kit Part number: 279769
Part number: 279769
Or the thermal fuse Part number: 3390719
Check if the heating element not damaged or touching the housing.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 11-10-2012, 07:00 AM
Junior Member
Default
I tested the heating element and it looks good -- no breaks or damage and no spots on the sides of the housing, no burn marks. It does not appear to be grounded in any way. It tests at 10.2 ohms. It tests open from each terminal to ground.
Perhaps it is the cycling thermostat? Part # 3387134. There are 2 pair of wires going into this device. The large pair tests at .4 ohms (on 200 ohm setting); and the small pair tests at 6.97 ohms (on the 20K setting).
Thanks in advance.
Walker717
  #4 (permalink)
Old 11-10-2012, 07:53 AM
Junior Member
Default
Sorry, my prior post did not go through.
The fuse that blows is the thermal cut off kit Part number: 279769
The other fuse tests as good.
Walker717
  #5 (permalink)
Old 11-10-2012, 09:27 AM
Junior Member
Default
One more question on the cycling thermostat part number 3387134. The replacement part has a 250 degree cutoff. The one I took out of the machine is labeled L 155 - 25F -- so it cuts off at 155 degrees. Wouldn't that make a difference? Shouldn't I get a part with the same 155 cutoff? I read somewhere that the exhaust from a dryer is between 140 - 150 degrees, no where near 250.
Walker717
  #6 (permalink)
Old 11-11-2012, 03:37 PM
Expert
Default
Hi.
Did you remove and clean the air duct asm.?
Part number: 3387911
Did you clean the filter housing?
The thermostat 3387134 is marked L155-25F, check the picture Part number: 3387134
Try to use the dryer with the vent hose disconnected from the dryer and see if that makes any difference.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer keeps blowing thermo Fuse DMY Dryer Repair 1 06-13-2012 01:58 AM
Kenmore dryer keeps blowing thermal fuse spoko Dryer Repair 0 02-23-2012 10:59 AM
Dryer overheat blowing thermal fuse heater box, not vent fuse try2repairguy Dryer Repair 2 11-10-2011 08:27 AM
kenmore thermal fuse keeps blowing kbay1977 Dishwasher Repair 2 02-10-2010 09:51 PM
Doesn't start - dryer keeps blowing fuse novas Dryer Repair 0 11-08-2007 01:57 PM
