Discuss
Kitchenaid dryer doesn't heat
 in
Dryer Repair
Very perplexed about this one. Dryer will not heat on any setting but blower runs. I have 220V at terminal
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kitchenaid dryer doesn't heat
  #1 (permalink)
Old 11-08-2012, 12:31 PM
Junior Member
Snakebone is on a distinguished road
Default Kitchenaid dryer doesn't heat
Model Number: KEYE660WWH1   Brand: Kitchen Aid   Age: More than 10 years
Very perplexed about this one. Dryer will not heat on any setting but blower runs. I have 220V at terminal block (110 on each feed to center and 220 from outside feeds). All thermostats and thermal fuse have continuity as well as hi-limit switch. I replaced the heating element even though the old one had 11ohms as does the new one. The element is not shorted to ground.
Here's the strange part: If I run the machine with the element leads connected to the element, I get 110V on each element lead when tested to ground, but 0V between the leads. Continuity is good at 11ohms. If I disconnect the leads and check voltage between them with the machine running, I get 220V.
Again, I get no voltage across these leads when hooked up to the element, but 220V when disconnected. I must be missing something here. Can anyone add clarity here??
I checked all thermostat continuity with a wire disconnected.
Also, when the timer is in Timed mode,, I don't get the 220V at the disconnected element leads, so I'm guessing that that side of the timer is bad, but in the Auto modes I get the 220V at the leads.
Ads By Google
Related Models
Whirlpool KEYE660WWH1
Whirlpool KEYE664WAL0
Whirlpool KEYE664WAL1
Whirlpool KEYE664WHT0
Whirlpool KEYE664WPL0
Whirlpool KEYE664WTO0
Whirlpool KEYE664WWH0
Whirlpool KEYE664WWH1
Whirlpool KEYE665BAL0
Whirlpool KEYE665BAL1
Whirlpool KEYE665BAL2
Whirlpool KEYE665BWH0
Whirlpool KEYE665BWH1
Whirlpool KEYE665BWH2
Whirlpool KEYE665BWH3
Whirlpool KEYE670BAL0
Whirlpool KEYE670BAL1
Whirlpool KEYE670BAL2
Whirlpool KEYE670BAL3
Whirlpool KEYE670BWH0
Whirlpool KEYE670BWH1
Whirlpool KEYE670BWH2
Whirlpool KEYE670BWH3
Whirlpool KEYE677BWH0
Whirlpool KEYE677BWH1
Whirlpool KEYE677BWH2
Whirlpool KEYE677BWH3
Whirlpool KEYE678BAL0
Whirlpool KEYE678BAL1
Whirlpool KEYE679BBL0
Whirlpool KEYE679BBL1
Whirlpool KEYE700TAL0
Whirlpool KEYE700THT0
Whirlpool KEYE700TPL0
Whirlpool KEYE700TTO0
Whirlpool KEYE700TWH0
Whirlpool KEYE750VAL0
Whirlpool KEYE750VHT0
Whirlpool KEYE750VPL0
Whirlpool KEYE750VTO0
Whirlpool KEYE750VWH0
Whirlpool KEYE760WAL0
Whirlpool KEYE760WAL1
Whirlpool KEYE760WHT0
Whirlpool KEYE760WPL0
Whirlpool KEYE760WTO0
Whirlpool KEYE760WWH0
Whirlpool KEYE760WWH1
Whirlpool KEYE767WWH0
Whirlpool KEYE770BAL0
Whirlpool KEYE770BAL1
Whirlpool KEYE770BAL2
Whirlpool KEYE770BWH0
Whirlpool KEYE770BWH1
Whirlpool KEYE770BWH2
Whirlpool KEYE777BWH0
Whirlpool KEYE777BWH1
Whirlpool KEYE777BWH2
Whirlpool KEYE778BAL0
Whirlpool KEYE778BAL1
Whirlpool KEYE778BAL2
Whirlpool KEYE800SWH1
Whirlpool KEYE800TAL0
Whirlpool KEYE800THT0
Whirlpool KEYE800TPL0
Whirlpool KEYE800TTO0
Whirlpool KEYE800TWH0
Whirlpool KEYE850VAL0
Whirlpool KEYE850VHT0
Whirlpool KEYE850VPL0
Whirlpool KEYE850VTO0
Whirlpool KEYE850VWH0
Whirlpool KEYE860WAL0
Whirlpool KEYE860WAL1
Whirlpool KEYE860WHT0
Whirlpool KEYE860WPL0
Whirlpool KEYE860WTO0
Whirlpool KEYE860WWH0
Whirlpool KEYE860WWH1
Whirlpool KEYE870BAL0
Whirlpool KEYE870BAL1
Whirlpool KEYE870BWH0
Whirlpool KEYE870BWH1
Whirlpool KEYE900SWH1
Whirlpool KEYE900TAL0
Whirlpool KEYE900THT0
Whirlpool KEYE900TPL0
Whirlpool KEYE900TTO0
Whirlpool KEYE900TWH0
Whirlpool KEYE950VAL0
Whirlpool KEYE950VHT0
Whirlpool KEYE950VPL0
Whirlpool KEYE950VTO0
Whirlpool KEYE950VWH0
Whirlpool KEYE960WAL0
Whirlpool KEYE960WWH0
Whirlpool KEYL400WAL0
Whirlpool KEYL400WWH0
Whirlpool KEYL405WAL0
Whirlpool KEYL405WWH0
Whirlpool KEYL410BAL0
Whirlpool KEYL410BAL1
Whirlpool KEYL410BAL2
Whirlpool KEYL410BWH0
Whirlpool KEYL410BWH1
Whirlpool KEYL410BWH2
Whirlpool KEYL507WWH0
Whirlpool KEYL510BAL0
Whirlpool KEYL510BAL1
Whirlpool KEYL510BAL2
Whirlpool KEYL510BWH0
Whirlpool KEYL510BWH1
Whirlpool KEYL510BWH2
Whirlpool KEYL517BWH0
Whirlpool KEYL517BWH1
Whirlpool KEYL517BWH2
Whirlpool KEYS677EQ0
Whirlpool KEYS677EQ1
Whirlpool KEYS677EQ2
Whirlpool KEYS677EZ0
  #2 (permalink)
Old 11-08-2012, 02:18 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool KEYE660WWH1 Dryer - AppliancePartsPros.com
See the attachment for your tech sheet
This is not that strange.
I do not know how much electrical you know so will try to explain it.
The house voltage is actually two 120 volt supplies that are 180 degrees out of phase. So when one (L1) is at positive 120, the other (L2) is at negative 120, this gives you the 240 volts (L1 to L2). Note that neutral/ground is not part of the 240 circuit.
When you use Neutral as one side of your meter you see 120 volts on both sides of the element but since the element is good (has continuity), this is probably the same side of the line. In other words the element is not connected to ground so no current flows therefore you see the same voltage at both sides.
I hope I did not confuse the livin out of you above because this is going to be a bit more complicated.
I think when you measure using Neutral/ground as a reference you are seeing the L2 voltage.
When in timed dry the timer motor is not connected into the heater circuit.
When in auto modes it is through the resistor.
So the L1 side of the line conducts through the timer motor and the resistor so you see 240 volts. But the resistance of the motor resistor combo is so high it limits the current to a low level (0.05 amp approx.) So you do not get any heat, also you do not see any voltage across the element when connected (0.05 amps times 11 ohms would give a voltage of 0.55 volts.
All the 240 is dropped across the timer/resistor.
All the above was just FYI and i am not sure I did a very good job of it.
In any case I agree with you, it is probably the timer since you have checked the Thermal Cutoff, the Operating Thermostat, the Hi-limit Thermostat and the heater.
To confirm this put the unit mid cycle of a heating mode, unplug the unit and one wire from Timer switch 2.
Measure across Timer Switch 2, it should be 0 ohms.
If not is is blown and the timer needs replacing.
__________________
  #3 (permalink)
Old 11-08-2012, 03:28 PM
Junior Member
Default
Denman,
Thanks so much for the reply. Your answer was clear as mud. Just kidding. Actually it was very clear to me and all make sense. Its like a phantom voltage but no measurable amps. I thought it might be that but my VOM can only measure up to 10amps unswitched so I was afraid I might cook it.
I'm still a little unclear on the specific test for the bad timer contact. Are you saying to disconnect the wire from switch 2 (Labeled "R" on my timer) and test continuity from the blade to the wire with the timer in a "Timed" run setting?
  #4 (permalink)
Old 11-08-2012, 06:27 PM
Senior Expert
APP Volunteer
Default
Yes the blade where R was attached to BK.
The reason you do this is to ensure that you are only reading the Timer Switch 2 contacts and not a alternate/parallel circuit path.
__________________
  #5 (permalink)
Old 11-21-2012, 04:45 AM
Junior Member
Default
You guys are great!! Tested the continuity as suggested and found no continuity so timer was bad. Replaced with new and now it works like new. Thanks again for taking the time to look over this forum. It's a terrific asset to us DIYers and saves us a ton of money. Thanks again!
  #6 (permalink)
Old 11-21-2012, 07:16 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KitchenAid Oven Will not heat JPratt Oven Repair (including Ranges and Cooktops) 8 10-29-2011 01:52 PM
KitchenAid superba dryer has heat but doesn't spin. How do I access the motor? davet_1961 Dryer Repair 1 09-21-2011 04:22 AM
kitchenaid gas dryer wont heat up basshunter62 Dryer Repair 0 06-12-2011 09:13 AM
KitchenAid KESC307HWH5 no heat mcguirmi Oven Repair (including Ranges and Cooktops) 7 01-17-2011 09:07 PM
Kitchenaid Oven will not heat up TAGS Oven Repair (including Ranges and Cooktops) 0 07-05-2010 04:56 PM
