| » repair tech needed |
Model Number: wed5300sq0 Brand: Whirlpool Age: 1 - 5 years
my dryer quit getting hot so i thought the heating element went out i decided to use the air fluff cycle i put the timer at 20 minutes and the dryer never shut off until i opened the door so now im thinking it the timer
Parts for Whirlpool WED5300SQ0 Dryer - AppliancePartsPros.com See the attachment for the wiring diagram. Did the timer advance but hang up just before off. If yes then it is probably a blown heater. If you look at the timing diagram you will see that the End Of Cycle gets power through Timer Switch 0 TM/OR contacts which gets it's power through the heating coil to drive the timer that last little bit to off.
__________________
| Display Modes | |
| Tech sheet needed | kasara | Washer Repair | 3 | 11-01-2012 04:35 PM |
| repair help needed | m_becker | Refrigerator & Freezer Repair | 1 | 06-17-2010 05:01 PM |
| About Hi-Tech Appliance Repair | hi-techappliance | Appliance Repair Companies - West of the Mississippi | 0 | 02-02-2009 02:10 PM |
| Is it worth it (tech advice needed)? | baron | Oven Repair (including Ranges and Cooktops) | 1 | 10-22-2008 09:17 PM |
