Discuss
whirlpool dryer not heatting and timer won't advance
 in
Dryer Repair
HEllo I just moved and my dryer won't heat nor the timer will advance. It only blows cold air and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer not heatting and timer won't advance
  #1 (permalink)
Old 11-08-2012, 05:03 AM
Junior Member
vero_09 is on a distinguished road
Default whirlpool dryer not heatting and timer won't advance
Brand: Whirlpool   Age: Less than 1 year
HEllo I just moved and my dryer won't heat nor the timer will advance. It only blows cold air and the timer will not stop. I already tried buying a new connection and the plug for the dryer since the house we moved into is a 4 wire and my dryer was set up for 3 wires. What can I do???
Ads By Google
  #2 (permalink)
Old 11-08-2012, 05:20 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
The above is confusing is it "nor the timer will advance" or "timer will not stop" ( timer advances but will not shut the unit off).
Are you sure you did the 4 wire hook up correctly" re: removed/disconnected the ground strap and then used the green/ground wire in the line cord to ground the machine frame?
If the timer does not advance does it do this in both timed dry and auto modes?
Have you checked that the unit is getting 240 volts?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer - No heat, Timer Does Not Advance katielove22 Dryer Repair 4 10-22-2012 12:06 AM
Whirlpool gas dryer, no heat, timer doesn't advance jeffmaaske Dryer Repair 1 09-05-2011 05:04 PM
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes. XtremeRob Dryer Repair 17 08-02-2011 09:34 PM
whirlpool dryer works but timer dosen't advance glassman58 Dryer Repair 8 06-06-2010 06:37 PM
Whirlpool dryer timer won't advance Hzep Dryer Repair 1 01-28-2008 03:22 PM
