Discuss
Amana Dryer - Will not run
 in
Dryer Repair
Hi, I have an Amana NED7200TW. This beauty has failed twice in the four years that I've owned it. I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Amana Dryer - Will not run
  #1 (permalink)
Old 11-07-2012, 05:05 PM
Junior Member
AnthonyS is on a distinguished road
Angry Amana Dryer - Will not run
Model Number: NED7200TW   Brand: Amana   Age: 1 - 5 years
Hi, I have an Amana NED7200TW. This beauty has failed twice in the four years that I've owned it. I clean it out and remove lint from all internal parts regularly, so naturally it has overheated twice and blown the thermistor.
The first time it happened was exactly one year ago. I was drying a couple of sheets and the dryer got so hot I could see shimmering waves of heat when I opened the door. It stopped running after that, so an electrician friend of mine and I traced out the problem to the thermistor, got a new one and it worked fine.
Last week, same thing happened with one sheet in the dryer. The unit stopped at about 5min remaining in the dry cyle and the sheet inside was so hot I could barely remove it. I checked the diagnostic code and it came back as '2', one of the causes of which is "Thermister Open Sensed". I bought another thermistor, replaced it and the dryer still won't run.
I can select a type of cycle, push the start button, and I get a couple of clicks from the motor but nothing else. No heat or motion of the drum. The minutes left in the cycle do count down, but that's it.
I cleared the diagnostic codes from the unit just in case, and it still won't run.
Any ideas as to what I should try next? Another person posting in this forum seemed to have the same issue as me, and fixed it with a new thermistor and he said that the thermal cutoff was off. Is this a fuse that I need to replace?
Thanks for any help you can offer.
Ads By Google
Related Models
Maytag NED7200TW10 29" Electric Dryer
Maytag NEDNS249-F  Ref - SXS/I&W
Maytag NEDNS249-FA  Ref - SXS/I&W
Maytag NEDNS249F  Ref - SXS/I&W
Maytag NEDNS249FA  Ref - SXS/I&W
Maytag NEDNS249FH  Ref - SXS/I&W
Maytag NEDNS249H  Ref - SXS/I&W
Maytag NEDNS249HA  Ref - SXS/I&W
Maytag NEDNS249HH  Ref - SXS/I&W
Norge NEF3G1 Range - F/s Std Ele
Norge NEF3G8DEV Range - S/c F/s Ele
Norge NEF6G6CLW Range - F/s Cont Clean Ele
Norge NEH2H0 Range - F/s Std Ele
Norge NEH3G8CV Range - S/c F/s Ele
Norge NEH3G8DX Range - S/c F/s Ele
Norge NEH6G6CLW Range - F/s Cont Clean Ele
Norge NEHA86-1 Range - S/c F/s Ele
Norge NEHW86-1 Range - S/c F/s Ele
Bosch NEM732 UC
Bosch NEM735 UC
Bosch NEM736 UC
Bosch NEM932 UC
Bosch NEM935 UC
Bosch NEM936 UC
Maytag NENS207G  Ref - SXS/I&W
Maytag NENS207GA  Ref - SXS/I&W
Maytag NENS207GH  Ref - SXS/I&W
Maytag NENS208GZ  Ref - Sxs
Maytag NENS208GZA  Ref - Sxs
Maytag NENS208GZH  Ref - Sxs
Maytag NENS208GZW  Ref - Sxs
Maytag NENS227F  Ref - Sxs
Maytag NENS227F-H  Ref - Sxs
Maytag NENS227FA  Ref - Sxs
Maytag NENS227FH  Ref - Sxs
Maytag NENS227G  Ref - Sxs
Maytag NENS227GA  Ref - Sxs
Maytag NENS227GH  Ref - Sxs
Maytag NENS228GZ  Ref - Sxs
Maytag NENS228GZA  Ref - Sxs
Maytag NENS228GZH  Ref - Sxs
Maytag NENS228GZW  Ref - Sxs
Maytag NENS248GZ  Ref - Sxs
Maytag NENS248GZA  Ref - Sxs
Maytag NENS248GZH  Ref - Sxs
Maytag NENS248GZW  Ref - Sxs
Maytag NENT156E  Ref - Top Mount
Maytag NENT156E-1  Ref - Top Mount
Maytag NENT156EA  Ref - Top Mount
Maytag NENT156EH  Ref - Top Mount
Maytag NENT156G  Ref - Top Mount
Maytag NENT156GA  Ref - Top Mount
Maytag NENT156GH  Ref - Top Mount
Maytag NENT156H  Ref - Top Mount
Maytag NENT156HA  Ref - Top Mount
Maytag NENT156HH  Ref - Top Mount
Maytag NENT156HW  Ref - Top Mount
Maytag NENT176H  Ref - Top Mount
Maytag NENT176HA  Ref - Top Mount
Maytag NENT176HH  Ref - Top Mount
Maytag NENT196H  Ref - Top Mount
Maytag NENT196HA  Ref - Top Mount
Maytag NENT196HH  Ref - Top Mount
Maytag NENT198H  Ref - Top Mount
Maytag NENT198HA  Ref - Top Mount
Maytag NENT198HH  Ref - Top Mount
Maytag NENT198K  Ref - Top Mount
Maytag NENT198KA  Ref - Top Mount
Maytag NENT217F  Ref - Top Mount
Maytag NENT217F-  Ref - Top Mount
Maytag NENT217F-A  Ref - Top Mount
Maytag NENT217FA  Ref - Top Mount
Maytag NENT217FH  Ref - Top Mount
Maytag NENT238H  Ref - Top Mount
Maytag NENT238HA  Ref - Top Mount
Maytag NENT238HH  Ref - Top Mount
Norge NER1360ACW Range - F/s Std Ele
International NER1360AGH Range - F/s Std Ele
Norge NER3540ACW Range - S/c F/s Ele
Norge NER3760ACW Range - S/c F/s Ele
Bosch NES732 UC
Bosch NES735 UC
Bosch NES736 UC
Bosch NES932 UC
Bosch NES935 UC
Bosch NES936 UC
Norge NEW2G1 Range - F/s Std Ele
Norge NEW2H0 Range - F/s Std Ele
Norge NEW2H1 Range - F/s Std Ele
Norge NEW3G1 Range - F/s Std Ele
Norge NEW3G8AC Range - S/c F/s Ele
Norge NEW3G8CV Range - S/c F/s Ele
Norge NEW3G8CX Range - S/c F/s Ele
Norge NEW3G8DEV Range - S/c F/s Ele
Norge NEW3G8DX Range - S/c F/s Ele
Norge NEW3G8EV Range - S/c F/s Ele
Norge NEW3G8EVW Range - S/c F/s Ele
Norge NEW3H2EX Range - F/s Std Ele
Norge NEW3H8CVW Range - S/c F/s Ele
Norge NEW3H8CX Range - S/c F/s Ele
Norge NEW3H8STVW-EV Range - S/c F/s Ele
Norge NEW3J8EV Range - S/c F/s Ele
Norge NEW6G6CLW Range - F/s Cont Clean Ele
Norge NEW6H6CLW Range - F/s Cont Clean Ele
Bosch NEZ1000
Bosch NEZ1010
Bosch NEZ1020
Bosch NEZ1050
Bosch NEZ1055
Bosch NEZ1070
Bosch NEZ1075
Bosch NEZ1100
Maytag NFW7200TW10 Automatic Washer
Amana NG2119 Washer - Top Loading
Amana NG3319 Washer - Top Loading
Amana NG3519 Washer - Top Loading
Amana NG4319 Washer - Top Loading
Amana NG4519 Washer - Top Loading
Amana NG4619 Washer - Top Loading
Amana NG4719 Washer - Top Loading
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
amana dryer pan head Dryer Repair 0 09-21-2012 03:34 AM
Amana Gas Dryer smittyd57 Dryer Repair 1 05-09-2012 03:45 PM
amana dryer too hot mbmdvm Dryer Repair 0 01-12-2012 03:01 PM
Amana Dryer greg50 Dryer Repair 0 08-22-2010 04:42 PM
Amana dryer tjsdad Dryer Repair 0 06-25-2010 04:16 PM
