| » Dryer runs when timer in off position and no heat. |
Model Number: EED4400WQ0 Brand: Estate Age: 1 - 5 years
My Estate dryer has suddenly started acting weird. The heat isn't working all the time and the dryer will run when timer is in off position. I checked the back of the knob for stripping and cracking but all seem OK. I'm pretty sure its a timer issue but before I spend 3/4 the cost of the dryer for a new timer I want to be sure, any help appreciated.
Hi.
Use the multimeter to check the timer contacts. With the timer set for Timed - Regular and power off check the contacts T-F, C-B, C-A for continuity. Then turn the timer to OFF and check again. If there is continuity at any of this contacts with the timer off - replace the timer Part number: W10185970 Here are the breakdown diagrams and Top and Console Parts parts for Estate EED4400WQ0 - AppliancePartsPros.com. Post the results.. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Keep us posted.
Simon.
__________________
Hi.
Replace the timer. Simon.
__________________
| Display Modes | |
| Timer Stops At Cool Down and Will Not Continue to Off Position | ymkarlsson | Dryer Repair | 1 | 02-20-2012 02:05 PM |
| New timer does not stop at the off position | bhurley | Dryer Repair | 1 | 01-18-2010 01:12 AM |
| Timer does not advance dryer runs no heat | Rmelc1 | Dryer Repair | 2 | 07-24-2009 01:10 PM |
| dryer runs,no heat,timer doesn't work | dcar48 | Dryer Repair | 2 | 02-04-2008 12:10 PM |
| Dryer doesnt heat but runs, timer isnt working either | bridget | Dryer Repair | 0 | 11-03-2007 11:37 AM |
