Discuss
ge gas dryer no heat
 in
Dryer Repair
my gas dryer heats for 2-3 min of of run time then goes cold can see igniter lighting up then
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » ge gas dryer no heat
  #1 (permalink)
Old 11-07-2012, 02:23 AM
Junior Member
mdelgiu1 is on a distinguished road
Default ge gas dryer no heat
Brand: GE   Age: 1 - 5 years
my gas dryer heats for 2-3 min of of run time then goes cold can see igniter lighting up then off this continues but no heat checked safte thermo and exit thermo both test good checked both both thermisters both read 7 ohms , any thoughts
Ads By Google
  #2 (permalink)
Old 11-07-2012, 09:14 AM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Replace the split coils on the gas valve. That will fix the problem. Part# 279834
__________________
Ricks Appliance Repair
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
gas dryer only heats on perm press and low heat, but not on high heat? GrandCanyonEngineer Dryer Repair 0 03-02-2011 02:23 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
