no heat in my kenmore
Dryer Repair
recently my dryer stooped working completely. i checked it and found the plug at the wall had a burnt wire..i
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » no heat in my kenmore
  #1 (permalink)
Old 11-06-2012, 05:52 AM
Junior Member
terry3388 is on a distinguished road
Default no heat in my kenmore
Model Number: 11086471100   Brand: Kenmore   Age: More than 10 years
recently my dryer stooped working completely. i checked it and found the plug at the wall had a burnt wire..i replaced it and after i plugged it in the exhaust hose was touching a limit switch which resulted in a few sparks, but now the dryer will run but no heat will come out...is it possible something shorted out when the metal exhaust touched the limit ? i ohmed out everything, limits, thermal fuse and element and everything seems good? any suggestions? Thanks, Terry Vandergriff
Related Models
Kenmore 11086471100 ELECTRIC DRYER
Kenmore 11086471110 ELECTRIC DRYER
Kenmore 11086471300 ELECTRIC DRYER
Kenmore 11086471310 ELECTRIC DRYER
Kenmore 11086471600 ELECTRIC DRYER
Kenmore 11086471610 ELECTRIC DRYER
Kenmore 11086471700 ELECTRIC DRYER
Kenmore 11086471710 ELECTRIC DRYER
Kenmore 11086471800 ELECTRIC DRYER
Kenmore 11086471810 ELECTRIC DRYER
Kenmore 11086475100 ELECTRIC DRYER
Kenmore 11086475110 ELECTRIC DRYER
Kenmore 11086475120 ELECTRIC DRYER
Kenmore 11086475130 ELECTRIC DRYER
Kenmore 11086475200 ELECTRIC DRYER
Kenmore 11086475210 ELECTRIC DRYER
Kenmore 11086475220 ELECTRIC DRYER
Kenmore 11086475300 ELECTRIC DRYER
Kenmore 11086475320 ELECTRIC DRYER
Kenmore 11086475330 ELECTRIC DRYER
Kenmore 11086475400 ELECTRIC DRYER
Kenmore 11086475410 ELECTRIC DRYER
Kenmore 11086475420 ELECTRIC DRYER
Kenmore 11086475600 ELECTRIC DRYER
Kenmore 11086475610 ELECTRIC DRYER
Kenmore 11086475620 ELECTRIC DRYER
Kenmore 11086475630 ELECTRIC DRYER
Kenmore 11086475720 ELECTRIC DRYER
Kenmore 11086475730 ELECTRIC DRYER
Kenmore 11086475800 ELECTRIC DRYER
Kenmore 11086475810 ELECTRIC DRYER
Kenmore 11086475820 ELECTRIC DRYER
Kenmore 11086475830 ELECTRIC DRYER
Kenmore 11086475920 ELECTRIC DRYER
Kenmore 11086475930 ELECTRIC DRYER
Kenmore 11086477100 ELECTRIC DRYER
Kenmore 11086477110 ELECTRIC DRYER
Kenmore 11086477300 ELECTRIC DRYER
Kenmore 11086477310 ELECTRIC DRYER
Kenmore 11086477600 ELECTRIC DRYER
Kenmore 11086477610 ELECTRIC DRYER
Kenmore 11086477700 ELECTRIC DRYER
Kenmore 11086477710 ELECTRIC DRYER
Kenmore 11086477800 ELECTRIC DRYER
Kenmore 11086477810 ELECTRIC DRYER
Kenmore 11086515100 ELECTRIC DRYER
Kenmore 11086515110 ELECTRIC DRYER
Kenmore 11086515120 ELECTRIC DRYER
Kenmore 11086535100 ELECTRIC DRYER
Kenmore 11086535110 ELECTRIC DRYER
Kenmore 11086535120 ELECTRIC DRYER
Kenmore 11086545100 ELECTRIC DRYER
Kenmore 11086545110 ELECTRIC DRYER
Kenmore 11086545120 ELECTRIC DRYER
Kenmore 11086556100 ELECTRIC DRYER
Kenmore 11086556110 ELECTRIC DRYER
Kenmore 11086557100 ELECTRIC DRYER
Kenmore 11086557110 ELECTRIC DRYER
Kenmore 11086557120 ELECTRIC DRYER
Kenmore 11086561100 ELECTRIC DRYER
Kenmore 11086561600 ELECTRIC DRYER
Kenmore 11086561800 ELECTRIC DRYER
Kenmore 11086562500 RESIDENTIAL DRYER
Kenmore 11086562501 RESIDENTIAL DRYER
Kenmore 11086566100 ELECTRIC DRYER
Kenmore 11086566110 ELECTRIC DRYER
Kenmore 11086566300 ELECTRIC DRYER
Kenmore 11086566310 ELECTRIC DRYER
Kenmore 11086566600 ELECTRIC DRYER
Kenmore 11086566610 ELECTRIC DRYER
Kenmore 11086566700 ELECTRIC DRYER
Kenmore 11086566710 ELECTRIC DRYER
Kenmore 11086566800 ELECTRIC DRYER
Kenmore 11086566810 ELECTRIC DRYER
Kenmore 11086568100 ELECTRIC DRYER
Kenmore 11086568110 ELECTRIC DRYER
Kenmore 11086568300 ELECTRIC DRYER
Kenmore 11086568310 ELECTRIC DRYER
Kenmore 11086568600 ELECTRIC DRYER
Kenmore 11086568610 ELECTRIC DRYER
Kenmore 11086568700 ELECTRIC DRYER
Kenmore 11086568710 ELECTRIC DRYER
Kenmore 11086568800 ELECTRIC DRYER
Kenmore 11086568810 ELECTRIC DRYER
Kenmore 11086570100 ELECTRIC DRYER
Kenmore 11086570110 ELECTRIC DRYER
Kenmore 11086570120 ELECTRIC DRYER
Kenmore 11086570200 ELECTRIC DRYER
Kenmore 11086570210 ELECTRIC DRYER
Kenmore 11086570310 ELECTRIC DRYER
Kenmore 11086570320 ELECTRIC DRYER
Kenmore 11086570400 ELECTRIC DRYER
Kenmore 11086570410 ELECTRIC DRYER
Kenmore 11086570600 ELECTRIC DRYER
Kenmore 11086570610 ELECTRIC DRYER
Kenmore 11086570620 ELECTRIC DRYER
Kenmore 11086570710 ELECTRIC DRYER
Kenmore 11086570720 ELECTRIC DRYER
Kenmore 11086570800 ELECTRIC DRYER
Kenmore 11086570810 ELECTRIC DRYER
Kenmore 11086570820 ELECTRIC DRYER
Kenmore 11086571100 ELECTRIC DRYER
Kenmore 11086571200 ELECTRIC DRYER
Kenmore 11086571400 ELECTRIC DRYER
Kenmore 11086571600 ELECTRIC DRYER
Kenmore 11086571800 ELECTRIC DRYER
Kenmore 11086572100 ELECTRIC DRYER
Kenmore 11086572110 ELECTRIC DRYER
Kenmore 11086572120 ELECTRIC DRYER
Kenmore 11086572200 ELECTRIC DRYER
Kenmore 11086572210 ELECTRIC DRYER
Kenmore 11086572300 ELECTRIC DRYER
Kenmore 11086572310 ELECTRIC DRYER
Kenmore 11086572320 ELECTRIC DRYER
Kenmore 11086572400 ELECTRIC DRYER
Kenmore 11086572410 ELECTRIC DRYER
Kenmore 11086572500 RESIDENTIAL DRYER
Kenmore 11086572501 RESIDENTIAL DRYER
Kenmore 11086572600 ELECTRIC DRYER
Kenmore 11086572610 ELECTRIC DRYER
  #2 (permalink)
Old 11-06-2012, 07:23 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Did you check the power?
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts. This is the voltage for the heating coil.
Be careful as 240 volts is lethal !!!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HE3 No Heat Jersey_Jedi Dishwasher Repair 0 02-07-2011 04:11 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Kenmore Model 110 76652500 kenmore no heat cgarza1 Dryer Repair 0 09-02-2010 02:09 PM
kenmore won't heat up mfbriskie Dryer Repair 0 02-19-2010 08:54 PM
