Discuss
Whirlpool Dryer doesn't start
 in
Dryer Repair
Hey APP forums, I recently moved into a rental home for a year and the previous residents left us a
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer doesn't start
  #1 (permalink)
Old 11-04-2012, 04:45 PM
Junior Member
PrinceEnder is on a distinguished road
Default Whirlpool Dryer doesn't start
Model Number: LER4634jq0   Brand: Whirlpool   Age: 1 - 5 years
Hey APP forums,
I recently moved into a rental home for a year and the previous residents left us a washer and dryer in the basement - which, according to the landlord, didn't work anymore. (he was right)
I fixed the washer but the dryer is appearing to be a bit of a struggle. I'm unsure of the age, but it looks to be within 10 years old. When I started trying to figure it out, the power cord was disconnected and placed across the room.. I'm not sure why they did that, but I reattached it fine. When I press the start button on the dryer, regardless of the setting, it doesn't start. It doesn't buzz, hum, or stutter. It seems lifeless. The door switch appears to be working fine, it clicks within range of the door shutting.
I tested the wall plug with a meter and it shows a current, so it's not that.
Power is going through to the machine, it's just not starting.
(I actually accidentally blew up my ohm meter by touching it on the back 3 power cord connectors, so I'm about to go to the store to pick up another)
I assume the first / next step for me is to test the start switch for continuity?
Thanks for all the help
Ads By Google
Related Models
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
Whirlpool LER4634PQ1 29" Electric Dryer
Whirlpool LER4634PT0 29" Electric Dryer
Whirlpool LER4634PT1 29" Electric Dryer
Whirlpool LER5434AN0
Whirlpool LER5434AW0
Whirlpool LER5600HQ0
Whirlpool LER5600HZ0
Whirlpool LER5600JQ0
Whirlpool LER5600JT0
Whirlpool LER5620KQ0
Whirlpool LER5620KQ1
Whirlpool LER5620KQ2 29"electric Dryer
Whirlpool LER5624BN0
Whirlpool LER5624BN1
Whirlpool LER5624BN2
Whirlpool LER5624BW0
Whirlpool LER5624BW1
Whirlpool LER5624BW2
Whirlpool LER5624DQ0
Whirlpool LER5624DQ1
Whirlpool LER5624DW1
Whirlpool LER5624DZ0
Whirlpool LER5624DZ1
Whirlpool LER5634AN0
Whirlpool LER5634AQ0
Whirlpool LER5634AQ1
Whirlpool LER5634AQ2
Whirlpool LER5634AW0
Whirlpool LER5634DQ1
Whirlpool LER5634EQ0
Whirlpool LER5634EZ0
Whirlpool LER5634LG0
Whirlpool LER5634LQ0 29" Electric Dryer
Whirlpool LER5634LT0
Whirlpool LER5634LW0
Whirlpool LER5635LQ0 29"electric Dryer
Whirlpool LER5635LQ1 29"electric Dryer
Whirlpool LER5636DW0
Whirlpool LER5636DW1
Whirlpool LER5636EQ0
Whirlpool LER5636EQ1
Whirlpool LER5636EQ2
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
  #2 (permalink)
Old 11-05-2012, 12:12 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool LER4634JQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
I would recheck the power first. Neutral (white) to L1 (black) is what runs the motor and should be 120 volts. Another way to check it is if the interior light works. Also if the timer advances at mid-scale timed dry with the door closed, this confirms that you have power and that the door switch is OK.
The most common cause of a dead dryer is a blown thermal fuse (Item 19 in the Bulkhead Parts section).
If blown replace it.
Also check/clean the vent system as this is the most common cause of it blowing.
Check that the outside louvers on the vent open properly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer won't start adsch Dryer Repair 5 07-02-2012 11:16 AM
Whirlpool dryer won't start moonie777 Dryer Repair 1 05-13-2011 04:00 PM
Whirlpool Dryer Won't Start AboveTheBULL Dryer Repair 4 01-24-2010 08:02 AM
whirlpool dryer won't start mrk1 Dryer Repair 0 01-11-2010 06:50 PM
Whirlpool Dryer won't start Conrad79 Dryer Repair 3 10-30-2007 07:54 AM
