Discuss
Maytag Centennial dryer will not heat up
 in
Dryer Repair
My Maytag Centennial gas dryer will no longer heat up when turned on. It still spins but does not produce
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Centennial dryer will not heat up
  #1 (permalink)
Old 10-31-2012, 07:51 PM
Junior Member
1hkfan is on a distinguished road
Default Maytag Centennial dryer will not heat up
Model Number: MGDC400VW0   Brand: Maytag   Age: 1 - 5 years
My Maytag Centennial gas dryer will no longer heat up when turned on. It still spins but does not produce any heat to dry the clothes. It will also run non stop as if the timer is not working as well. I have tried each setting, and all have failed to heat up.
Any suggestions?
Ads By Google
Related Models
Maytag MGDZ400TQ1 27" Gas Dryer
Maytag MGDZ400TQ2 27" Gas Dryer
Maytag MGDZ600TB1 27" Gas Dryer
Maytag MGDZ600TB2 27" Gas Dryer
Maytag MGDZ600TK1 27" Gas Dryer
Maytag MGDZ600TK2 27" Gas Dryer
Maytag MGDZ600TW1 27" Gas Dryer
Maytag MGDZ600TW2 27" Gas Dryer
Frigidaire MGF200PBDA Frg(v2) / Gas Range
Frigidaire MGF200PBDB Frg(v1) / Gas Range
Frigidaire MGF200PBWA Frg(v1) / Gas Range
Frigidaire MGF200PBWB Frg(v2) / Gas Range
Frigidaire MGF300PBDA Frg(v1) / Gas Range
Frigidaire MGF300PBDB Wwh(v17) / Gas Range
Frigidaire MGF300PBDC Kel(v1) / Gas Range
Frigidaire MGF300PBDD Frg(v1) / Gas Range
Frigidaire MGF300PBDE Frg(v1) / Gas Range
Frigidaire MGF300PBDF Frg(v1) / Gas Range
Frigidaire MGF300PBDG Frg(v2) / Gas Range
Frigidaire MGF300PBDH
Frigidaire MGF300PBWA Frg(v2) / Gas Range
Frigidaire MGF300PBWB Wwh(v18) / Gas Range
Frigidaire MGF300PBWC Kel(v2) / Gas Range
Frigidaire MGF300PBWD Frg(v2) / Gas Range
Frigidaire MGF300PBWE Frg(v2) / Gas Range
Frigidaire MGF300PBWF Frg(v3) / Gas Range
Frigidaire MGF300PBWG Frg(v4) / Gas Range
Frigidaire MGF300PBWH
Frigidaire MGF301SBDA Frg(v1) / Gas Range
Frigidaire MGF301SBWA Frg(v2) / Gas Range
Frigidaire MGF303PGDA Frg(v1) / Gas Range
Frigidaire MGF303PGDC Frg(v1) / Gas Range
Frigidaire MGF303PGDD Frg(v2) / Gas Range
Frigidaire MGF303PGDE Frg(v3) / Gas Range
Uni MGF303PGDG Universal/gas Range
Uni MGF303PGDH Universal/gas Range
Uni MGF303PGDJ Universal/gas Range
Uni MGF303PGDK Universal/gas Range
Uni MGF303PGDL Universal/gas Range
Frigidaire MGF303PGWA Frg(v2) / Gas Range
Frigidaire MGF303PGWC Frg(v4) / Gas Range
Frigidaire MGF303PGWD Frg(v5) / Gas Range
Frigidaire MGF303PGWE Frg(v6) / Gas Range
Uni MGF303PGWG Universal/gas Range
Uni MGF303PGWH Universal/gas Range
Uni MGF303PGWJ Universal/gas Range
Uni MGF303PGWK Universal/gas Range
Uni MGF303PGWL Universal/gas Range
Frigidaire MGF311SBDA Frg(v3) / Gas Range
Frigidaire MGF311SBDB Wwh(v19) / Gas Range
Frigidaire MGF311SBDC Frg(v1) / Gas Range
Frigidaire MGF311SBDD Frg(v1) / Gas Range
Frigidaire MGF311SBDE Frg(v1) / Gas Range
Frigidaire MGF311SBDF Frg(v1) / Gas Range
Frigidaire MGF311SBWA Frg(v4) / Gas Range
Frigidaire MGF311SBWB Wwh(v20) / Gas Range
Frigidaire MGF311SBWC Frg(v2) / Gas Range
Frigidaire MGF311SBWD Frg(v2) / Gas Range
Frigidaire MGF311SBWE Frg(v2) / Gas Range
Frigidaire MGF311SBWF Frg(v2) / Gas Range
Frigidaire MGF312SBDA Frg(v1) / Gas Range
Frigidaire MGF312SBDB
Frigidaire MGF312SBDC Frg(v1) / Gas Range
Frigidaire MGF312SBWA Frg(v2) / Gas Range
Frigidaire MGF312SBWB
Frigidaire MGF312SBWC Frg(v2) / Gas Range
Frigidaire MGF313SCDB Frg(v1) / Gas Range
Frigidaire MGF313SCDC Frg(v1) / Gas Range
Frigidaire MGF313SCWB Frg(v2) / Gas Range
Frigidaire MGF313SCWC Frg(v2) / Gas Range
Frigidaire MGF316WFSA Frg(v0) / Gas Range
Frigidaire MGF316WFSB Frg(v0) / Gas Range
Frigidaire MGF316WFSC Frg(v1) / Gas Range
Frigidaire MGF316WFTC Frg(v2) / Gas Range
Frigidaire MGF316WGSA Frg(v0) / Gas Range
Frigidaire MGF316WGSC Frg(v1) / Gas Range
Frigidaire MGF316WGSD Frg(v1) / Gas Range
Frigidaire MGF316WGSE Frg(v2) / Gas Range
Frigidaire MGF316WGSF Frg(v3) / Gas Range
Uni MGF316WGSG Universal/gas Range
Uni MGF316WGSH Universal/gas Range
Uni MGF316WGSJ Universal/gas Range
Uni MGF316WGSK Universal/gas Range
Frigidaire MGF316WGTA Frg(v2) / Gas Range
Frigidaire MGF316WGTC Frg(v3) / Gas Range
Frigidaire MGF322BBDA Frg(v3) / Gas Range
Frigidaire MGF322BBDB
Frigidaire MGF322BBDC Frg(v1) / Gas Range
Frigidaire MGF322BBDD Frg(v1) / Gas Range
Frigidaire MGF322BBWA Frg(v4) / Gas Range
Frigidaire MGF322BBWB
Frigidaire MGF322BBWC Frg(v2) / Gas Range
Frigidaire MGF322BBWD Frg(v2) / Gas Range
Frigidaire MGF324BEDA Frg(v1) / Gas Range
Frigidaire MGF324BEDB Frg(v1) / Gas Range
Frigidaire MGF324BEDC Frg(v1) / Gas Range
Frigidaire MGF324BEWA Frg(v2) / Gas Range
Frigidaire MGF324BEWB Frg(v2) / Gas Range
Frigidaire MGF324BEWC Frg(v2) / Gas Range
Frigidaire MGF324BGDA Frg(v1) / Gas Range
Frigidaire MGF324BGDB Frg(v1) / Gas Range
Frigidaire MGF324BGDD Frg(v1) / Gas Range
Frigidaire MGF324BGDE Frg(v2) / Gas Range
Frigidaire MGF324BGDF Frg(v1) / Gas Range
Frigidaire MGF324BGWA Frg(v2) / Gas Range
Frigidaire MGF324BGWB Frg(v2) / Gas Range
Frigidaire MGF324BGWD Frg(v3) / Gas Range
Frigidaire MGF324BGWE Frg(v4) / Gas Range
Frigidaire MGF324BGWF Frg(v2) / Gas Range
Frigidaire MGF324SEDA Frg(v1) / Gas Range
Frigidaire MGF324SEDB Frg(v3) / Gas Range
Frigidaire MGF324SEDC Frg(v3) / Gas Range
Frigidaire MGF324SEDD Frg(v1) / Gas Range
Frigidaire MGF324SEWA Wwh(v10) / Gas Range
Frigidaire MGF324SEWB Frg(v4) / Gas Range
Frigidaire MGF324SEWC Frg(v4) / Gas Range
Frigidaire MGF324SEWD Frg(v2) / Gas Range
Frigidaire MGF324WBSA Wwh(v17) / Gas Range
Frigidaire MGF324WBSB Wwh(v13) / Gas Range
  #2 (permalink)
Old 11-01-2012, 08:47 AM
Expert
APP Volunteer
rickgburton is on a distinguished road
Default
Below the dryer door on the left side is a plastic plug that will pop out. Start the dryer on timed dry high heat and look through that viewing hole and see if the igniter glows red and then turns off. If it does replace the coils on the gas valve. If you don't see it glow red you'll need to check it for continuity. If it reads open, replace it. Igniter-#279311 Coils-#279834
__________________
Ricks Appliance Repair
  #3 (permalink)
Old 11-01-2012, 09:48 PM
Junior Member
Default
Thanks Rick,
I tried what you suggested and I don't see anything but darkness. I will figure out how to check for continuity.
  #4 (permalink)
Junior Member
Default
Thanks Rick,
  #5 (permalink)
Old 11-01-2012, 11:10 PM
Expert
APP Volunteer
Default
Remove the back of the dryer and check the thermal fuse first. On a gas dryer the thermal fuse is inline with the gas valve. Part# 3392519 If it checks good here's how to remove the front panel:
Remove the lint filter and the two screws right below it. Use a putty knife or something similar to release the two clips in the front corners between the top and front panel. Lift the top up and lean it back out of the way. Remove the two screws on the inside holding the front panel to the two sides. Lean the front panel forward and disconnect the door switch connector. Pull up on the front panel to release it from the two lower clip.
__________________
  #6 (permalink)
Old 11-01-2012, 11:11 PM
Expert
APP Volunteer
Default
__________________
  #7 (permalink)
Old 01-20-2013, 03:59 PM
Junior Member
whattheheck is on a distinguished road
Default
Hi. I found this forum because I'm having similar trouble. My dryer will start fine and heat fine. But after a few min. the heat goes out and will not start again. I vaccummed all the lint out of everywhere. Any ideas? Like I said, the glow plug glows, and it fires, but after a few min. goes out and won't re fire.
Thanks.
John
  #8 (permalink)
Old 01-21-2013, 02:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
What is the complete model number of the dryer?
Would the igniter glow again?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #9 (permalink)
Old 02-10-2013, 03:51 PM
Junior Member
JamaicaBob is on a distinguished road
Default Another wrinkle to this "no heat" issue
Greetings,
I tried the troubleshooting mentioned above and I found (or at least it seems) that the pilot light, the igniter and coils seem to be working.
The next question would be, what if they don't light, ignite etc. on automatic settings? Is there a way to troubleshoot that?
Thx
  #10 (permalink)
Old 02-10-2013, 04:22 PM
Expert
APP Volunteer
Default
Then you will need to find out where you're losing the voltage to the gas valve. If it works on timed and not automatic, it's probably the timer that's faulty.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Centennial Gas Dryer won't get hot gcdunlap Dryer Repair 0 03-27-2012 04:12 PM
Maytag Centennial Dryer mcurt1 Dryer Repair 2 03-20-2012 05:40 AM
Maytag Centennial Dryer New candleice Dryer Repair 1 03-19-2012 04:34 AM
maytag centennial litopelena Washer Repair 0 11-27-2010 04:03 AM
Maytag Centennial Dryer going through motors Dave in NH Dryer Repair 1 06-14-2009 05:25 PM
