| » GE Gas Dryer - Drum Won't Turn / Locked Up |
Model Number: DDG8280GDLWH Brand: GE Age: More than 10 years
When I press the Start button, it makes a buzzing sound and nothing else happens. I can spin the drum counterclockwise manually from the inside, but not clockwise. I removed the top and and the plate in the back where you can see the motor. As far as I can tell, the belt looks fine. I can't see anything jamming it from the top, but I can't tell if something may be jamming it at the bottom as I haven't completely disassembled it and therefore I can't see the entire bottom of the drum.
Thanks! Ads By Google Related Models |
HI.
Remove the front panel and check the blower for any restrictions.If non found rotate the motor. If the motor is bad - replace it Part number: WE17X10010 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Dryer drum will not turn | JohnRHayes | Dryer Repair | 0 | 08-08-2012 10:47 AM |
| Dryer Drum does not turn | javvy | Dryer Repair | 1 | 07-26-2011 08:10 AM |
| dryer drum will not turn on | rturner | Dryer Repair | 1 | 06-29-2008 10:17 AM |
| Dryer Drum Does Not Turn | Pike | Dryer Repair | 1 | 12-17-2007 07:18 PM |
| Dryer Drum Won't Turn | PSINKHORN | Dryer Repair | 1 | 10-28-2007 07:41 PM |
