Discuss
Dryer stops heating during the cycle
 in
Dryer Repair
This gas dryer is having an issue where it takes a long time to dry. It starts and a flame
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer stops heating during the cycle
  #1 (permalink)
Old 10-29-2012, 01:42 PM
Junior Member
juicejug is on a distinguished road
Default Dryer stops heating during the cycle
Model Number: LGR8648PW0   Brand: Whirlpool   Age: 5 - 10 years
This gas dryer is having an issue where it takes a long time to dry. It starts and a flame ignites seemingly properly for the first 20-30 minutes or so but then never lights again during the cycle. In High heat mode, if I run the dryer for this period, stop it once it stops heating, wait a minute and then restart, it lights right up again. In low heat mode, it does the same except in shorter intervals and I have on some occasions smelled gas. I've also noticed in the high heat mode that the igniter will light up every few minutes, but there is no gas that gets ignited
I've tried:
Cleaning the vents
Checked the resistance on both coils and they are normal
The igniter is lighting the flame
I've checked all 3 thermostats and they show 0 resistance
What else could I check?
Ads By Google
Related Models
Whirlpool LGR8648PW0 29"gas Dryer
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0
Whirlpool LGR8857EQ1
Whirlpool LGR8857EQ2
Whirlpool LGR8857EQ3
Whirlpool LGR8857EZ0
Whirlpool LGR8857EZ1
Whirlpool LGR8857EZ2
Whirlpool LGR8857EZ3
Whirlpool LGR8858DQ0
Whirlpool LGR8858DQ1
Whirlpool LGR8858DZ0
Whirlpool LGR8858DZ1
Whirlpool LGR8858EQ0
Whirlpool LGR8858EQ1
Whirlpool LGR8858EQ2
Whirlpool LGR8858EQ3
Whirlpool LGR8858EZ0
Whirlpool LGR8858EZ1
Whirlpool LGR8858EZ2
Whirlpool LGR8858EZ3
Amana LGS10AW Washer - Top Loading
Amana LGS19AW Dryer - Gas
Amana LGS33AW Dryer - Gas
Amana LGS34AW Washer - Top Loading
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AN0
Whirlpool LGT5434AQ0
Whirlpool LGT5434AW0
Whirlpool LGT5436AN0
Whirlpool LGT5436AW0
Whirlpool LGT5624BN0
Whirlpool LGT5624BN1
Whirlpool LGT5624BN2
Whirlpool LGT5624BQ0
Whirlpool LGT5624BQ1
Whirlpool LGT5624BQ2
Whirlpool LGT5624BW0
Whirlpool LGT5624BW1
Whirlpool LGT5624BW2
Whirlpool LGT5624DQ0
Whirlpool LGT5624DQ1
Whirlpool LGT6634AN0
Whirlpool LGT6634AN1
Whirlpool LGT6634AN2
Whirlpool LGT6634AQ0
Whirlpool LGT6634AQ1
Whirlpool LGT6634AQ2
Whirlpool LGT6634AW0
Whirlpool LGT6634AW1
Whirlpool LGT6634AW2
Whirlpool LGT6634DQ0
Whirlpool LGT6634DQ1
Whirlpool LGT6634DZ0
Whirlpool LGT6634DZ1
Whirlpool LGT6638AN0
Whirlpool LGT6638AN1
Whirlpool LGT6638AN2
Whirlpool LGT6638AQ0
Whirlpool LGT6638AQ2
Whirlpool LGT6638AW0
Whirlpool LGT6638AW1
Whirlpool LGT6638AW2
Whirlpool LGT6638DQ0
Whirlpool LGT6638DQ1
Whirlpool LGT6638DZ0
Whirlpool LGT6638DZ1
Whirlpool LGT7646AN0
Whirlpool LGT7646AQ0
Whirlpool LGT7646AQ2
Whirlpool LGT7646AW0
Whirlpool LGT7646AZ0
Whirlpool LGT7646AZ2
Whirlpool LGT7646DQ0
Whirlpool LGT7646DQ1
Whirlpool LGT7646DZ0
Whirlpool LGT7646DZ1
Whirlpool LGT7646EQ0
Whirlpool LGT7646EQ1
Whirlpool LGT7646EQ2
Whirlpool LGT7646EQ3
Whirlpool LGT7646EZ0
Whirlpool LGT7646EZ1
Whirlpool LGT7646EZ2
Whirlpool LGT7646EZ3
Whirlpool LGT7848AN0
Whirlpool LGT7848AQ0
Whirlpool LGT7848AQ1
Whirlpool LGT7848AQ2
Whirlpool LGT7848AW0
Whirlpool LGT7848AZ0
Whirlpool LGT7848AZ1
Whirlpool LGT7848AZ2
Whirlpool LGT7848DQ0
Whirlpool LGT7848DQ1
Whirlpool LGT7848DZ0
Whirlpool LGT7848DZ1
Whirlpool LGT8858AN0
Whirlpool LGT8858AN1
Whirlpool LGT8858AN2
Whirlpool LGT8858AQ0
Whirlpool LGT8858AQ1
Whirlpool LGT8858AQ2
Whirlpool LGT8858AW0
Whirlpool LGT8858AW1
Whirlpool LGT8858AW2
Whirlpool LGT8858AZ0
Whirlpool LGT8858AZ1
Whirlpool LGT8858AZ2
Whirlpool LGT8858DQ0
Whirlpool LGT8858DQ1
Whirlpool LGT8858DZ0
Whirlpool LGT8858DZ1
Whirlpool LGV4434AN0
Whirlpool LGV4434AW0
Whirlpool LGV4436AN0
Whirlpool LGV4436AW0
Whirlpool LGV4624BG0
Whirlpool LGV4624BN0
  #2 (permalink)
Old 10-29-2012, 03:25 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Based on the information you provided the problem is bad control coils Part number: 279834
Part number: 279834
Use the video clip for the instructions.
Here are the breakdown diagrams and 8318272 Burner Assembly parts for Whirlpool LGR8648PW0 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-29-2012, 03:39 PM
Junior Member
Default
So even though:
The two prong coil will read 1,000-1,300 ohms, and the three prong coilwill read 1,300-1,400 ohms across prongs 1&2, and 500-600 ohms acrossprongs 1&3.
these readings are exactly what I'm getting, they could still be bad? I'm happy to replace them but at the cost of them, I want to make sure that this is, in fact, the failing part(s)
Since my first post I've been watching closely and have noticed the igniter glow with no flame, then about 30 seconds later I smelled gas, then another 30 seconds after that the igniter glowed again and gas was ignited.
  #4 (permalink)
Old 10-29-2012, 04:01 PM
Expert
Default
HI.
It's either the control coils or the gas valve ( much more $).
The gas valve comes with the new coils, but because of the price I'd try the coils first.
The coil may fail when it's hot, if you are testing it when it's cool it'll show normal resistance.
Simon.
__________________
  #5 (permalink)
Old 10-29-2012, 04:04 PM
Junior Member
Default
Okay, that sounds reasonable. I did test them when they were cool and I have seen other users have the same issues with coils. I also don't suspect the gas valve as I've smelled gas and it does fire on occasion, where I'd expect a valve to be an all or none issue.
I'll try and remember to post the results.
  #6 (permalink)
Old 10-31-2012, 08:29 PM
Junior Member
Default
Just got the coils today. Took about 15 minutes to change them out and put it all back together. Only dried 1 load but it seems to be perfectly back to normal.
Thanks for your help!
  #7 (permalink)
Old 11-01-2012, 09:17 AM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer stops mid cycle, restarts, then stops RayD Dryer Repair 4 06-07-2012 07:08 AM
Bosch Dishwasher not heating up and cycle never stops bikemike Dishwasher Repair 0 09-07-2011 01:44 AM
Dryer Heats then stops heating. After rest, heats then stops heating Jim WA Dryer Repair 0 07-07-2011 12:53 PM
Kenmore dryer starts to heat, makes odd cycle noise and stops heating 2 minutes in pitcher09 Dryer Repair 0 08-21-2009 04:46 PM
gas dryer stops heating maclc Dryer Repair 2 07-25-2008 06:13 PM
