Discuss
Whirlpool LER7647EQ0 Dryer not heating in auto cycle
 in
Dryer Repair
I've got a Whirlpool LER7647EQ0 Dryer that is not fully drying when set on the automatic cycle, yet when using
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool LER7647EQ0 Dryer not heating in auto cycle
  #1 (permalink)
Old 10-29-2012, 10:47 AM
Junior Member
rjyoung00 is on a distinguished road
Default Whirlpool LER7647EQ0 Dryer not heating in auto cycle
Model Number: LER7646EQ0   Brand: Whirlpool   Age: More than 10 years
I've got a Whirlpool LER7647EQ0 Dryer that is not fully drying when set on the automatic cycle, yet when using the timed cycle, it works just fine. I've pulled the back of it & cleaned everything, nothing was clogged. I assume since it works fine in the timed cycle that there is nothing wrong with the heating element, thermal fuse or the timer. Am I correct in assuming that this would be a thermostat problem, or am I overlooking something?
EDIT - Just checked the thermostats & thermal fuse & have continuity across them.
Related Models
Whirlpool LER7646EQ0 DRYER
Whirlpool LER7646EQ1 DRYERS
Whirlpool LER7646EQ2 ELECTRIC DRYER
Whirlpool LER7646EZ0 DRYER
Whirlpool LER7646EZ1 DRYERS
Whirlpool LER7646EZ2 ELECTRIC DRYER
Whirlpool LER7646JQ0 DRYER
Whirlpool LER7646JT0 DRYER
Whirlpool LER7648KQ0 RESIDENTIAL DRYER
Whirlpool LER7648KQ1 RESIDENTIAL DRYER
Whirlpool LER7648KQ2 RESIDENTIAL DRYER
Whirlpool LER7648KQ3 29"ELECTRIC DRYER
Whirlpool LER7648KT0 RESIDENTIAL DRYER
Whirlpool LER7648KT1 RESIDENTIAL DRYER
Whirlpool LER7648KT2 RESIDENTIAL DRYER
Whirlpool LER7648KT3 29"ELECTRIC DRYER
Whirlpool LER7648PQ0 29" ELECTRIC DRYER
Whirlpool LER7648PQ1 29" ELECTRIC DRYER
Whirlpool LER7648PT0 29" ELECTRIC DRYER
Whirlpool LER7648PT1 29" ELECTRIC DRYER
Whirlpool LER7848DQ0 ELECTRIC DRYER
Whirlpool LER7848DQ1 ELECTRIC DRYER
Whirlpool LER7848DZ0 ELECTRIC DRYER
Whirlpool LER7848DZ1 ELECTRIC DRYER
Whirlpool LER7858AN1 ELECTRIC DRYER
Whirlpool LER7858AN2 ELECTRIC DRYER
Whirlpool LER7858AW0 Residential Dryer
Whirlpool LER7858AW1 ELECTRIC DRYER
Whirlpool LER7858AW2 ELECTRIC DRYER
Whirlpool LER8620PG0 29"ELECTRIC DRYER
Whirlpool LER8620PG1 29"ELECTRIC DRYER
Whirlpool LER8620PW0 29"ELECTRIC DRYER
Whirlpool LER8620PW1 29"ELECTRIC DRYER
Whirlpool LER8648LG0 RESIDENTIAL DRYER
Whirlpool LER8648LG1 29"ELECTRIC DRYER
Whirlpool LER8648LQ0 RESIDENTIAL DRYER
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
Whirlpool LER8648PQ1 29"ELECTRIC DRYER
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
  #2 (permalink)
Old 10-30-2012, 02:49 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool LER7646EQ0 Dryer - AppliancePartsPros.com
See the attachment for the tech sheet
I found your post confusing.
In the title you say " Dryer not heating in auto cycle"
In the post body you say "Dryer that is not fully drying when set on the automatic cycle" which seems to say that it is heating but not fully drying.
Which is it?
As you can see from the wiring diagram the only part that changes when in timed dry to auto is the timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer stays on during auto cycle js7fm0 Dryer Repair 0 06-27-2012 08:25 PM
Whirlpool Gas Dryer, Auto cycle does not advance and timed cycle does not heat Costa Rica Kim Dryer Repair 0 01-25-2012 10:47 AM
Whirlpool Dryer "Auto" cycle won't end AndreaP5 Dryer Repair 1 04-13-2011 08:55 AM
Whirlpool Dryer Auto Cycle Will not End davcinoz Dryer Repair 1 07-19-2009 02:52 AM
Dryer overheats on auto dry cycle hicks115 Dryer Repair 3 04-19-2009 03:37 PM
