Discuss
Whirlpool timer won't turn on autosense and will not get hot
 in
Dryer Repair
My Whirlpool dryer timer will not turn if it is on the auto-sense setting. It will turn if it is
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool timer won't turn on autosense and will not get hot
  #1 (permalink)
Old 10-28-2012, 01:06 PM
Junior Member
Remi32 is on a distinguished road
Default Whirlpool timer won't turn on autosense and will not get hot
Model Number: TGDS840PQ1   Brand: Whirlpool   Age: 5 - 10 years
My Whirlpool dryer timer will not turn if it is on the auto-sense setting. It will turn if it is on the timed try or the fluff no heat option. Also..the heat will never come on no matter what setting it's on.
I did a continuity test on the high-limit thermostat, thermal shutoff, and cycling thermostat. All seemed to test fine. The cycling one had continuity across the red but not the violet wires.
Do you think it's the timer? or something else? I'm not sure what else to test.
Ads By Google
Related Models
Whirlpool TGDS840PQ1 29"gas Dryer
Whirlpool TGDX540RQ0 29" Gas Dryer
Whirlpool TGDX540RQ1 29" Gas Dryer
Whirlpool TGDX640EQ0
Whirlpool TGDX640EQ1
Whirlpool TGDX640EQ2
Whirlpool TGDX640EQ3
Whirlpool TGDX640JQ0
Whirlpool TGDX640JQ1
Whirlpool TGDX640JQ2
Whirlpool TGDX640JQ3 29"gas Dryer
Whirlpool TGDX640PQ0 29" Gas Dryer
Whirlpool TGDX640PQ1 29"gas Dryer
Tappan TGF303AWA Tappan/gas Range
Tappan TGF303BWA Tappan/gas Range
Tappan TGF303BWB Tappan/gas Range
Tappan TGF303BWC Tappan/gas Range
Frigidaire TGF303BWD Tappan/range
Tappan TGF303BWE Tappan/range
Tappan TGF317AUA Tappan/range
Tappan TGF317AUB Tappan/gas Range
Tappan TGF317AWA Tappan/range
Tappan TGF317AWB Tappan/gas Range
Tappan TGF317BUA Tappan/gas Range
Tappan TGF317BUB Tappan/gas Range
Tappan TGF317BUC Tappan/gas Range
Tappan TGF317BWA Tappan/gas Range
Tappan TGF317BWB Tappan/gas Range
Tappan TGF317BWC Tappan/gas Range
Tappan TGF317DUA Tappan/gas Range
Tappan TGF317DUB Tappan/gas Range
Tappan TGF317DUC Tappan/range
Tappan TGF317DWA Tappan/gas Range
Tappan TGF317DWB Tappan/gas Range
Tappan TGF317DWC Tappan/range
Tappan TGF317DWD Tappan/range
Tappan TGF317DWE Tappan/range
Tappan TGF317ESA Tappan/range
Tappan TGF317ESB Tappan/range
Tappan TGF317ESC Tappan/range
Tappan TGF317ESD Tappan/range
Tappan TGF320DUA Tappan/gas Range
Tappan TGF320DWA Tappan/gas Range
Tappan TGF320DWB Tappan/range
Tappan TGF320DWC Tappan/range
Tappan TGF324BHDD Tappan/gas Range
Frigidaire TGF324BHWA
Frigidaire TGF324BHWB
Tappan TGF324BHWC Tappan/range
Tappan TGF324BHWD Tappan/gas Range
Tappan TGF324BHWE Tappan/gas Range
Tappan TGF324WHSD Tappan/gas Range
Tappan TGF326WHSD Tappan/gas Range
Tappan TGF326WHSE Tappan/gas Range
Tappan TGF326WHTD Tappan/gas Range
Tappan TGF326WHTE Tappan/gas Range
Frigidaire TGF330WCDA Tap(v1) / Gas Range
Frigidaire TGF330WCDB Tap(v1) / Gas Range
Frigidaire TGF330WCDC Tap(v1) / Gas Range
Frigidaire TGF330WCDD Tap(v1) / Gas Range
Frigidaire TGF330WCDE Tap(v1) / Gas Range
Frigidaire TGF330WCWA Tap(v2) / Gas Range
Frigidaire TGF330WCWB Tap(v2) / Gas Range
Frigidaire TGF330WCWC Tap(v2) / Gas Range
Frigidaire TGF330WCWD Tap(v2) / Gas Range
Frigidaire TGF330WCWE Tap(v2) / Gas Range
Frigidaire TGF331SCDA Tap(v1) / Gas Range
Frigidaire TGF331SCDB Tap(v1) / Gas Range
Frigidaire TGF331SCDC Tap(v1) / Gas Range
Frigidaire TGF331SCWA Tap(v2) / Gas Range
Frigidaire TGF331SCWB Tap(v2) / Gas Range
Frigidaire TGF331SCWC Tap(v2) / Gas Range
Frigidaire TGF332BCDA Tap(v1) / Gas Range
Frigidaire TGF332BCDB Tap(v1) / Gas Range
Frigidaire TGF332BCDC Tap(v1) / Gas Range
Frigidaire TGF332BCDD Tap(v1) / Gas Range
Frigidaire TGF332BCDE Tap(v1) / Gas Range
Frigidaire TGF332BCWA Tap(v2) / Gas Range
Frigidaire TGF332BCWB Tap(v2) / Gas Range
Frigidaire TGF332BCWC Tap(v2) / Gas Range
Frigidaire TGF332BCWD Tap(v2) / Gas Range
Frigidaire TGF332BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCDA Tap(v1) / Gas Range
Frigidaire TGF334BCDB Tap(v1) / Gas Range
Frigidaire TGF334BCDC Tap(v1) / Gas Range
Frigidaire TGF334BCDD Tap(v2) / Gas Range
Frigidaire TGF334BCDE Tap(v1) / Gas Range
Frigidaire TGF334BCDF Tap(v1) / Gas Range
Frigidaire TGF334BCDG Tap(v1) / Gas Range
Frigidaire TGF334BCDH Tap(v1) / Gas Range
Frigidaire TGF334BCWA Tap(v2) / Gas Range
Frigidaire TGF334BCWB Tap(v2) / Gas Range
Frigidaire TGF334BCWC Tap(v3) / Gas Range
Frigidaire TGF334BCWD Tap(v4) / Gas Range
Frigidaire TGF334BCWE Tap(v2) / Gas Range
Frigidaire TGF334BCWF Tap(v2) / Gas Range
Frigidaire TGF334BCWG Tap(v2) / Gas Range
Frigidaire TGF334BCWH Tap(v2) / Gas Range
Frigidaire TGF334WFSA Tap(v0) / Gas Range
Frigidaire TGF334WFSB Tap(v0) / Gas Range
Frigidaire TGF334WFSC Tap(v0) / Gas Range
Frigidaire TGF334WFSD Tap(v0) / Range
Frigidaire TGF335BCDA Tap(v1) / Gas Range
Frigidaire TGF335BCDB Tap(v1) / Gas Range
Frigidaire TGF335BCDC Tap(v1) / Gas Range
Frigidaire TGF335BCDD Tap(v1) / Gas Range
Frigidaire TGF335BCDE Tap(v1) / Gas Range
Frigidaire TGF335BCWA Tap(v2) / Gas Range
Frigidaire TGF335BCWB Tap(v2) / Gas Range
Frigidaire TGF335BCWC Tap(v2) / Gas Range
Frigidaire TGF335BCWD Tap(v2) / Gas Range
Frigidaire TGF335BCWE Tap(v2) / Gas Range
Frigidaire TGF335CFSA Tap(v1) / Gas Range
Frigidaire TGF335CFTA Tap(v2) / Gas Range
Tappan TGF336ASA Tappan/gas Range
Tappan TGF336ASB Tappan/gas Range
Tappan TGF336ASC Tappan/gas Range
Tappan TGF336ASD Tappan/gas Range
Tappan TGF336ASE Tappan/gas Range
Tappan TGF336ASF Tappan/gas Range
  #2 (permalink)
Old 10-28-2012, 01:52 PM
Junior Member
Default forgot to mention I tested the fuse and removed the vent
I forgot to mention that I also tested the fuse for continuity and it tested fine. I did also jump the fuse and it didn't matter.
  #3 (permalink)
Old 10-29-2012, 12:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the igniter glow?
If it does then the problem very likely is a bad gas valve coils.
- The coil kit Part number: 279834
Part number: 279834
Here are the breakdown diagrams and Parts for Estate TGDS840PQ1 Dryer - AppliancePartsPros.com
P.S. Make sure the dryer exhaust line is clean and the vent hose at the back of the dryer is not kinked and/or twisted.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 10-29-2012, 02:52 PM
Junior Member
Default
Hi Gene,
Thanks for the info. I am at work but will look at that ignitor when I get home. I think it does because I was watching down the back of the dryer for the flame and thought it seemed to get brighter but no flame. Will check to be sure it's not just wishful thinking. Will let you know.
Is there a way I can do a continuity test on those coils to be sure they are bad? I ask because I just replaced them unnecessarily last year when I had a bad thermal cutoff switch. They were only $25 from this site but I couldnt' find my old set. I'd hate to replace them again if I could prove or rule them out with a test.
  #5 (permalink)
Old 10-29-2012, 03:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Remi32 View Post
...Is there a way I can do a continuity test on those coils to be sure they are bad?..
A continuity test does not work good with this coils because very often they could pass it and then fail under the heat stress.
BTW, the price for this kit today is only $15.99 .
__________________
  #6 (permalink)
Old 10-29-2012, 04:08 PM
Junior Member
Default
Just got home and looked through the peephole and the ignitor does NOT glow with the timer on the autosense or timed dry settings. It must have been wishful thinking because I see the ignitor right by the front peephole and I was only looking down the back of the dryer where I usually see the flame reflection.
I forgot to mention that I actually have the vent hose disconnected just to be sure that clogging wasn't an issue.
What should I look at next?
  #7 (permalink)
Old 10-29-2012, 04:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would like to confirm that the igniter does glow on the timed dry.
If it does not now, check for 120 VAC to the igniter.
__________________
  #8 (permalink)
Old 10-29-2012, 09:48 PM
Junior Member
Default
OK...I am confused. The ignitor was NOT glowing. But since you asked to confirm it I went ahead and took everything apart so I could test the 120 volt. I did a continuity test and the ignitor was good. and then even without the gas I tested the 120 volt and it had 122 volts. So I plugged in the ignitor and I'll be danged if it didn't start glowing!
So I stuck everything together and of course it started working just fine!! My concern is that I have something failing intermittently. I'll see how long this lasts but is there something I can test to avoid this from happening again??
  #9 (permalink)
Old 10-30-2012, 02:12 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
One of possibilities is a loose connection somewhere. When you took it apart and assembled it back, you probably fixed it. At least I hope so.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool electric Dryer WED9400SW2 light does not turn off and tumbler will not turn kmuck9 Dryer Repair 0 09-25-2012 06:27 AM
Whirlpool Duet GEW9250PWO Dryer Timer Counts Dwon but Drum Doesn't Turn sjnnn8 Dryer Repair 1 05-29-2012 06:13 PM
Whirlpool duet doesnt heat or turn timer working astarr Dryer Repair 3 11-04-2010 04:30 AM
Timer won't turn off johnanddebbie20 Dryer Repair 1 09-05-2009 01:44 PM
Estate Dryer AutoSense Problem DerbyDad03 Dryer Repair 3 11-17-2008 07:58 PM
