Discuss
GE Dryer - Confirm diagnosis for system shutting off
 in
Dryer Repair
This coin operated dryer shuts off in about 10-20 seconds after a cool start. Once it shuts down it will
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE Dryer - Confirm diagnosis for system shutting off
  #1 (permalink)
Old 10-24-2012, 01:24 PM
Member
venicebeachvillas is on a distinguished road
Question GE Dryer - Confirm diagnosis for system shutting off
Model Number: DMCD330EG0WC   Brand: GE   Age: 5 - 10 years
This coin operated dryer shuts off in about 10-20 seconds after a cool start. Once it shuts down it will initially start but shuts back down. If you wait a minute or two it then runs for 10-20 seconds before shutting down again. While running sometimes I hear a very brief cut out then continues a short period until it shuts down. This happens in the only 3 modes it has, high, low and permanent press. The heater heats each time. All performed without the exhaust hooked up. If you kept the press to start button held down it would continue to run.
I checked to make sure both exhaust and blower inlets were clear.
Checked line voltage.
The drum rotated smoothly in the direction it spins.
Seal between the blower and motor looked good.
The heater coils were clean (no black marks) and the connections appeared in good shape (no measurements were made).
Immediately after it ran for a period with the start button held down I checked continuity on the Safety Thermostat and the Thermal fuse, they both still had continuity. I could not check Thermostat Inlet Blue at the same time after running due lack of access, but later it had continuity as did T/st Outlet(biased) on the blower.
I believe from reading multiple postings with similar issues I need to replace the motor, WE17X10010.
But I am not overly confident.
If the system is really overheating and the Thermostat Inlet Blue or the T/st Outlet(biased) is shutting the system down due to high heat or malfunctioning, could this be the cause??
Can someone knowledgeable please confirm or point me in the right direction.
Thanks for reading this long post (just wanted to be detailed).
-Kevin
Ads By Google
Related Models
General Electric DMCD330EG0WC Electric dryer
General Electric DMCD330GG0WC Gas dryer
Maytag DME15F-9P-P4 Mwave - Cntrtp / Stand Alone
Maytag DME15F-9PP4 Mwave - Cntrtp / Stand Alone
Maytag DME15H-9P-P4 Mwave - Cntrtp / Stand Alone
Maytag DMEA15H-9PP4 Mwave - Cntrtp / Stand Alone
Maytag DMEG15H-9PP4 Mwave - Cntrtp / Stand Alone
Maytag DMEG15HW-9PP4 Mwave - Cntrtp / Stand Alone
Norge DMN15H-14T Mwave - Cntrtp / Stand Alone
Norge DMN15H-5 Mwave - Cntrtp / Stand Alone
Norge DMN15HW-14T Mwave - Cntrtp / Stand Alone
Norge DMN46H-14T Mwave - Cntrtp / Stand Alone
Norge DMN46HW-14T Mwave - Cntrtp / Stand Alone
Amana DMO-560 Mwave - Family Size (60 Hz)
Amana DMO219 Mwave - Cntrtp / Stand Alone
Amana DMO360 Mwave - Family Size (60 Hz)
Amana DMO560 Mwave - Cntrtp / Stand Alone
Amana DMO560B Mwave - Family Size (60 Hz)
Amana DMO660 Mwave - Cntrtp / Stand Alone
Amana DMO660B Mwave - Family Size (60 Hz)
Amana DMO760 Mwave - Cntrtp / Stand Alone
Amana DMO760A Mwave - Family Size (60 Hz)
Frigidaire DMS081U1S0
Frigidaire DMS081U1S1
Frigidaire DMS103T1B1
Frigidaire DMS103T1H1
Maytag DMS46KG-10T Mwave - Cntrtp / Stand Alone
Maytag DMS46KW-10T Mwave - Cntrtp / Stand Alone
Frigidaire DMT103T1W1
Frigidaire DMT113U1B0
Frigidaire DMT113U1B1
General Electric DNCD450EA0WC Electric dryer
General Electric DNCD450EA1WC Electric dryer
General Electric DNCD450GA0WC Gas dryer
General Electric DNCD450GA1WC Gas dryer
General Electric DNCD450GA2WC Gas dryer
General Electric DNCD450GA3WC Gas dryer
General Electric DNCJ440EA0WC Electric dryer
General Electric DNCJ440EA1WC Electric dryer
General Electric DNCJ440GA0WC Gas dryer
General Electric DNCJ440GA1WC Gas dryer
General Electric DNCK440EA0WC Electric dryer
General Electric DNCK440EA1WC Electric dryer
General Electric DNCK440GA0WC Gas dryer
General Electric DNCK440GA1WC Gas dryer
General Electric DNCK440GA2WC Gas dryer
Maytag DNF17AALWH Freezer - Vertical
Maytag DNF17ABLWH Freezer - Vertical
Maytag DNF17ACLWH Freezer - Vertical
Maytag DNF17ACLWHT Freezer - Vertical
Maytag DNF17BCLWHT  Freezer - Vertical
Maytag DNF17H  Freezer - Vertical
Maytag DNF17HX  Freezer - Vertical
Maytag DNF20AJ Freezer - Vertical
Maytag DNF20J Freezer - Vertical
Maytag DNF20JA Freezer - Vertical
Maytag DNF20JW Freezer - Vertical
Admiral DNS22F9 Ref - SXS/I&W
Admiral DNS22F9A Ref - SXS/I&W
Admiral DNS22F9H Ref - SXS/I&W
Admiral DNS22H9 Ref - SXS/I&W
Admiral DNS22H9A Ref - SXS/I&W
Admiral DNS22H9H Ref - SXS/I&W
Admiral DNS24F9 Ref - SXS/I&W
Admiral DNS24F9A Ref - SXS/I&W
Admiral DNS24F9H Ref - SXS/I&W
Admiral DNS24H9 Ref - SXS/I&W
Admiral DNS24H9A Ref - SXS/I&W
Admiral DNS24H9H Ref - SXS/I&W
Admiral DNS24H9W Ref - SXS/I&W
General Electric DNSB514EB0CC Electric dryer
General Electric DNSB514GB0CC Gas dryer
General Electric DNSR473EV0AA Electric dryer
General Electric DNSR473EV0WW Electric dryer
General Electric DNSR473EW0AA Electric dryer
General Electric DNSR473EW0WW Electric dryer
General Electric DNSR473EW1AA Electric dryer
General Electric DNSR473EW1WW Electric dryer
General Electric DNSR473EW2AA Electric dryer
General Electric DNSR473EW2WW Electric dryer
General Electric DNSR473GV0AA Gas dryer
General Electric DNSR473GV0WW Gas dryer
General Electric DNSR473GW0AA Gas dryer
General Electric DNSR473GW0WW Gas dryer
General Electric DNSR473GW1AA Gas dryer
General Electric DNSR473GW1WW Gas dryer
General Electric DNSR473GW2AA Gas dryer
General Electric DNSR473GW2WW Gas dryer
General Electric DNSR473GW3AA Gas dryer
General Electric DNSR473GW3WW Gas dryer
General Electric DNSR475EY0AA Electric dryer
General Electric DNSR475EY0WW Electric dryer
General Electric DNSR475EY1AA Electric dryer
General Electric DNSR475EY1WW Electric dryer
General Electric DNSR475EY2AA Electric dryer
General Electric DNSR475EY2WW Electric dryer
General Electric DNSR475GY0AA Gas dryer
General Electric DNSR475GY0WW Gas dryer
General Electric DNSR475GY1AA Gas dryer
General Electric DNSR475GY1WW Gas dryer
General Electric DNSR475GY2AA Gas dryer
General Electric DNSR475GY2WW Gas dryer
General Electric DNSR475GY3AA Gas dryer
General Electric DNSR475GY3WW Gas dryer
Admiral DNT18F9 Ref - Top Mount/ I&W
Admiral DNT18F9A Ref - Top Mount/ I&W
  #2 (permalink)
Old 10-31-2012, 01:53 AM
Member
Default
Since no one has replied, I went ahead and replaced the motor. The problem still exists, only it shuts down immediately cold or hot every time.
Any idea's ???????????????????????????
  #3 (permalink)
Old 11-01-2012, 02:42 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I am not the above but will give you what I know and perhaps it will help.
You said earlier "Immediately after it ran for a period with the start button held down" does this mean that the unit runs OK if you hold the start button down?
If yes then I would look at the belt/idler switch.
I am doing some guessing here as GE likes to keep all tech data a secret and I do not have access to it. But I did find a general wiring diagram (See below link) for a GE and it shows that the start switch is wired in parallel with the belt/idler switch which will kill power to the unit's motor.
Could be the switch itself or that the belt has a problem or the idler is bouncing around too much.
http://www.applianceaid.com/images/g...ec-diagram.JPG
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not shutting off JHS421 Dryer Repair 0 03-17-2011 08:11 PM
Need Kenmore 110.87980100 Dryer Diagnosis Help, Tried reasonable tests MikeInMA Dryer Repair 5 01-10-2011 08:41 AM
Please confirm...dryer will not start CarolineB Dryer Repair 0 03-22-2010 09:37 AM
dryer not shutting off mijllc Dryer Repair 1 01-29-2008 12:43 PM
dryer keeps shutting off marqitos06 Dryer Repair 1 08-04-2007 07:49 PM
