Discuss
Kenmore gas dryer, no heat
 in
Dryer Repair
I have a Kenmore gas dryer, model 110.79522800 that stopped heating. Drum motor runs fine. Have checked the following: •
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore gas dryer, no heat
  #1 (permalink)
Old 10-24-2012, 06:42 AM
Junior Member
coloradonate is on a distinguished road
Default Kenmore gas dryer, no heat
Model Number: 110.79522800   Brand: Kenmore   Age: 1 - 5 years
• Igniter (has no visible flaws, reads 65 Ohms)
• Radiant flame sensor (has continuity, resistance ~0 Ohm)
• Gas valve solenoid coil with 2 wires (will call this the 2-wire coil):
--> Resistance ~1220 Ohm
• Gas valve solenoid coil with 3 wires (will call this the 3-wire coil):
--> Resistance ~1365 Ohm between Black and Blue
--> Resistance ~560 Ohm between Black and White
(Resistance values that I have stated for solenoid coils are approximate as I didn’t write them down, but they were very close to the values listed for reference on the wire diagrams found online…can redo and report exact results if necessary)
All of the info below pertains to initiating a dryer cycle on Automatic, High Heat:
There is no glow on the igniter. I shorted out the leads running to the flame sensor to take it out of the equation. Still no glow on the igniter. Removed the plug going to the igniter and measured voltage, getting only 17 Volts. Removed both plugs going to the solenoid coils and measured voltage at the igniter, getting 120 Volts. Plugged the solenoid coils back in, one by one. With the 2-wire coil plug back in place (3-wire coil plug removed), the voltage to the igniter remains at 120 V. With the 3-wire coil plug in place (and 2-wire coil plug removed), the voltage to the igniter is back to 17 V.
I now have a scenario where I can obtain 120 V to the igniter. So I installed the igniter plug back into the igniter. Left both solenoid coils unplugged and left the flame sensor shorted out (as stated above, this provided 120 V to the igniter.) Turned it on and still received no glow to the igniter. This appears to point to a bad igniter, but before I go buying parts, I need to understand why the igniter voltage reads 17 V when the solenoid coils are wired into the circuit. This concerns me, and makes me think that it’s either not the igniter, or it’s more than just the igniter. Please help…where is my logic going wrong?? Is it ONLY the igniter? Why would the igniter resistance show 65 Ohm if it's bad?
Additional info: I have admittedly not checked the thermal fuse, operating thermostat, or hi limit thermostat (tight quarters and limited time), but since they are wired in series coming from Line voltage, I believe they must be okay if I was reading 120 V at the igniter. There should be no way to read 120 V at the igniter in any scenario if ANY of those components do not have continuity…correct? Additionally, in the scenario whereby I can obtain 120 V at the igniter (i.e., flame sensor leads shorted out, both solenoid coil plugs removed), I ran through all the cycles on the control panel, and receive 120 V during Automatic High Heat, Automatic Low Heat (e.g., delicates), and even Air fluff (which I believe should have no heat), but was getting 0 V when on Timed High Heat. Does this imply the timer may be related to the malfunction?
Sorry for the mass amount of info, hope somebody can make sense of this and help! Thanks in advance. ~Nate
Ads By Google
Related Models
Kenmore 110.82182200  COMPACT ELECTRIC DRYER
Kenmore 110.82722200  COMPACT ELECTRIC DRYER
Kenmore 110.82822100  ELECTRIC DRYER
Kenmore 110.82822101  ELECTRIC DRYER
Kenmore 110.82822102  ELECTRIC DRYER
Kenmore 110.82824100  ELECTRIC DRYER
Kenmore 110.82824101  ELECTRIC DRYER
Kenmore 110.82824102  ELECTRIC DRYER
Kenmore 110.82826100  ELECTRIC DRYER
Kenmore 110.82826101  ELECTRIC DRYER
Kenmore 110.82826102  ELECTRIC DRYER
Kenmore 110.82832100  DRYER
Kenmore 110.82834100  DRYER
Kenmore 110.82836100  DRYER
Kenmore 110.83679630  ELECTRIC DRYER
Kenmore 110.84832200  ELECTRIC DRYER
Kenmore 110.84832201  ELECTRIC DRYER
Kenmore 110.84834200  ELECTRIC DRYER
Kenmore 110.84834201  ELECTRIC DRYER
Kenmore 110.84836200  ELECTRIC DRYER
Kenmore 110.84836201  ELECTRIC DRYER
Kenmore 110.86015100  ELECTRIC DRYER
Kenmore 110.86015110  ELECTRIC DRYER
Kenmore 110.86015120  ELECTRIC DRYER
Kenmore 110.86030100  ELECTRIC DRYER
Kenmore 110.86030110  ELECTRIC DRYER
Kenmore 110.86030120  ELECTRIC DRYER
Kenmore 110.86070100  ELECTRIC DRYER
Kenmore 110.86070110  ELECTRIC DRYER
Kenmore 110.86405160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86405860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407140  ELECTRIC DRYER
Kenmore 110.86407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407840  ELECTRIC DRYER
Kenmore 110.86407860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off poslow Dryer Repair 2 11-21-2010 10:10 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Kenmore dryer will not heat vikingboy Dryer Repair 3 09-27-2009 02:00 PM
Kenmore dryer will not heat lpennock Dryer Repair 2 05-11-2009 06:19 AM
Kenmore dryer ~No heat `and more cassjo Dryer Repair 1 01-15-2008 04:14 PM
