Discuss
Whirlpool dryer will not shut off after new timer replacement
 in
Dryer Repair
Wife was complaining again about dryer not shutting off. I've replaced the timer about a year ago so I ordered
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool dryer will not shut off after new timer replacement
  #1 (permalink)
Old 10-23-2012, 05:23 PM
Junior Member
grayfeathers is on a distinguished road
Default Whirlpool dryer will not shut off after new timer replacement
Model Number: LEN3624BWO   Brand: Whirlpool   Age: 1 - 5 years
Wife was complaining again about dryer not shutting off. I've replaced the timer about a year ago so I ordered another timer. Timer works until nearly time to shut off then timer stops working. What else would cause the timer to stop working?
Thanks in advance.
Ads By Google
Related Models
Whirlpool LEN3634DW0
Whirlpool LEN3634DW1
Whirlpool LEP6646AN0
Whirlpool LEP6646AN1
Whirlpool LEP6646AN2
Whirlpool LEP6646AW0
Whirlpool LEP6646AW1
Whirlpool LEP6646AW2
Whirlpool LEP6848AN0
Whirlpool LEP6848AN1
Whirlpool LEP6848AN2
Whirlpool LEP6848AW0
Whirlpool LEP6848AW1
Whirlpool LEP6848AW2
Whirlpool LEP7858AN0
Whirlpool LEP7858AN1
Whirlpool LEP7858AN2
Whirlpool LEP7858AQ2
Whirlpool LEP7858AW0
Whirlpool LEP7858AW1
Whirlpool LEP7858AW2
Whirlpool LEP7858AZ2
Frigidaire LEQ1442ES0 Frigidaire/dryer
Frigidaire LEQ2152EE0 Frigidaire/dryer
Frigidaire LEQ2152ES0 Frigidaire/electric Dryer
Frigidaire LEQ332DS0 Frigidaire/dryer
Whirlpool LEQ5000KQ0
Whirlpool LEQ5000KQ1 29"electric Dryer
Whirlpool LEQ5000KQ2 29"electric Dryer
Whirlpool LEQ5000KW1 29"electric Dryer
Whirlpool LEQ5000KW2 29"electric Dryer
Whirlpool LEQ5000PW0 29"electric Dryer
Frigidaire LEQ6000ES0 Frigidaire/dryer
Frigidaire LEQ6000ES1 Frigidaire/dryer
Frigidaire LEQ6000ES2 Frigidaire/electric Dryer
Frigidaire LEQ642DS0 Frigidaire/dryer
Frigidaire LEQ7000EG0 Frigidaire/dryer
Frigidaire LEQ7000ES0 Frigidaire/dryer
Frigidaire LEQ7000ES1 Frigidaire/dryer
Frigidaire LEQ7000ES2 Frigidaire/dryer
Whirlpool LEQ7000KQ0
Whirlpool LEQ7000KQ1
Whirlpool LEQ7000KQ2
Whirlpool LEQ7030KQ0
Whirlpool LEQ7030KQ1
Whirlpool LEQ7030KQ2 29"electric Dryer
Whirlpool LEQ8000HQ0
Whirlpool LEQ8000HQ1
Whirlpool LEQ8000JQ0
Whirlpool LEQ8000JQ1
Whirlpool LEQ8000JQ2
Whirlpool LEQ8000JQ3 29"electric Dryer
Whirlpool LEQ8000JQ4 Electric Dryer
Whirlpool LEQ8100KQ0
Whirlpool LEQ8100KQ1
Whirlpool LEQ8100KT0
Whirlpool LEQ8100KT1
Whirlpool LEQ8611LG0
Whirlpool LEQ8611LG1 27"electric Dryer
Whirlpool LEQ8611LW0
Whirlpool LEQ8611LW1 27"electric Dryer
Whirlpool LEQ8611PG0 27" Electric Dryer
Whirlpool LEQ8611PG1 27"electric Dryer
Whirlpool LEQ8611PG2 27"electric Dryer
Whirlpool LEQ8611PW0 27" Electric Dryer
Whirlpool LEQ8611PW1 27"electric Dryer
Whirlpool LEQ8611PW2 27"electric Dryer
Whirlpool LEQ8621PG0 27" Electric Dryer
Whirlpool LEQ8621PG1 27"electric Dryer
Whirlpool LEQ8621PG2 27"electric Dryer
Whirlpool LEQ8621PW0 27" Electric Dryer
Whirlpool LEQ8621PW1 27"electric Dryer
Whirlpool LEQ8621PW2 27"electric Dryer
Whirlpool LEQ8800JQ0
Whirlpool LEQ8800JQ1
Whirlpool LEQ8800JT0
Whirlpool LEQ8800JT1
Whirlpool LEQ8857HQ0
Whirlpool LEQ8857HQ1
Whirlpool LEQ8857HZ0
Whirlpool LEQ8857HZ1
Whirlpool LEQ8857JQ0
Whirlpool LEQ8857JQ1
Whirlpool LEQ8857JT0
Whirlpool LEQ8857JT1
Whirlpool LEQ8858HQ0
Whirlpool LEQ8858HQ1
Whirlpool LEQ8858HZ0
Whirlpool LEQ8858HZ1
Whirlpool LEQ8858JQ0
Whirlpool LEQ8858JQ1
Whirlpool LEQ8858JT0
Whirlpool LEQ8858JT1
Whirlpool LEQ8858JZ0
Whirlpool LEQ8858JZ1
Whirlpool LEQ9030PQ0 29"electric Dryer
Whirlpool LEQ9030PQ1 29" Electric Dryer
Whirlpool LEQ9508KQ0
Whirlpool LEQ9508LG0
Whirlpool LEQ9508LW0
Whirlpool LEQ9508LW1 29"electric Dryer
Whirlpool LEQ9508PG0 29"electric Dryer
Whirlpool LEQ9508PG1 29" Electric Dryer
Whirlpool LEQ9508PW0 29"electric Dryer
Whirlpool LEQ9508PW1 29" Electric Dryer
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
  #2 (permalink)
Old 10-24-2012, 03:40 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool LEN3624BW0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Does the timer advance in auto modes or only in timed dry?
__________________
  #3 (permalink)
Old 10-24-2012, 05:35 PM
Junior Member
Default
Thanks for the wiring diagram and for your fast response.
The timer works when in timed mode but not in high heat or low heat mode. But, when in timed mode the timer will stop working just after the first click is heard on the timer. If that makes sense. Also, when I say the timer is working, I'm going by the "site glass" in the timer itself. The dryer will not shut off unless I manually turn the knob to the off position.
  #4 (permalink)
Old 10-25-2012, 04:19 AM
Senior Expert
APP Volunteer
Default
Is high and low heat still in timed dry?
Perhaps i should explain how it works, see the wiring diagram.
In timed dry the timer motor gets power through TIMER SWITCH 0, TM/WB contacts. Basically directly from the line (L1 to Neutral)
In auto modes the timer motor gets power through TIMER SWITCH 0, TM/OR contacts. This is through the heating coil when the coil is shut off by a thermostat. The RESISTOR then drops this 240 volt power down to 120 volts for the timer motor.
You will also see in the timer/contact chart if you look at END OF CYCLE that in both timer and auto that the TIMER SWITCH 0 TM/OR contacts drive the timer motor the last little way to off.
So if the timer stalls just before shut off and at the end of it's cycle then you may have a problem with the heating coil.
Unplug the unit and both wires at the heating coil.
Measure the heating coil, should be around 10 ohms.
Then measure from each heater contact to the machine's frame, both should be infinite ohms. Be sure to find bare metal on the frame.
If not infinite then the coil has shorted to the frame/case and should be replaced.
Not sure what this means.
This is just telling you that the timer motor is working not that the timer is working. There could be a problem in the timer where the motor works but the timer does not advance. If the motor is running then the timer should advance.
When I refer to the timer working I am talking about the knob advancing.
__________________
  #5 (permalink)
Old 10-31-2012, 06:48 PM
Junior Member
Default Update
Found heater open which really doesn't make since because the dryer was drying clothes. Anyway, ordered and replaced heater. No change. Timer is still not advancing in the temperature mode but will advance in the timed mode but still will not shut off.
I pulled the dryer back out of it's closet and traced every wire that I could find. I found a part open that has orange wires on each side of it. I took the wiring diagram that you gave me, which I am very thankful for btw, and I assume that this part is a resistor. Part # 15 on the schematic. But, part # 15 on the parts breakdown is not the part that is on my dryer. Can you possible confirm that I'm heading in the right direction. Can I jump this part out?
Thanks.
  #6 (permalink)
Old 11-01-2012, 12:43 AM
Senior Expert
APP Volunteer
Default
Yes I think you are going in the right direction.
I am assuming you used a meter scale that was higher than 5,000 ohms to check it. Otherwise it will read as open (20K on most digital meters).
No you cannot short it out!!!
It is there to drop the 240 heater voltage down to 120 volts for the timer motor.
It looks like the part includes 2 female connectors so you can replace the male connectors with these if required.
__________________
  #7 (permalink)
Old 11-01-2012, 09:31 PM
Junior Member
Default Good deal
Got the part ordered tonight. FYI, I'm using a Fluke Amprobe multi meter. Top of the line.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer timer will not shut off bomack Dryer Repair 1 10-23-2012 04:34 PM
Whirlpool dryer timer replacement kcj4Texas Dryer Repair 0 10-12-2010 08:29 PM
Whirlpool dryer timer advances occasionally, but usually does not shut off lynndicken Dryer Repair 2 08-21-2010 11:30 PM
dryer won't shut off, I replaced timer...still does not shut off. jwd Dryer Repair 0 03-20-2010 04:39 PM
Whirlpool dryer no heat & timer wont shut off lsaustin Dryer Repair 1 06-20-2009 10:47 AM
