| » Please read and help. Dryer won't heat |
What is the complete model number of the dryer?
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Gene, thank you for being so kind to answer. The model is GUSR465GBWW. Same as the only one on youtube. 6.58 minutes, with the guy showing how to check for continuity. I think it's a common, relatively old model. Here's the pic also.
Thank you again |
This dryer is made to use in Canada and there are no any technical data available on line for non American models. Without the correct wiring diagram I can only guess.
The power to the gas part of the dryer (igniter, coils and flame sensor) is coming through the thermostats and fuses from the timer. If there is no power and all thermostats and fuses are fine, then timer should be the culprit. Gene.
__________________
Thank you for the wiring diagram.
Check for continuity between the A & B timer terminals while the timer is in any On position. If it shows no continuity, replace the timer. The part number you can find on the old part. Gene.
__________________
| Display Modes | |
| No Help Yet...Please Read! | kitchenfun | Oven Repair (including Ranges and Cooktops) | 3 | 09-19-2009 05:11 AM |
| Display too dim to read | jsmithee | Oven Repair (including Ranges and Cooktops) | 0 | 04-13-2009 10:38 AM |
| Temp sensor read good Ohms, oven won't heat properly | jaminels | Oven Repair (including Ranges and Cooktops) | 0 | 04-05-2009 09:15 AM |
| Old Caloric oven won't heat and I can't read the model number!!! | jsm115 | Oven Repair (including Ranges and Cooktops) | 1 | 12-15-2008 05:32 PM |
