Discuss
Gas Dryer will not ignite
 in
Dryer Repair
The dryer will not ignite. Is it the valve? Here is what I have done: I observed that when the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer will not ignite
  #1 (permalink)
Old 10-22-2012, 08:51 AM
Junior Member
JoshK is on a distinguished road
Default Gas Dryer will not ignite
Model Number: FSG447GHS0   Brand: Frigidaire   Age: More than 10 years
I observed that when the dryer is started, the igniter glows for approximately 15 seconds and then goes out. There is no flame.
I ohm'd out the solenoid coils. I found the 3-terminal coil showed showed open when it was hot. I replaced both coils. The result is the same -- igniter on, but no flame.
I retested the (new) solenoid coils and they test 1278ohm (2-terminal) and 578ohm / 1378ohm (3-terminal).
I tested the flame sensor. It shows continuity when cold. I shorted its terminals and ran a test. The ignitor stayed on for approximately 50 seconds until I stopped the test.
Other gas appliances in the home are working.
Other than the gas valve, what could it be?
Is there any way to test the gas valve other than replacing it and seeing if the new one solves the problem?
Thank you in advance.
Related Models
Frigidaire FSG447GHS0 Frg(v0) / Dryer
Frigidaire FSG447GHS1 Dryer - Frig Gallery
Frigidaire FSG747GC DRYER
Frigidaire FSG747GCS0 Frg(v0) / Gas Dryer
Frigidaire FSG747GES0 Frg(v0) / Gas Dryer
Frigidaire FSG747GES1 Frg(v0) / Gas Dryer
Frigidaire FSG748GFS0 Frg(v0) / Dryer
Frigidaire FSG748GFS1 Frg(v0) / Stack Dryer
Frigidaire FSG848RHQ0 Frg(v1) / Dryer
Frigidaire FSG848RHS0 Frg(v2) / Dryer
Frigidaire FSG849GHQ1 Dryer - Frigidaire Gallery
Frigidaire FSG849GHS1 Dryer - Frigidaire Gallery
Frigidaire FSGB39RGS0 Frg(v0) / Dryer
Frigidaire FSK190AN5D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190AN5F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190AN5T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190AN5V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190AN5W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190EN0D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190EN0F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190EN0T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190EN0V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190EN0W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190EN1D Kel(v10) / Side By Side Refrigerator
Frigidaire FSK190EN1F Kel(v9) / Side By Side Refrigerator
Frigidaire FSK190EN1T Kel(v8) / Side By Side Refrigerator
Frigidaire FSK190EN1V Kel(v7) / Side By Side Refrigerator
Frigidaire FSK190EN1W Kel(v6) / Side By Side Refrigerator
Frigidaire FSK190EN2D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190EN2F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190EN2T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190EN2V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190EN2W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190EN3D Kel(v5) / Side By Side Refrigerator
Frigidaire FSK190EN3F Kel(v4) / Side By Side Refrigerator
Frigidaire FSK190EN3T Kel(v3) / Side By Side Refrigerator
Frigidaire FSK190EN3V Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190EN3W Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190JN0D Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190JN0W Kel(v2) / Side By Side Refrigerator
Frigidaire FSK190JN1D Kel(v1) / Side By Side Refrigerator
Frigidaire FSK190JN1W Kel(v2) / Side By Side Refrigerator
Amana FSP-10.A COMMERCIAL MICROWAVES
Amana FSP-10.B COMMERCIAL MICROWAVES
Amana FSP-10.C COMMERCIAL MICROWAVES
Amana FSP-10.D COMMERCIAL MICROWAVES
Amana FSP10 COMMERCIAL MICROWAVES
Amana FSP10SS COMMERCIAL MICROWAVES
Amana FSP11 COMMERCIAL MICROWAVES
Menu Master FSP11 COMMERCIAL MICROWAVES
Amana FSP11LW COMMERCIAL MICROWAVES
Amana FSP11SS COMMERCIAL MICROWAVES
Amana FSP700 COMMERCIAL MICROWAVES
Amana FSP8LW COMMERCIAL MICROWAVES
Amana FST130-2D RANGE- S/C S/I DDRAFT GAS
Amana FST136-2D RANGE- S/C S/I DDRAFT GAS
Bosch FT100-060
Frigidaire FTF1040AS0 Frtld Washer - Frigidaire
Frigidaire FTF1240FS0 WASHER
Frigidaire FTF1240FS1 WASHER
Frigidaire FTF1240FS2 WASHER
Frigidaire FTF2140ES0 Frigidaire/washer
Frigidaire FTF2140ES1 Frigidaire/washer
Frigidaire FTF2140ES2 Frigidaire/washer
Frigidaire FTF2140ES3 Frigidaire/washer
Frigidaire FTF2140FE0 WASHER
Frigidaire FTF2140FE1 WASHER
Frigidaire FTF2140FS0 Frigidaire/washer
Frigidaire FTF2140FS1 WASHER
Frigidaire FTF2140FS2 WASHER
Frigidaire FTF5000HS0 WASHER
Frigidaire FTF530ES0 Frigidaire/washer
Frigidaire FTF530ES1 Frigidaire/washer
Frigidaire FTF530FS0 Frigidaire/washer
Frigidaire FTF530FS1 WASHER
Frigidaire FTF530FS2 WASHER
Frigidaire FTF530FS3 WASHER
Frigidaire FTF530FS4 WASHER
Frigidaire FTF630AS0 Frtld Washer - Frigidaire
Frigidaire FTFB2940FE0 Frigidaire/washer
Frigidaire FTFB2940FE1 WASHER
Frigidaire FTFB4000FS0 Frigidaire/washer
Frigidaire FTFB4000FS1 Frigidaire/washer
Frigidaire FTFB4000GS0 Frigidaire/washer
Frigidaire FTFB4000GS1 WASHER
Frigidaire FTHD18P4KB0 REFRIGERATOR
Frigidaire FTHD18P4KB1 REFRIGERATOR
Frigidaire FTHD18P4KB3 REFRIGERATOR
Frigidaire FTHD18P4KB4 REFRIGERATOR
Frigidaire FTHD18P4KW0 REFRIGERATOR
Frigidaire FTHD18P4KW1 REFRIGERATOR
Frigidaire FTHD18P4KW3 REFRIGERATOR
Frigidaire FTHD18P4KW4 REFRIGERATOR
Frigidaire FTMD18P4KB0 REFRIGERATOR
Frigidaire FTMD18P4KB1 REFRIGERATOR
Frigidaire FTMD18P4KB2 REFRIGERATOR
Frigidaire FTMD18P4KB3 REFRIGERATOR
Frigidaire FTMD18P4KB4 REFRIGERATOR
Frigidaire FTMD18P4KB5 REFRIGERATOR
Frigidaire FTMD18P4KB6 REFRIGERATOR
Frigidaire FTMD18P4KW0 REFRIGERATOR
Frigidaire FTMD18P4KW1 REFRIGERATOR
Frigidaire FTMD18P4KW2 REFRIGERATOR
Frigidaire FTMD18P4KW3 REFRIGERATOR
Frigidaire FTMD18P4KW4 REFRIGERATOR
Frigidaire FTMD18P4KW5 REFRIGERATOR
Frigidaire FTMD18P4KW6 REFRIGERATOR
Frigidaire FTMI21P5KB0 REFRIGERATOR
Frigidaire FTMI21P5KW0 REFRIGERATOR
Frigidaire FTR630AS0 Frtld Washer - Frigidaire
Frigidaire FTW3011KW0 WASHER
Frigidaire FTW3014KW0 WASHER
Frigidaire FU017RRW1 Wwh(v2) / Upright Freezer
Frigidaire FU018TRW1 Wwh(v3) / Upright Freezer
Frigidaire FU019ARW5 Wwh(v3) / Upright Freezer
Frigidaire FU054ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU054ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU054ERD3 Wwh(v3) / Upright Freezer
Frigidaire FU054ERW1 Wwh(v4) / Upright Freezer
  #2 (permalink)
Old 10-22-2012, 11:17 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Check if the shot off valve behind the dryer is open.Check if the coils are installed correctly and the insert is inside the double coil.
If it is then the safety gas valve is bad
Part number: 5303207409
You can return any unused parts even installed ones.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-22-2012, 11:25 AM
Junior Member
Default
Yes, the shut-off valve is open.
Yes, I reinstalled the metal insert inside the 3-terminal coil. It appears to only fit in the larger hole bottom side of the coil. Is that correct?
As far as coils being installed correctly, it appears they only go one way -- the dimples on the top of them fit into holes in the bracket that holds down the coils. Also, the offset of the pins in the connectors appear to only allow the electrical connectors to be attached one way.
I understood that the valves rarely fail -- but I suppose if you sell replacement valves they must fail sometimes!
Thank you.
  #4 (permalink)
Old 10-22-2012, 11:37 AM
Expert
Default
Hi.
Replace the safety gas valve.
Simon.
__________________
  #5 (permalink)
Old 10-24-2012, 05:50 AM
Junior Member
Default Gas valve did it
First of all, I'm not sure how you got me the part that fast. I ordered it in the mid-afternoon on Monday, regular shipping. Tuesday morning when I went to take my kids to school at 8am, it had already been delivered!
Replacing the gas valve solved the problem, thank you.
  #6 (permalink)
Old 10-24-2012, 11:40 AM
Expert
Default
Hi.
We are trying our best.
Thank you for using APP.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't ignite; front burners won't ignite SweetMary Oven Repair (including Ranges and Cooktops) 0 07-25-2011 11:32 AM
Gas Dryer Won't Ignite LilPrim Dryer Repair 0 02-15-2011 09:06 AM
Gas dryer won't ignite bahlemeyer Dryer Repair 3 11-22-2010 06:48 AM
Gas Dryer will ignite once, then won't again paryb Dryer Repair 2 02-10-2010 09:59 AM
Dryer will not ignite/dry Kevo Dryer Repair 0 06-21-2008 07:54 AM
