| » Dryer seems to be working but not getting hot |
Model Number: 110.87731700 Brand: Kenmore Age: 1 - 5 years
Tried unplugging it and that didn't work
Hi.
Does it gets warm or no heat at all? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 10-22-2012 at 10:49 AM. |
Hi.
If you have the multimeter proceed with troubleshooting. First check if there is 240VAC to the dryer (if not check the circuit breaker and outlet). Unplug the dryer, remove the toe panel (two screws at the bottom), locate the manual - you may need it. To check continuity remove one wire off every part you are testing. Check continuity of the heating element (7.8-11.8 ohm), thermal cut off, hi limit thermostat. If all of them checks OK - use the manual and run the diagnostic test. The heater Part number: 8544771 The cut off kit Part number: 280148 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
Simon.
__________________
| Display Modes | |
| Dryer panel not working. 2 low amber lights on constant. Light inside working. | tsgibson | Dryer Repair | 1 | 12-28-2011 06:39 AM |
| Kenmore Washer+Dryer, Dryer not working | Sgat8516 | Dryer Repair | 11 | 03-29-2011 03:10 PM |
| dryer not working | joolee123 | Dryer Repair | 0 | 09-18-2010 08:49 AM |
| dryer not working right | Ferrell2008 | Dryer Repair | 0 | 06-07-2009 09:50 AM |
| Dryer not working | lsolen1 | Dryer Repair | 2 | 10-31-2008 05:48 AM |
