| » Gas dryer will not heat |
Model Number: 796.90311900 Brand: Kenmore Age: 1 - 5 years
When I select a cycle, but before starting it, I note that both the DRY and COOLING status indicators are lit. After starting the cycle the DRY indicator blinks and the COOLING indicator stays lit. I never hear the burner light. Dryer was last used yesterday when the wife noted the second load did not seem to dry correctly.
Does this indicate a specific fault, or should I just start down the testing path of flame sensor, igniter, high-limit switch etc? Thanks, PW Ads By Google Related Models |
Hi.
It's sounds like the problem is with the control board. Very unfortunately I can not be more specific due to the limited access to the manuals (LG brand sold By Sears). Open the dryer and check if the manual is there. Or order one from Sears. Run the test. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Simon,
Finally had time to take it apart and test. Findings: Igniter: ~200 ohms Thermostat and high-limit thermostat: ~20 ohms each Gas valve coils: ~1900 ohms each FLAME SENSOR: a big fat OPEN - infinite ohms I noticed when I removed the flame sensor that it rattled. I don't think it should rattle, but I've never shaken one before. OK - off to order a flame sensor. My wife is not happy that a relativey new dryer (about 18 months) already needs to be repaired!!! PW |
Hi.
Congratulation on your success. Keep us posted. Simon.
__________________
| Display Modes | |
| Roper (Gas) Dryer heats up then heat goes off (still running, no heat) | jtdesignsca | Dryer Repair | 3 | 01-17-2013 12:06 PM |
| gas dryer only heats on perm press and low heat, but not on high heat? | GrandCanyonEngineer | Dryer Repair | 0 | 03-02-2011 02:23 PM |
| Kenmore dryer heats on low heat but not on high heat | Mrhollywood334 | Dryer Repair | 0 | 09-11-2010 09:33 PM |
| Dryer stops after a few minutes with heat on - will run continuously with heat off | somegeek | Dryer Repair | 0 | 05-27-2010 01:35 PM |
| Clothes dryer runs, but doest not heat (Dryer no heat | yzhong | Dryer Repair | 5 | 10-29-2009 04:54 PM |
