Discuss
Whirlpool Dryer Bad Heating Element AGAIN
 in
Dryer Repair
Last week my whirlpool dryer model #LEQ9508PWD quit spinning but there was heat. After a lot of research, it turned
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer Bad Heating Element AGAIN
  #1 (permalink)
Old 10-18-2012, 04:11 PM
Junior Member
sunshine1017 is on a distinguished road
Default Whirlpool Dryer Bad Heating Element AGAIN
Model Number: LEQ9508PWD   Brand: Whirlpool   Age: 5 - 10 years
Last week my whirlpool dryer model #LEQ9508PWD quit spinning but there was heat. After a lot of research, it turned out to be a bad thermal fuse. Replaced that and dryer appeared to be working fine. Then today the heating element went out again. I replaced this a year ago. Is there something else I could check that could be causing these other problems? Thanks in advance!
Forgot to add that I noticed the heat turns on when I start the timer, but without hitting the start button.
Ads By Google
Related Models
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
Whirlpool LER2614EW0
Whirlpool LER2614EW1
Whirlpool LER2614EW2
Whirlpool LER2614JQ0
Whirlpool LER2614JQ1
Whirlpool LER2614JQ2 29"electric Dryer
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB Range - S/c F/s Ele
Admiral LER3330AAW Range - S/c F/s Ele
Admiral LER3330AAZ Range - S/c F/s Ele
Whirlpool LER3422AN0
Whirlpool LER3422AW0
Whirlpool LER3424AW0
Whirlpool LER3622BN0
Whirlpool LER3622BW0
Whirlpool LER3622DQ1
Whirlpool LER3622DQ2
Whirlpool LER3622DZ1
Whirlpool LER3622DZ2
Whirlpool LER3622HQ0
Whirlpool LER3622HQ1
Whirlpool LER3622PQ0 Compact Electric Dryer
Whirlpool LER3622PQ1 Compact Electric Dryer
Whirlpool LER3622PQ2 Compact Electric Dryer
Whirlpool LER3624BN2
Whirlpool LER3624BN3
Whirlpool LER3624BW0
Whirlpool LER3624BW1
Whirlpool LER3624BW2
Whirlpool LER3624BW3
Whirlpool LER3624DQ0
Whirlpool LER3624DQ1
Whirlpool LER3624DQ2
Whirlpool LER3624DZ0
Whirlpool LER3624DZ2
Whirlpool LER3624EQ0
Whirlpool LER3624EQ1
Whirlpool LER3624JQ0
Whirlpool LER3624JQ1
Whirlpool LER3624JQ2 29" Electric Dryer
Whirlpool LER3624PQ0 29" Electric Dryer
Whirlpool LER3624PQ1 29" Electric Dryer
Whirlpool LER3634EW0
Whirlpool LER3634EW1
Whirlpool LER3634EW2
Whirlpool LER3634JW0
Whirlpool LER3634JW1
Admiral LER3725AAC Range - S/c F/s Ele
Whirlpool LER4434AN0
Whirlpool LER4434AN1
Whirlpool LER4434AQ0
Whirlpool LER4434AQ1
Whirlpool LER4434AW0
Whirlpool LER4434AW1
Whirlpool LER4436AN0
Whirlpool LER4436AW0
Whirlpool LER4600PQ0 29" Electric Dryer
Whirlpool LER4600PQ1 29" Electric Dryer
Whirlpool LER4624BN0
Whirlpool LER4624BN1
Whirlpool LER4624BN2
Whirlpool LER4624BQ0
Whirlpool LER4624BQ1
Whirlpool LER4624BQ2
Whirlpool LER4624BW0
Whirlpool LER4624BW1
Whirlpool LER4624BW2
Whirlpool LER4624DQ0
Whirlpool LER4624DQ1
Whirlpool LER4624DZ0
Whirlpool LER4624DZ1
Whirlpool LER4634BQ0
Whirlpool LER4634BQ1
Whirlpool LER4634BQ2
Whirlpool LER4634DQ0
Whirlpool LER4634DQ1
Whirlpool LER4634DZ0
Whirlpool LER4634DZ1
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
Whirlpool LER4634JZ0
Whirlpool LER4634PQ0 29" Electric Dryer
  #2 (permalink)
Old 10-18-2012, 07:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by sunshine1017 View Post
...I noticed the heat turns on when I start the timer, but without hitting the start button...
Does it do it now? If yes then unplug the dryer and don't plug it back until it's fixed.
Quote:
... today the heating element went out again...
Can you explain it more detailed please? Did you check the heating element for continuity?
Here are the breakdown diagrams and Parts for Whirlpool LEQ9508PW0 Dryer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-19-2012, 07:47 PM
Junior Member
Default
Last week the dryer was heating, but it would not spin. It was the thermal fuse. Replaced that and when I plugged it back in, it would spin and heat but I noticed that it would heat when the timer was turned, before hitting the start button.
Now, it won't heat at all but it does spin. So I took off the heating element and can plainly see that it is the problem.
  #4 (permalink)
Old 10-19-2012, 08:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very likely the heating element was shorted to the ground. Hopefully the new heating element will fix it. Whirlpool has redesigned this part and possible you will need to order 2 new connecting wires because of the different terminals.
- The heating element Part number: 279838
Part number: 279838
- The connecting wire (order two) Part number: AP3134638
P.S. Click on the heating element part number or picture to watch the installation instructional video.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool cabrio dryer heating element repair bradman67 Dryer Repair 1 03-21-2012 12:47 PM
How do I gain access to the heating element of a whirlpool gold dryer: GEQ8858JT1 lonchaney Dryer Repair 1 11-21-2010 04:22 AM
Whirlpool dryer heating element koala63 Dryer Repair 1 06-25-2010 02:58 PM
Replacing heating element on Whirlpool dryer GEEMAN Dryer Repair 3 11-08-2009 06:20 PM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
