Discuss
Heating Element On Before Motor Spins
 in
Dryer Repair
Recently I notice my Whirlpool Dryer MOD: LEQ9508PW0 turns on the heater element as soon as the timer is set
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Heating Element On Before Motor Spins
  #1 (permalink)
Old 10-18-2012, 01:34 PM
Junior Member
Sh00tnBlanks is on a distinguished road
Default Heating Element On Before Motor Spins
Model Number: LEQ9508PW0   Brand: Whirlpool   Age: 5 - 10 years
Recently I notice my Whirlpool Dryer MOD: LEQ9508PW0 turns on the heater element as soon as the timer is set to anywhere in the run position. On a normal load I would turn the time to 60 mins, open the door and start loading laundry. By the time I get the laundry in, the element is red hot. I then close the door and hit the start button. If I let it cycle through everything goes as it should. However, if I open the door and interrupt the cycle it stops tumbling but the element continues to produce heat.
I broke the dryer down, cleaned out all the lint buildup and did some checks on the motor. With everything disconnected at the motor switch, the red wires (1 & 2) show infinite resistance. If I use my finger to activate the centrifugal switch, the Ohms between the red wires (1 & 2) drop to 0.00.
How is the element heating up without the motor spinning and activating the centrifugal switch? Am I overlooking something simple?
Ads By Google
Related Models
Whirlpool LEQ9508PW0 29"electric Dryer
Whirlpool LEQ9508PW1 29" Electric Dryer
Whirlpool LEQ9557KQ1
Whirlpool LEQ9557KT1
Whirlpool LEQ9558KQ0
Whirlpool LEQ9558KQ1
Whirlpool LEQ9558KT0
Whirlpool LEQ9558KT1
Whirlpool LEQ9857LG0
Whirlpool LEQ9857LG1 29"electric Dryer
Whirlpool LEQ9857LW0
Whirlpool LEQ9857LW1 29"electric Dryer
Whirlpool LEQ9857PW0 29"electric Dryer
Whirlpool LEQ9858LG0
Whirlpool LEQ9858LG1 29"electric Dryer
Whirlpool LEQ9858LW0
Whirlpool LEQ9858LW1 29"electric Dryer
Whirlpool LEQ9858PG0 29"electric Dryer
Whirlpool LEQ9858PG1 29"electric Dryer
Whirlpool LEQ9858PW0 29"electric Dryer
Whirlpool LEQ9858PW1 29"electric Dryer
Whirlpool LEQ9957KQ0
Whirlpool LEQ9957KT0
Admiral LER1115AAW Range - F/s Std Ele
Whirlpool LER2614BW0
Whirlpool LER2614BW1
Whirlpool LER2614BW2
Whirlpool LER2614DW0
Whirlpool LER2614DW1
Whirlpool LER2614EW0
Whirlpool LER2614EW1
Whirlpool LER2614EW2
Whirlpool LER2614JQ0
Whirlpool LER2614JQ1
Whirlpool LER2614JQ2 29"electric Dryer
Frigidaire LER331DS0 Frigidaire/dryer
Admiral LER3330AAB Range - S/c F/s Ele
Admiral LER3330AAW Range - S/c F/s Ele
Admiral LER3330AAZ Range - S/c F/s Ele
Whirlpool LER3422AN0
Whirlpool LER3422AW0
Whirlpool LER3424AW0
Whirlpool LER3622BN0
Whirlpool LER3622BW0
Whirlpool LER3622DQ1
Whirlpool LER3622DQ2
Whirlpool LER3622DZ1
Whirlpool LER3622DZ2
Whirlpool LER3622HQ0
Whirlpool LER3622HQ1
Whirlpool LER3622PQ0 Compact Electric Dryer
Whirlpool LER3622PQ1 Compact Electric Dryer
Whirlpool LER3622PQ2 Compact Electric Dryer
Whirlpool LER3624BN2
Whirlpool LER3624BN3
Whirlpool LER3624BW0
Whirlpool LER3624BW1
Whirlpool LER3624BW2
Whirlpool LER3624BW3
Whirlpool LER3624DQ0
Whirlpool LER3624DQ1
Whirlpool LER3624DQ2
Whirlpool LER3624DZ0
Whirlpool LER3624DZ2
Whirlpool LER3624EQ0
Whirlpool LER3624EQ1
Whirlpool LER3624JQ0
Whirlpool LER3624JQ1
Whirlpool LER3624JQ2 29" Electric Dryer
Whirlpool LER3624PQ0 29" Electric Dryer
Whirlpool LER3624PQ1 29" Electric Dryer
Whirlpool LER3634EW0
Whirlpool LER3634EW1
Whirlpool LER3634EW2
Whirlpool LER3634JW0
Whirlpool LER3634JW1
Admiral LER3725AAC Range - S/c F/s Ele
Whirlpool LER4434AN0
Whirlpool LER4434AN1
Whirlpool LER4434AQ0
Whirlpool LER4434AQ1
Whirlpool LER4434AW0
Whirlpool LER4434AW1
Whirlpool LER4436AN0
Whirlpool LER4436AW0
Whirlpool LER4600PQ0 29" Electric Dryer
Whirlpool LER4600PQ1 29" Electric Dryer
Whirlpool LER4624BN0
Whirlpool LER4624BN1
Whirlpool LER4624BN2
Whirlpool LER4624BQ0
Whirlpool LER4624BQ1
Whirlpool LER4624BQ2
Whirlpool LER4624BW0
Whirlpool LER4624BW1
Whirlpool LER4624BW2
Whirlpool LER4624DQ0
Whirlpool LER4624DQ1
Whirlpool LER4624DZ0
Whirlpool LER4624DZ1
Whirlpool LER4634BQ0
Whirlpool LER4634BQ1
Whirlpool LER4634BQ2
Whirlpool LER4634DQ0
Whirlpool LER4634DQ1
Whirlpool LER4634DZ0
Whirlpool LER4634DZ1
Whirlpool LER4634EQ0
Whirlpool LER4634EQ1
Whirlpool LER4634EQ2
Whirlpool LER4634EW0
Whirlpool LER4634EZ0
Whirlpool LER4634EZ1
Whirlpool LER4634EZ2
Whirlpool LER4634JQ0
Whirlpool LER4634JQ1
Whirlpool LER4634JQ2 29" Electric Dryer
Whirlpool LER4634JT0
Whirlpool LER4634JT1
Whirlpool LER4634JT2 29" Electric Dryer
  #2 (permalink)
Old 10-18-2012, 08:30 PM
Junior Member
Default Update
So I pulled the back off the unit and disconnected the second leg of power at the H2 spade connector on the heating element to see if my symptoms stayed the same. Now that the power wire that comes from the motor switch is completely disconnected, I plugged the unit back into the wall and the element started to heat right up when I turned the dial to run. So, I'd say it's safe to say this has nothing to do with my dryer motor switch. I believe the most likely cause is a short between the element and chasis of the dryer. I'll have to check that in the morning.
  #3 (permalink)
Old 10-19-2012, 02:31 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I agree with you that it sounds like you have a grounded element.
__________________
  #4 (permalink)
Old 10-19-2012, 02:55 AM
Junior Member
leslie rolle is on a distinguished road
Default
I have almost the same problem but my element is not ground out. If. I jump the. Red wire at the motor the element heats up but then remove the jumper its those not work how do i fix this problem
  #5 (permalink)
Old 10-19-2012, 05:42 AM
Senior Expert
APP Volunteer
Default
leslie rolle
Please start your own post using "Post new Topic"
Your problem is very different from this problem.
By the sound of it you have no heat and Sh00tnBlanks has heat all the time
__________________
  #6 (permalink)
Old 10-19-2012, 06:19 AM
Junior Member
Default
Quote:
After confirming the grounded element by using a meter between the terminals on the element and the dryer chasis, I pulled the element off and found the culprit. One of the insulated clips that hold the coil away from the enclosure had broken in half and allowed it to sag. There is a visible spot on the coil about the size of a pencil lead that had been grounding out. I bent the coil back and reinstalled simply for testing purpose. Everything worked perfectly after that. I ordered a new coil this morning. Glad I didn't jump the gun and order a whole new motor like I was thinking yesterday.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Motor spins in low RPM only GeraldBSchmid Washer Repair 2 01-01-2011 07:16 AM
Motor spins - nothing else does! Ace119 Washer Repair 11 11-17-2009 01:57 PM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
bake element not heating but broil element heating okay horno Oven Repair (including Ranges and Cooktops) 1 10-04-2009 11:37 AM
Washer Sometimes Spins, Motor Runs MikeH Washer Repair 1 01-05-2009 07:38 PM
