Discuss
Whirpool Electric Dryer LER7646 won't start
 in
Dryer Repair
Hi, The dryer cut out in the middle of a cycle and I was able to restart it after it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirpool Electric Dryer LER7646 won't start
  #1 (permalink)
Old 09-24-2009, 10:17 AM
Junior Member
defreitasm is on a distinguished road
Default Whirpool Electric Dryer LER7646 won't start
Model Number: LER7646   Brand: Whirlpool   Age: More than 10 years
The dryer cut out in the middle of a cycle and I was able to restart it after it sat for about 15 minutes. I assume it cooled off, I cleaned the duct just in case that was the culprit. It ran OK the rest of the evening, but the next day it shut down in the middle of a load and now it won't start at all.
I set the timer cycles and hear the timer ticking. The start button will make the engagement "click" noise when pressed. The door switch sounds like it's making the click noise to close the circuit ok.
House CBs look OK and since the timer operates I tempted to assume the motor runs off the same leg.
I'm thinking that it can't be the thermal fuse since I was able to get it started once. I called a repair place and explained the situation. He immediately asked me if it was a Whirlpool and said that it sounds like the symptoms of a bad motor. I asked why did he think guess that it was a Whirlpool and he indicated that this is a common symptom and problem. He tolds me I was better off just getting a new dryer. I have one scheduled for delivery on Saturday, but wonder if it is worth tinkering with to determine if it is something else.
Related Models
Whirlpool LER7646AN0 ELECTRIC DRYER
Whirlpool LER7646AN1 ELECTRIC DRYER
Whirlpool LER7646AN2 ELECTRIC DRYER
Whirlpool LER7646AQ0 ELECTRIC DRYER
Whirlpool LER7646AQ1 ELECTRIC DRYER
Whirlpool LER7646AQ2 ELECTRIC DRYER
Whirlpool LER7646AW0 Residential Dryer
Whirlpool LER7646AW1 ELECTRIC DRYER
Whirlpool LER7646AW2 ELECTRIC DRYER
Whirlpool LER7646AZ0 ELECTRIC DRYER
Whirlpool LER7646AZ1 ELECTRIC DRYER
Whirlpool LER7646AZ2 ELECTRIC DRYER
Whirlpool LER7646DQ0 ELECTRIC DRYER
Whirlpool LER7646DQ1 ELECTRIC DRYER
Whirlpool LER7646DW0 ELECTRIC DRYER
Whirlpool LER7646DW1 ELECTRIC DRYER
Whirlpool LER7646DZ0 ELECTRIC DRYER
Whirlpool LER7646DZ1 ELECTRIC DRYER
Whirlpool LER7646EQ0 DRYER
Whirlpool LER7646EQ1 DRYERS
Whirlpool LER7646EQ2 ELECTRIC DRYER
Whirlpool LER7646EZ0 DRYER
Whirlpool LER7646EZ1 DRYERS
Whirlpool LER7646EZ2 ELECTRIC DRYER
Whirlpool LER7646JQ0 DRYER
Whirlpool LER7646JT0 DRYER
Whirlpool LER7648KQ0 RESIDENTIAL DRYER
Whirlpool LER7648KQ1 RESIDENTIAL DRYER
Whirlpool LER7648KQ2 RESIDENTIAL DRYER
Whirlpool LER7648KQ3 29"ELECTRIC DRYER
Whirlpool LER7648KT0 RESIDENTIAL DRYER
Whirlpool LER7648KT1 RESIDENTIAL DRYER
Whirlpool LER7648KT2 RESIDENTIAL DRYER
Whirlpool LER7648KT3 29"ELECTRIC DRYER
Whirlpool LER7648PQ0 29" ELECTRIC DRYER
Whirlpool LER7648PQ1 29" ELECTRIC DRYER
Whirlpool LER7648PT0 29" ELECTRIC DRYER
Whirlpool LER7648PT1 29" ELECTRIC DRYER
Whirlpool LER7848DQ0 ELECTRIC DRYER
Whirlpool LER7848DQ1 ELECTRIC DRYER
Whirlpool LER7848DZ0 ELECTRIC DRYER
Whirlpool LER7848DZ1 ELECTRIC DRYER
Whirlpool LER7858AN1 ELECTRIC DRYER
Whirlpool LER7858AN2 ELECTRIC DRYER
Whirlpool LER7858AW0 Residential Dryer
Whirlpool LER7858AW1 ELECTRIC DRYER
Whirlpool LER7858AW2 ELECTRIC DRYER
Whirlpool LER8620PG0 29"ELECTRIC DRYER
Whirlpool LER8620PG1 29"ELECTRIC DRYER
Whirlpool LER8620PW0 29"ELECTRIC DRYER
Whirlpool LER8620PW1 29"ELECTRIC DRYER
Whirlpool LER8648LG0 RESIDENTIAL DRYER
Whirlpool LER8648LG1 29"ELECTRIC DRYER
Whirlpool LER8648LQ0 RESIDENTIAL DRYER
Whirlpool LER8648LW0 RESIDENTIAL DRYER
Whirlpool LER8648LW1 29"ELECTRIC DRYER
Whirlpool LER8648PG0 29"ELECTRIC DRYER
Whirlpool LER8648PG1 29"ELECTRIC DRYER
Whirlpool LER8648PQ0 29" ELECTRIC DRYER
Whirlpool LER8648PQ1 29"ELECTRIC DRYER
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
  #2 (permalink)
Old 09-24-2009, 02:16 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
You are missing the 3 last digits of the Model Number.
The following info is for a LER7646AN0
Here are the parts
Section replacement parts for WHIRLPOOL LER7646AN0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203401723.pdf
Could be the thermal fuse is blown, Item 23 in Section 3
If the motor was running slow for some reason you have less air flow and this will blow the thermal fuse. There are also other possbilities.
The normal cause of this blowing is a dirty vent system but there are many other causes.
Unplug the unit, remove one wire from the fuse and check it with a meter.
If you do not have a meter you can:
Unplug the unit
Remove the wires from the fuse.
Short them together.
Tape them up so they cannot short to the frame.
And give it a try.
If blown replace ASAP as this is a critical safety device.
If it is the thermal fuse, get back to us and we will try and figure out why the unit shut off by itself (probably a motor overheat) but that can be caused by things other than just a blown motor.
__________________
  #3 (permalink)
Old 09-24-2009, 06:03 PM
Junior Member
Default
I did some trouble shooting before I read your post and it was the thermal fuse. I replaced it and it is working as I type. There was some lint in the accumaltion in the vent hose. I got as much out as I could and will replace the vent over the next two days. I never had completely blocked airflow but assume there was some restriction. I think the link filter may have also blocked some airflow as it had built up residue. I think the residue on the lint filter is from those fabric softener sheets that I tell my wife not to use. I am going to order a new one since the screen is wearing thin around the edges and starting to develop holes. It still puzzles me how the first time it cut out it restarted I believe from cooling off. I'm thinking maybe a resettable overload on the motor maybe but not really sure. I am tempted to say the thermal fuse may not have been fully blown and somehow was able to pass current if that's possible, though unlikely.
One other thing.... back in December, the heater element was replaced and the tech told me it may have been from overheating. Maybe this fuse was fatigued but again it still mystifies me that after the first shutdown it restart.
  #4 (permalink)
Old 09-24-2009, 07:42 PM
Senior Expert
APP Volunteer
Default
Yes, it does sound like the motor's cutout tripped.
Things to check are:
1. That the blower wheel in the unit is clean.
2. That the interior of the dryer especially the motor is lint free.
3. That the drum is rotating OK. Try rotating it by hand, it should rotate fairly easily. It may have too much load on it.
4. That the internal seals in the air flow path are OK. You are actually pulling the air over the heater and through the drum then pushing it out the exhaust. If there is an air leak you pull cooler (room) air through the blower and this is where the cycling thermostat is so the dryer will run hot.
__________________
  #5 (permalink)
Old 09-25-2009, 04:51 AM
Junior Member
Default
The inside of the machine was fairly clean. I didn't check the seals as I was not aware of this potential issue. I'm hoping that it was merely the restricted airflow through the duct and lint filter. That would cause the same symptoms, correct?
  #6 (permalink)
Old 09-25-2009, 06:50 AM
Senior Expert
APP Volunteer
Default
Blowing the thermal fuse for sure.
But the motor overheating no or at least very doubtful.
__________________
  #7 (permalink)
Old 09-25-2009, 06:58 AM
Junior Member
Default
I'm hopefull it is OK as I was able to run the dryer last night for several loads over a period of about 3 hours.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Electric Dryer won't start teachef Dryer Repair 2 10-03-2009 04:11 PM
GE electric dryer will not start qzymfl Dryer Repair 7 07-27-2009 06:21 PM
Electric dryer will not start livergrrl Dryer Repair 1 07-05-2009 07:29 AM
whirpool dryer wont start larb83 Dryer Repair 5 05-25-2009 05:56 PM
Electric dryer will not start kheinrich Dryer Repair 3 08-21-2008 09:22 AM
