Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Dryer does not heat, but runs, all parts seem to be good (http://forum.appliancepartspros.com/dryer-repair/503109-dryer-does-not-heat-but-runs-all-parts-seem-good.html)
discgolfdoug 10-14-2012 09:01 PM
I've replaced the thermal fuse, high and low limit thermostats and heating element. Heated for one load, then shut off breaker, then when breaker was switched back on--no heat again. All parts show continuity.
Any ideas what to try??
denman 10-15-2012 02:18 AM
I cannot find any tech info on the given model number, please check it.
There is info on a 5570.
Need more info.
What was the original problem?
You said "shut off breaker", did you shut it off or did it blow the machine trip the breaker?
When you checked continuity did you get actual resistance (ohm) readings?
Since the breaker shut off I would start by checking the voltage. The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
