GE profile dryer has power but won't start - just chimes like the door is open
Dryer Repair
I have a GE profile dryer that was working fine when one day it just stopped in the middle of
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » GE profile dryer has power but won't start - just chimes like the door is open
  #1 (permalink)
Old 10-14-2012, 12:16 PM
Junior Member
azdhood is on a distinguished road
Default GE profile dryer has power but won't start - just chimes like the door is open
Model Number: DPVH880EJMV   Brand: GE   Age: 1 - 5 years
I have a GE profile dryer that was working fine when one day it just stopped in the middle of a cycle and would not start again. It has full power, but pressing start just chimes like the door is still open. Did some troubleshooting and verified the door switch is good with an ohm meter for continuity. Also verified the fuses are good. Was thinking it might be the power board or control panel. Ran all the self diagnostic tests and all work ok. The blowers come on, the thermistor and thermostat tests all test ok and no error codes. A visual of the control board looks clean, no blown caps or anything else that stands out.
I went through the circuit diagram as it relates to the door switch and found that it connects through to the door light where I found what I believe is the original cause. It looks like a button or coin might have smashed the bulb and temporarily shorted the filament causing some kind of arcing in the bulb housing. It was mostly black and the base of the bulb had an 1/8" hole burned clear through it. I removed the bulb and even cut out the housing but still the same issue. So I believe this goes back to possibly the power board or control board.
The only other item I noticed is a part called the rack dry interlock relay - GE part number WE4M442. This is also within the same circuit as the door switch and drum light bulb. I noticed it when trying to run the dryer set in the rack dry option - still get the same issue - and also when trying to turn on the drum light it makes a fairly noticeable clicking noise. Also, I noticed that with the power off, but the dryer plugged into AC power, this particular relay will become moderately warm within about 15 minutes. I'm not exactly sure what this relay does, but it doesn't look like something that should develop any heat under normal conditions, however this is just a guess from what it looks like. It doesn't get truly hot, but noticeably warm to touch. This could be a goose chase but since it is directly fed between the door switch and drum light bulb, and since it is getting warm and also the noticeable click noise I'm thinking it might be related and possible concern?
I would appreciate any advice on this part if what I'm describing could be related to this relay. The part isn't expensive - only around $30 with shipping but the problem is that it will take 2-3 weeks to get it. Is there any way to test this part to confirm if it is working or not before I order and wait?
Alternately based on what I've described if anyone has any other suggestions I would love to hear them.
In case it is of interest for this topic, or anyone in the future with a similar dryer, I found the following service manual online that has helped a lot:
It is not the exact model but similar and going through it has helped at least to eliminate a good variety of possibilities so far.
Related Models
General Electric DPVH880GJ0MG GAS DRYER
General Electric DPVH880GJ0MV GAS DRYER
General Electric DPVH880GJ0WW GAS DRYER
General Electric DPVH880GJ2MG GAS DRYER
General Electric DPVH880GJ2MV GAS DRYER
General Electric DPVH880GJ2WW GAS DRYER
General Electric DPVH880GJ3MG GAS DRYER
General Electric DPVH880GJ3MV GAS DRYER
General Electric DPVH880GJ3WW GAS DRYER
General Electric DPVH890GJ0MG GAS DRYER
General Electric DPVH890GJ0MV GAS DRYER
General Electric DPVH890GJ0WW GAS DRYER
General Electric DPVH890GJ1MG GAS DRYER
General Electric DPVH890GJ1MV GAS DRYER
General Electric DPVH890GJ1WW GAS DRYER
General Electric DPVH890GJ2MG GAS DRYER
General Electric DPVH890GJ2MV GAS DRYER
General Electric DPVH890GJ2WW GAS DRYER
General Electric DPXB515EB0CC Electric dryer
General Electric DPXB515EB0WW Electric dryer
General Electric DPXB515GB0CC Gas dryer
General Electric DPXB515GB0WW Gas dryer
General Electric DPXH46EA0CC Electric dryer
General Electric DPXH46EA0WW Electric dryer
General Electric DPXH46EA1CC Electric dryer
General Electric DPXH46EA1WW Electric dryer
General Electric DPXH46EA3CC Electric dryer
General Electric DPXH46EA3WW Electric dryer
General Electric DPXH46EF0CC Electric dryer
General Electric DPXH46EF0WW Electric dryer
General Electric DPXH46GA0CC Gas dryer
General Electric DPXH46GA0WW Gas dryer
General Electric DPXH46GA1CC Gas dryer
General Electric DPXH46GA1WW Gas dryer
General Electric DPXH46GA3CC Gas dryer
General Electric DPXH46GA3WW Gas dryer
General Electric DPXH46GA4CC Gas dryer
General Electric DPXH46GA4WW Gas dryer
General Electric DPXH46GA5CC Gas dryer
General Electric DPXH46GA5WW Gas dryer
General Electric DPXH46GA6CC Gas dryer
General Electric DPXH46GA6WW Gas dryer
General Electric DPXH46GF0CC Gas dryer
General Electric DPXH46GF0WW Gas dryer
General Electric DPXQ473ET0AA Electric dryer
General Electric DPXQ473ET0WW Electric dryer
General Electric DPXQ473ET2AA Electric dryer
General Electric DPXQ473ET2WW Electric dryer
General Electric DPXQ473ET3AA Electric dryer
General Electric DPXQ473ET3WW Electric dryer
General Electric DPXQ473ET5AA Electric dryer
General Electric DPXQ473ET5WW Electric dryer
General Electric DPXQ473ET6AA Electric dryer
General Electric DPXQ473ET6WW Electric dryer
General Electric DPXQ473GT0AA Gas dryer
General Electric DPXQ473GT0WW Gas dryer
General Electric DPXQ473GT2AA Gas dryer
General Electric DPXQ473GT2WW Gas dryer
General Electric DPXQ473GT3AA Gas dryer
General Electric DPXQ473GT3WW Gas dryer
General Electric DPXQ473GT5AA Gas dryer
General Electric DPXQ473GT5WW Gas dryer
General Electric DPXQ473GT6AA Gas dryer
General Electric DPXQ473GT6WW Gas dryer
General Electric DPXR473EW0AA Electric dryer
General Electric DPXR473EW0WW Electric dryer
General Electric DPXR473EW1AA Electric dryer
General Electric DPXR473EW1WW Electric dryer
General Electric DPXR473GW0AA Gas dryer
General Electric DPXR473GW0WW Gas dryer
General Electric DPXR473GW1AA Gas dryer
General Electric DPXR473GW1WW Gas dryer
General Electric DPXR475EW0AA Electric dryer
General Electric DPXR475EW0WW Electric dryer
General Electric DPXR475EW1AA Electric dryer
General Electric DPXR475EW1WW Electric dryer
General Electric DPXR475GW0AA Gas dryer
General Electric DPXR475GW0WW Gas dryer
General Electric DPXR475GW1AA Gas dryer
General Electric DPXR475GW1WW Gas dryer
General Electric DPXR483EA0AA Electric dryer
General Electric DPXR483EA0WW Electric dryer
General Electric DPXR483EA1AA Electric dryer
General Electric DPXR483EA1WW Electric dryer
General Electric DPXR483GA0AA Gas dryer
General Electric DPXR483GA0WW Gas dryer
General Electric DPXR483GA1AA Gas dryer
General Electric DPXR483GA1WW Gas dryer
General Electric DPXR483GA2AA Gas dryer
General Electric DPXR483GA2WW Gas dryer
General Electric DQSR483EE0CC Electric dryer
General Electric DQSR483EE0WW Electric dryer
General Electric DQSR483EE1CC Electric dryer
General Electric DQSR483EE1WW Electric dryer
General Electric DQSR483EG0WW Electric dryer
General Electric DQSR483GE0CC Gas dryer
General Electric DQSR483GE0WW Gas dryer
General Electric DQSR483GE1CC Gas dryer
General Electric DQSR483GE1WW Gas dryer
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Profile turns on when I open door - again! claudiadefries Microwave Repair 10 10-23-2012 11:21 AM
dryer doesnt start, only chimes jgold Dryer Repair 1 12-16-2011 02:28 PM
Dryer "Door Open" light on so won't start amyrausch38 Dryer Repair 0 07-30-2011 05:48 AM
GE profile turn on when I open door - again! claudiadefries Microwave Repair 0 11-12-2009 07:26 AM
GE Profile Dishwasher door falls open quickly baltija Dishwasher Repair 3 02-15-2009 12:00 PM
