Discuss
Dryer belt breaking
 in
Dryer Repair
Tried to replace belt. Old belt was shredded--shows signs of overheating. The blue plastic spacer between the motor pulley and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer belt breaking
  #1 (permalink)
Old 10-13-2012, 10:59 AM
Junior Member
weegiebomber is on a distinguished road
Unhappy Dryer belt breaking
Model Number: MDE9606AYW   Brand: Maytag   Age: 5 - 10 years
Tried to replace belt. Old belt was shredded--shows signs of overheating. The blue plastic spacer between the motor pulley and motor housing was melted and fell off the motor shaft The blue spacer cannot be purchased, would have to buy new motor assembly! Ouch ($135)--it's a 25 cent part. I'm not sure of function of spacer, is it to keep the belt from jumping off the pulley? Made another spacer (wood--2 piece--same dimensions as original spacer), put the spacer on the shaft and installed new belt. After less than 2 weeks new belt failed, shows signs of heating. Spacer I made is still intact on motor shaft.
When belt is installed per diagram (ribs/grooves facing away from drum), the flat part of the belt is against the grooves on the motor pulley. You can see that the grooves on the pulley cut into the belt. I'm confused--seems like the grooves on the belt should line up with grooves on the pulley and this would keep the belt from jumping off
Questions: The belt seems to be jumping off the pulley--originally it must have jumped off and wrapped itself around the shaft long enough to create friction to melt the blue plastic spacer. Maybe this happened again?
Does anyone have experience with this problem? Not willing to spend another $25 for a belt since it has failed twice now.
Question #2: Did I install the belt correctly, does the flat part really align against the sharp pulley grooves?
Ads By Google
Related Models
Maytag MDE9606AYW Dryer - Ele
Maytag MDE9606AZA Dryer - Ele
Maytag MDE9606AZQ Dryer - Ele
Maytag MDE9606AZW Dryer - Ele
Maytag MDE9700AYM Dryer - Ele
Maytag MDE9700AYQ Dryer - Ele
Maytag MDE9700AYW Dryer - Ele
Maytag MDE9700AZM Dryer - Ele
Maytag MDE9700AZW Dryer - Ele
Maytag MDE9706AYA Dryer - Ele
Maytag MDE9706AYW Dryer - Ele
Maytag MDE9706AZW Dryer - Ele
Maytag MDE9766AYW Dryer - Ele
Maytag MDE9766AZW Dryer - Ele
Maytag MDE9800AYQ Dryer - Ele
Maytag MDE9800AYW Dryer - Ele
Maytag MDE9800AZQ Dryer - Ele
Maytag MDE9800AZW Dryer - Ele
Maytag MDE9806AYA Dryer - Ele
Maytag MDE9806AYW Dryer - Ele
Maytag MDE9806AZW Dryer - Ele
Maytag MDE9876AYW Dryer - Ele
Maytag MDET236AYW Dryer - Ele
Maytag MDET236AZW Dryer - Ele
Maytag MDET336AYW Dryer - Ele
Maytag MDET336AZW Dryer - Ele
Maytag MDET446AYW Dryer - Ele
Maytag MDET446AZW Dryer - Ele
Maytag MDG100PN1 Dryer - Gas
Maytag MDG100PN1L Dryer - Gas
Maytag MDG100PN1W Dryer - Gas
Maytag MDG10CSAAL Dryer - Gas
Maytag MDG10CSAAW Dryer - Gas
Maytag MDG10CSABL Dryer - Gas
Maytag MDG10CSABW Dryer - Gas
Maytag MDG10CSAGL Dryer - Gas
Maytag MDG10CSAGW Dryer - Gas
Maytag MDG10CSAKL Dryer - Gas
Maytag MDG10CSEGL Dryer - Gas
Maytag MDG10CSEGW Dryer - Gas
Maytag MDG10DAAAL Dryer - Gas
Maytag MDG10DAAAW Dryer - Gas
Maytag MDG10DAABL Dryer - Gas
Maytag MDG10DAABW Dryer - Gas
Maytag MDG10MNAAW Dryer - Gas
International MDG10MNAGW Dryer - Gas
Maytag MDG10MNEGW Dryer - Gas
Maytag MDG10PDAAL Dryer - Gas
Maytag MDG10PDAAW Dryer - Gas
Maytag MDG10PDABL Dryer - Gas
Maytag MDG10PDABW Dryer - Gas
Maytag MDG10PDEGL Dryer - Gas
Maytag MDG10PDEGW Dryer - Gas
Maytag MDG10PRAAW Dryer - Gas
Maytag MDG10PSABW Dryer - Gas
Maytag MDG10PSAGL Dryer - Ele
Maytag MDG10PSAGW Dryer - Ele
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL Dryer - Gas
Maytag MDG11CSAAW Dryer - Gas
Maytag MDG11CSABW Dryer - Gas
Maytag MDG11CSAGL Dryer - Gas
Maytag MDG11CSAGW Dryer - Gas
Maytag MDG11CSEGL Dryer - Gas
Maytag MDG11CSEGW Dryer - Gas
Maytag MDG11MNAAW Dryer - Gas
Maytag MDG11MNAGW Dryer - Gas
Maytag MDG11MNEGW Dryer - Gas
Maytag MDG11PDAAL Dryer - Gas
Maytag MDG11PDAAW Dryer - Gas
Maytag MDG11PDABL Dryer - Gas
Maytag MDG11PDABW Dryer - Gas
Maytag MDG11PDAGL Dryer - Gas
Maytag MDG11PDAGW Dryer - Gas
Maytag MDG11PDEGL Dryer - Gas
Maytag MDG11PDEGW Dryer - Gas
Maytag MDG120P1HW Dryer - Gas
Maytag MDG120PHVW Dryer - Gas
Maytag MDG12CSAAL Dryer - Gas
Maytag MDG12CSAAW Dryer - Gas
Maytag MDG12CSABL Dryer - Gas
Maytag MDG12CSABW Dryer - Gas
Maytag MDG12CSAGW Dryer - Gas
Maytag MDG12CSEGW Dryer - Gas
Maytag MDG12MNAAW Dryer - Gas
Maytag MDG12MNAGW Dryer - Gas
Maytag MDG12MNEGW Dryer - Gas
Maytag MDG12PDAAL Dryer - Gas
Maytag MDG12PDAAW Dryer - Gas
Maytag MDG12PDABL Dryer - Gas
Maytag MDG12PDABW Dryer - Gas
Maytag MDG12PDBAL Dryer - Gas
Maytag MDG12PDBAW Dryer - Gas
Maytag MDG12PDBBL Dryer - Gas
Maytag MDG12PDBBW Dryer - Gas
Maytag MDG12PRAAW Dryer - Gas
Maytag MDG12PRBAW Dryer - Gas
Maytag MDG12PRBBW Dryer - Gas
Maytag MDG12PSABW Dryer - Gas
Maytag MDG12PSAGW Dryer - Gas
Maytag MDG12PSBAW Dryer - Gas
Maytag MDG12PSBBW Dryer - Gas
Maytag MDG13CSAAL Dryer - Gas
Maytag MDG13CSAAW Dryer - Gas
Maytag MDG13CSABW Dryer - Gas
Maytag MDG13CSAGW Dryer - Gas
Maytag MDG13CSAKL Dryer - Gas
Maytag MDG13CSEGW Dryer - Gas
Maytag MDG13MNAAW Dryer - Gas
Maytag MDG13PDAAL Dryer - Gas
Maytag MDG13PDAAW Dryer - Gas
Maytag MDG13PDABL Dryer - Gas
Maytag MDG13PDABW Dryer - Gas
Maytag MDG13PDAGW Dryer - Gas
Maytag MDG13PDBAL Dryer - Gas
Maytag MDG13PDBAW Dryer - Gas
Maytag MDG13PDBBL Dryer - Gas
Maytag MDG13PDBBW Dryer - Gas
Maytag MDG13PDEGW Dryer - Gas
Reply
« darn dryer | dryer »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice Bin Auger/Fins breaking off freddyrod Refrigerator & Freezer Repair 0 02-15-2012 09:06 AM
Ice tray keeps breaking cameron tobey Refrigerator & Freezer Repair 0 09-07-2009 08:51 AM
Ice Stripper Keeps Jamming Breaking keburlingame@hotmail.com Refrigerator & Freezer Repair 0 07-31-2009 07:12 PM
water valve breaking jimfish2391 Refrigerator & Freezer Repair 1 05-18-2009 11:35 AM
Thermal Cut Off Keeps Breaking wbuc Dryer Repair 1 02-29-2008 01:04 PM
