Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   wont start help (http://forum.appliancepartspros.com/dryer-repair/502840-wont-start-help.html)
d9levi 10-11-2012 07:09 PM
wont start help
I put money in and the light comes on and when you push the start button nothing happens
denman 10-12-2012 02:59 PM
1 Attachment(s)
Parts for CEM2760TQO - AppliancePartsPros.com
Could be a number of things;
1. Thermal fuse. if this is open also check/clean your vent system as that is the most common cause of it blowing.
2. Broken belt. Unit has a belt switch that opens when the belt breaks.
3. Door switch not closing.
4. Push To Start switch not closing.
There could be other causes but the above are at the top of the list.
