| » Roper Element replacement |
Model Number: RES7648EQ2 Brand: Roper Age: 5 - 10 years
Hey, guys. My Roper, Model RES7648EQ2 just stopped heating up. Should I just assume that it's the heating element, and can you point me in the direction of a good troubleshooting/walkthrough?
Thanks so much in advance. Ads By Google Related Models |
Well, I tested the thermal fuse, which was fine, and my element had read 9 on the losest setting of resistance. My high-level thermostat is fine, too. I guess I'll check the cycling thermostat, but I don't like the way this is going...
Have you checked if there is 240VAC to the dryer?
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
Simon.
__________________
Hi.
Here what you need to do: - with dryer turned to heat check if there is 240VAC across the heating element (if yes - replace it) - with unit unplugged check continuity of the thermal cutoff, operating thermostat, hi-limit thermostat (replace if needed). -with unit unplugged open the control panel, set the timer to Timed-regular and check continuity TM-OR,BK-R,T-W. - If everything checks out OK then most likely the motor switch contacts 1M-2M not closing. Here are the breakdown diagrams and Bulkhead parts for Roper RES7648EQ2 - AppliancePartsPros.com Post the results. Simon.
__________________
| Display Modes | |
| Heating Element on Roper Dryer won't heat up | c grass | Dryer Repair | 3 | 11-24-2010 04:34 AM |
| Roper Dryer belt Replacement | Dubya_tee | Dryer Repair | 1 | 09-30-2009 06:26 AM |
| Heating Element for Roper Oven | cweber1079 | Oven Repair (including Ranges and Cooktops) | 0 | 09-08-2009 03:59 PM |
| roper drive block replacement | mrkevlar | Washer Repair | 3 | 07-12-2009 06:13 PM |
| Roper range cook top element gets too hot | Dennis11 | Oven Repair (including Ranges and Cooktops) | 2 | 06-24-2009 11:58 PM |
