| » Roper Element replacement |
Model Number: RES7648EQ2 Brand: Roper Age: 5 - 10 years
Hey, guys. My Roper, Model RES7648EQ2 just stopped heating up. Should I just assume that it's the heating element, and can you point me in the direction of a good troubleshooting/walkthrough?
Thanks so much in advance. Ads By Google Related Models |
Hi.
First you need to check if there is 240VAC to the dryer. If yes then unplug it,remove the back panel and using the multimeter check continuity of the: heating element, thermal cut off, high limit, cycling thermostat, thermal fuse. All this checks must be done with one wire off the part. Here are the breakdown diagrams and Bulkhead parts for Roper RES7648EQ2 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Heating Element on Roper Dryer won't heat up | c grass | Dryer Repair | 3 | 11-24-2010 04:34 AM |
| Roper Dryer belt Replacement | Dubya_tee | Dryer Repair | 1 | 09-30-2009 06:26 AM |
| Heating Element for Roper Oven | cweber1079 | Oven Repair (including Ranges and Cooktops) | 0 | 09-08-2009 03:59 PM |
| roper drive block replacement | mrkevlar | Washer Repair | 3 | 07-12-2009 06:13 PM |
| Roper range cook top element gets too hot | Dennis11 | Oven Repair (including Ranges and Cooktops) | 2 | 06-24-2009 11:58 PM |
