Replaced the motor,timer and switch last year. Now it just finished a cycle and won't tumble, but the coils heat up. Set it to air fluff, you can hear the timer but won't tumble on any setting. No motor noise, buzz or anything. What should i check? Thanks
Here are your parts Parts for Maytag DE7500 Dryer - AppliancePartsPros.comThe unit has a thermal fuse (Item 6 in Section 02) on the heater perhaps this is blown. The heating coil should not be able to heat up when the motor is at rest due to one of the centrifugal switches on the motor so check as shown below. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 to 12 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows. The hi-limit should have regulated the temperature so the fuse did not blow. Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device. Just in case it is not a grounded element. With all the below the high limit will also have to be replaced. Check that the belt is OK. Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot. Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow. Check/clean your vent system. Check/clean the blower wheel. If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut) |
THIS FORUM IS DEAD!!!!!!! |
Thanks for your help, great information!
You are welcome.
Would be nice if you could add to the post as what was the actual fix, then when others search for the same problem they will see what actually worked instead of just suggestions. |
