| » dryer problems |
Model Number: lel7646eq1 Brand: Whirlpool Age: 5 - 10 years
my dryer stop heating and i check it it was the heating fuse was open , so i replace it but when i open the heating element was grounded i replace it to and the hi limit came with it as well i replace it , it worked for like a i month and today stop heating opened and the heating fuse was blown again , what you think could be the problem with it? before i go foward please help.
Most likely the dryer was overheated due to clogged exhaust and insufficient air flow.
__________________
Professional appliance repair in Los Angeles, California. |
Did you check the blower and the air ducts inside the dryer?
__________________
Hi Ted,
Post your e-mail, please. Gene.
__________________
If your talking about the fuse in the electrical box,and if you are using two 30 amp fuses in this box,then the trouble is in the electrical box itself. More then likely there is heat building up in the fuse holders causing the fuse to blow.So if you change this box it will solve your problem
__________________
| Display Modes | |
| Dryer problems/questions | jamesb1034 | Dryer Repair | 1 | 04-27-2008 02:50 PM |
| Dryer problems | Charlie1076 | Dryer Repair | 1 | 01-16-2008 02:57 PM |
| Dryer problems | perry1980r | Dryer Repair | 2 | 01-09-2008 06:07 PM |
| Dryer belt problems | Kimberli | Dryer Repair | 1 | 11-12-2007 04:35 PM |
| Dryer Problems | rr454 | Dryer Repair | 4 | 08-09-2007 11:25 PM |
