Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   replace blower wheel (http://forum.appliancepartspros.com/dryer-repair/502592-replace-blower-wheel.html)
Jlski 10-09-2012 01:18 PM
need steps to follow to replace blower wheel. top, front, and drum removed. what next?
Simon / APP Team 10-09-2012 02:11 PM
Hi.
Remove the screw and clamp holding the blower and pull out the blower.
Memories the way the clamp is installed.
Here are the breakdown diagrams and Backsplash, Blower & Motor Assembly parts for GE DWSR405GB1WW - AppliancePartsPros.com
Simon.
Jlski 10-10-2012 08:55 AM
Quote:
Originally Posted by Simon / APP Team (Post 774386)
Hi.
Simon.
actually for this model you need to remove the two screws that hold the motor mount bracket to the base and the two long screws on the front that hold the motor attached blower flange to the blower assembly. Then you can slightly lift and pull the motor assembly with blower wheel attached towards the inside of the dryer. expect a lot of dust which in my case caused pushed the wheel into contact with the front assembly housing and caused the screeching noise.
