dryer
I replaced thermal and high limit switches and they only lasted less than 1 month. I took them both off at the same time,:mad:does anyone know which one goes furthest back when working from the front of the machine???
What are the part numbers of the parts you installed?
Have you cleaned the dryer vent line? If not then it has to be done ASAP. Gene. |
part # 279769 Cleaned completely
Quote:
The high limit thermostat
![]() is first from the front and the thermal cut-off is second. Gene. |
| All times are GMT -7. The time now is 12:15 AM. |
