Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Needed Wiring Diagram (http://forum.appliancepartspros.com/dryer-repair/502389-needed-wiring-diagram.html)
xfixer 10-07-2012 03:53 PM
I have no voltage condition to the ignitor. I need to obtain a wiring diagram for I need to determine the route the current would take from the console, probably through the control board and eventually to the ignitor. I identified the the control panel board on this machine it is appliance parts number AP4319168
If anyone can point me in the direction of which wires leaving the control board feed the ignitor assembly this would definitely assist me in diagnosing this condition.
Thanking you in advance for any assistance you may lend.
Ray
Gene 10-08-2012 04:37 PM
1 Attachment(s)
Hi Ray,
If there is no power to the igniter then you may want to start the troubleshooting from the thermal fuse which is located at the blower housing. Check it for continuity and replace it if it's open.
- The thermal fuse Part number: 3390719
xfixer 10-08-2012 08:51 PM
Thank You Gene.....
Quote:
Originally Posted by Gene (Post 774230)
Hi Ray,
Your response was clear, concise, accurate and correct.... thermal fuse was open Ray
Gene 10-09-2012 01:11 PM
You are welcome Ray. Thank you for the feed back and your good words.
