| » Affinity Dryer Push Start, makes 60 Cycle Hum, does nthing else. |
Model Number: LEQ60000ES0 Brand: Frigidaire Age: 1 - 5 years
Lights work, push start, just makes a 60 cycle hum and nothing else happens.
Please check you model number as I cannot find any info on the unit.
Are you sure that it does not have one too many zeros. Is the hum from the motor, see below if it is. Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it. If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp. If nothing is jammed in there you will have to open it up and find the cause. If it rotates OK. This may take 2 people Open the door Manually hold the door switch closed Push the start button and manually rotate the drum in the correct direction. Watch your knuckles in case it starts up. If it does start up, odds are high that you need a new motor. Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
Quote:
Here are your parts, includes a wiring diagram.
Replacement parts for Frigidaire LEQ6000ES0 Frigidaire/dryer | AppliancePartsPros.com I was hoping to see a start capacitor in the schematic. As you can see there is no capacitor the motor. Is the start/run centrifugal switch internal or is it replacable? No you have to replace the motor (item 28 in Section 4) Open the unit up just to be sure that lint etc. is not preventing the centrifugal switches from activating. Also before ordering a motor check the belt, drum seals, internal seals, rear support bearing etc. so you have an idea what a basic overhaul will cost. The unit may not be worth fixing if it needs lots of parts and.or is in poor shape.
__________________
| Display Modes | |
| Dryer won't start and makes humming sound when any cycle is selected | cwilker1973 | Dryer Repair | 3 | 12-05-2011 12:23 PM |
| dryer just buzzes when push start button like cycle is done | ltmartin76 | Dryer Repair | 1 | 02-18-2011 06:46 AM |
| Dryer will not start - will power up, but when push the start button, will not start | perduena | Dryer Repair | 0 | 07-12-2010 07:14 PM |
| Electric dryer makes the end of cycle sound when i push the start button | candy2785 | Dryer Repair | 1 | 01-08-2010 02:11 AM |
| Washer Makes Strange Noise When I Push Start Button | Kelli Huntsman | Washer Repair | 0 | 01-05-2009 09:28 AM |
