Discuss
tony
 in
Dryer Repair
I would like a belt- pulley kit.also sensor that detects if clothes is not working.The dryer works fine
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » tony
  #1 (permalink)
Old 01-30-2008, 01:56 PM
lanza530@comcast.net lanza530@comcast.net is offline
Junior Member
lanza530@comcast.net is on a distinguished road
Default tony
Model Number: le9800xsno   Brand: Whirlpool   Age: More than 10 years
I would like a belt- pulley kit.also sensor that detects if clothes is not working.The dryer works fine on time dry.Do I need a sensor,if so please give me pats #s and prices for both items.
Thank you
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-31-2008, 01:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem on auto dry cycle caused by an air flow restriction in the exhaust line.
Disconnect the vent hose on the back of the dryer and run couple loads without the vent hose. If you'll see a difference then the venting needs cleaning. Also check the blower and the air ducts inside the dryer.
- The part number for the belt is AP2946843
Here are the break down diagrams for the Whirlpool dryer Model LE9800XSW0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
