| » whirlpool duet electric dryer does not heat |
Model Number: gew9250pl1 Brand: Whirlpool Age: 5 - 10 years
Whirlpool gew9250pl1 electric dryer runs, vent is clean, good air flow out of exteriorvent louver. Sensing LED stays on allthe time and the electric dryer does not heat. Any ideas? Ads By Google Related Models |
Hi.
First check if there is 240VAC at the dryers connector block. If not - reset the breakers. Remove the toe panel 2 screws in each corner and check for 240VAC at the heater contacts. If 240VAC is there replace the heater element Part number: 3387747 If not then check hi-limit, thermal cut-off, heater relay in the control board. Use the tech sheet (behind the toe panel) to run the diagnostic test. Here are the breakdown diagrams and Replacement parts for Whirlpool GEW9250PL1 ELECTRIC DRYER | AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 09-28-2012 at 01:12 PM. |
| Display Modes | |
| Whirlpool Duet Electric Dryer | Sandi Van Camp | Dryer Repair | 2 | 11-14-2011 10:14 AM |
| Whirlpool Duet Electric Dryer does not turn on | vong | Dryer Repair | 3 | 11-04-2011 04:48 AM |
| whirlpool duet electric dryer works but no heat | sbfire370 | Dryer Repair | 2 | 04-13-2011 11:59 AM |
| Whirlpool Duet Electric Dryer | Corey Pantuso | Dryer Repair | 0 | 12-16-2010 08:40 AM |
| Electric whirlpool duet dryer won't heat | LEhart | Dryer Repair | 1 | 11-18-2008 07:45 AM |
