| » No heat from maytag mde9700ayw |
Model Number: mde9700ayw Brand: Maytag Age: 1 - 5 years
Replaced thermal fuse twice keeps blowing fuse after 1 dry cycle. Inspected dryer vent and ran with hose disconected still blows fuse. Was wondering if thermostat for heating element could be bad causing to get to hot.
Replacement parts for Maytag MDE9700AYW DRYER- ELE | AppliancePartsPros.com See the attachment for the tech sheet. Was wondering if thermostat for heating element could be bad causing to get to hot. The unit does not use a thermostat. Temperature is regulated by the board reading the thermistor resistance, see the tech sheet. Could be a number of things. First I would try the diagnostics to see if something comes up. Next I would check for a grounded heating coil. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it. Next would be the thermistor resistance.
__________________
| Display Modes | |
| Maytag MDE9700AYW Will not run | aschiemann | Dryer Repair | 3 | 12-20-2011 12:16 PM |
| Maytag No heat | jprince | Dryer Repair | 0 | 11-07-2010 01:38 PM |
| maytag mde9700ayw error code e5 | scottclk | Dryer Repair | 0 | 08-23-2009 04:08 PM |
| Maytag NO HEAT | GEARHEAD | Dryer Repair | 3 | 05-27-2009 06:14 AM |
| Maytag MW won't Heat. | Jimmyd | Microwave Repair | 1 | 12-01-2008 06:44 PM |
