| » dryer |
Please provide the model number of the dryer.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hi.
You need to check the flame sensor, hi-limit, cut-off thermal fuse. Most likely it's the flame sensor. You can try to jump it and if the ignitor start glowing - replace the flame sensor. Part number: 338906 Here are the breakdown diagrams and Replacement parts for Maytag AGD4475TQ0 29" GAS DRYER | AppliancePartsPros.com Post the results. Simon.
__________________
Quote:
Hi.
Most likely it's the bad timer. To check set the timer to time dry and jump BK-R and TM-WB. Flame comes on - replace the timer Part number: 8299764 Post the results. Simon.
__________________
Quote:
Hi.
You never mentioned checking the thermal fuse Part number: 3392519 and cycling thermostat Part number: 3387134 If all fuses and thermostats and new ignitor have continuity - replace the timer. Simon.
__________________
Quote:
The motor contacts 5M and 6M must be closed when it's running.
If the contacts are open you should replace the motor. Simon.
__________________
| Display Modes | |
