Dryer overheats and stops. Starts again after it cools down. Will run for 2 to 10 minutes and overheats again. I cleaned out vent, hose and disassembled and cleaned all exhaust vents. It does it on all heat cycles and fabric settings on the timer. Also replaced Thermostat and no change. Any ideas what to check next.
