| » not drying |
Model Number: DVL223EB1WW Brand: GE Age: 5 - 10 years
Everything seems to be working properly but the clothes are not drying - it takes several cycles to get a load done. What should we look at first, second, etc. to fix.
Replacement parts for GE DVL223EB1WW | AppliancePartsPros.com Often this is just a dirty/malfuntioning vent system. Check and clean it. If it is a royal pain to do you may want to run the♦ following test first. Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully. If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load. Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
__________________
| Display Modes | |
| Not drying | treak60 | Dryer Repair | 0 | 06-15-2009 04:01 PM |
| Drying continue drying in auto cyclr | Napolean | Dryer Repair | 1 | 02-26-2009 12:11 PM |
| Upper Drying Cabinet Not Drying | Slate0 | Dryer Repair | 0 | 02-17-2009 07:02 AM |
| Dryer will not heat during timed drying; will heat for short time while auto drying | mg13nj | Dryer Repair | 11 | 11-11-2008 03:50 PM |
| Not drying | spitgun | Dryer Repair | 1 | 10-15-2008 09:21 PM |
