Discuss
dryer not heating up
 in
Dryer Repair
i have problem with my dryer heating up also my timer will not turn blowing cold air and tub moves
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dryer not heating up
  #1 (permalink)
Old 09-23-2009, 10:39 AM
Junior Member
sweettea is on a distinguished road
Default dryer not heating up
Model Number: ler5636pqo   Brand: Whirlpool   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
Whirlpool LER6634DW1 ELECTRIC DRYER
Whirlpool LER6634DZ0 ELECTRIC DRYER
Whirlpool LER6634DZ1 ELECTRIC DRYER
Whirlpool LER6636PW0 29" ELECTRIC DRYER
Whirlpool LER6636PW1 29" ELECTRIC DRYER
Whirlpool LER6638DQ0 ELECTRIC DRYER
Whirlpool LER6638DQ1 ELECTRIC DRYER
Whirlpool LER6638DW0 ELECTRIC DRYER
Whirlpool LER6638DW1 ELECTRIC DRYER
Whirlpool LER6638DZ0 ELECTRIC DRYER
Whirlpool LER6638DZ1 ELECTRIC DRYER
Whirlpool LER6644DQ0 ELECTRIC DRYER
Whirlpool LER6644DQ1 ELECTRIC DRYER
Whirlpool LER6644DZ0 ELECTRIC DRYER
Whirlpool LER6644DZ1 ELECTRIC DRYER
Whirlpool LER6646BN0 ELECTRIC DRYER
Whirlpool LER6646BN1 ELECTRIC DRYER
Whirlpool LER6646BN2 ELECTRIC DRYER
Whirlpool LER6646BW0 ELECTRIC DRYER
Whirlpool LER6646BW1 ELECTRIC DRYER
Whirlpool LER6646BW2 ELECTRIC DRYER
Whirlpool LER6646DN1 ELECTRIC DRYER
Whirlpool LER6646DW1 ELECTRIC DRYER
Whirlpool LER6646PW0 29" ELECTRIC DRYER
Whirlpool LER6646PW1 29" ELECTRIC DRYER
Whirlpool LER6848AN1 ELECTRIC DRYER
Whirlpool LER6848AN2 ELECTRIC DRYER
Whirlpool LER6848AQ2 ELECTRIC DRYER
Whirlpool LER6848AW0 Residential Dryer
Whirlpool LER6848AW1 ELECTRIC DRYER
Whirlpool LER6848AW2 ELECTRIC DRYER
Whirlpool LER6848AZ2 ELECTRIC DRYER
Whirlpool LER7620KQ0 RESIDENTIAL DRYER
Whirlpool LER7620KQ1 ELECTRIC DRYER
Whirlpool LER7620KT0 DRYER
Whirlpool LER7620KT1 ELECTRIC DRYER
Whirlpool LER7620LG0 RESIDENTIAL DRYER
Whirlpool LER7620LG1 29"ELECTRIC DRYER
Whirlpool LER7620LQ0 RESIDENTIAL DRYER
Whirlpool LER7620LW0 RESIDENTIAL DRYER
Whirlpool LER7620LW1 29"ELECTRIC DRYER
Whirlpool LER7646AN0 ELECTRIC DRYER
Whirlpool LER7646AN1 ELECTRIC DRYER
Whirlpool LER7646AN2 ELECTRIC DRYER
Whirlpool LER7646AQ0 ELECTRIC DRYER
Whirlpool LER7646AQ1 ELECTRIC DRYER
Whirlpool LER7646AQ2 ELECTRIC DRYER
Whirlpool LER7646AW0 Residential Dryer
Whirlpool LER7646AW1 ELECTRIC DRYER
Whirlpool LER7646AW2 ELECTRIC DRYER
Whirlpool LER7646AZ0 ELECTRIC DRYER
Whirlpool LER7646AZ1 ELECTRIC DRYER
Whirlpool LER7646AZ2 ELECTRIC DRYER
Whirlpool LER7646DQ0 ELECTRIC DRYER
Whirlpool LER7646DQ1 ELECTRIC DRYER
Whirlpool LER7646DW0 ELECTRIC DRYER
Whirlpool LER7646DW1 ELECTRIC DRYER
Whirlpool LER7646DZ0 ELECTRIC DRYER
Whirlpool LER7646DZ1 ELECTRIC DRYER
Whirlpool LER7646EQ0 DRYER
  #2 (permalink)
Old 09-24-2009, 03:18 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for WHIRLPOOL LER5636PQ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/w...%208528187.pdf
Try the unit in timed dry mode.
If the timer still does not advance you may have a power problem.
Note that both the heater and timer motor run off of the 240 volts.
Turn the breaker off/on slowly a couple times. Better yet check it with a meter.
If it does turn then it could be the heater is blown.
In auto modes the voltage for the timer goes through the heating coil.
Easiest way to check it is with a meter.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer not heating rcabalo Dryer Repair 2 11-26-2009 09:52 AM
dryer not heating iyacko Dryer Repair 2 08-26-2009 12:50 PM
dryer not heating ecubulldog Dryer Repair 1 07-05-2009 07:40 AM
Dryer not Heating stompy27 Dryer Repair 0 11-05-2008 06:06 AM
Gas dryer not heating Penthor Dryer Repair 3 02-17-2008 08:56 AM
