Discuss
Dryer does not start
 in
Dryer Repair
My Kenmore dryer will not start. When I push the start button it will buzz and then shut off. If
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer does not start
  #1 (permalink)
Old 09-20-2012, 01:20 PM
Junior Member
Kalalau is on a distinguished road
Default Dryer does not start
Brand: Kenmore   Age: 5 - 10 years
My Kenmore dryer will not start. When I push the start button it will buzz and then shut off. If I push the start button again, nothing happens. If I wait about 30 minutes the start button will buzz again but then shut off. It does sound like it is trying to turn the drum but there is too much resistance and it stops. When I manually tried to turn the drum there is some resistance. I am not sure if it is supposed to turn very freely because it does not.
I did open the dryer and it looks like the belt is intact. I did replace the belt about two years ago and it has worked fine until recently. I looked for any obstructions but could not find any. There was a ton of lint in the dryer which I vacuumed out.
Any ideas?
Ads By Google
  #2 (permalink)
Old 09-21-2012, 01:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
__________________
  #3 (permalink)
Old 09-21-2012, 10:57 AM
Junior Member
Default
If it rotates OK.
Open the door
Thank you for your reply. I did try to manually rotate the drum while holding the start button but it did not start.
Is it possible to clean out the motor if it is jammed with lint as I think it is possible that this is the problem as there was so much lint around the drum.
But I think that the drum is offering too much resistance to turn manually but I don't know why.
  #4 (permalink)
Old 09-22-2012, 03:14 AM
Senior Expert
APP Volunteer
Default
Yes the unit can be opened up and cleaned inside.
If there is a great deal of lint you may require parts/seals.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HOT POINT DRYER has power but start button doesn't start the dryer. HOT POINT Dryer Repair 2 08-01-2011 06:47 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dryer Repair 0 03-28-2011 03:21 PM
Dryer wont start, sensing light just flashes when i hold down the start button! crsteilen Dishwasher Repair 0 03-28-2011 12:13 PM
Dryer will not start - will power up, but when push the start button, will not start perduena Dryer Repair 0 07-12-2010 07:14 PM
dryer start button flashing and not clicking to start dryer lawfamily Dryer Repair 0 06-21-2010 07:43 PM
