Discuss
whirlpool dryer only works on cooldown
 in
Dryer Repair
My dryer heats fine and will dry clothes on cool down settings. I have been having this issue for about
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » whirlpool dryer only works on cooldown
  #1 (permalink)
Old 09-19-2012, 10:01 AM
Junior Member
rpresnell is on a distinguished road
Default whirlpool dryer only works on cooldown
Brand: Whirlpool   Age: 5 - 10 years
My dryer heats fine and will dry clothes on cool down settings. I have been having this issue for about a week. When i turn the knob to a cool down settting it pretty much starts right up. when I put it on a normal setting it does nothing then if i turn it around and around and back and forth sometimes I can get it to work on the reg setting. I usually get to frustrated cause it wont work so i put it back on the cool down and then just restart it a couple of times. I have noticed a couple times that if it completly finishes and buzzes like it is done then i can sometimes not very often turn it and trick it to a timmed setting like at around 40 min. However if i open the door or stop it then it will rarley turn back on unless i move it to cool down again. wondering if this is a issue with the knob "timmer"? again it does heat up and clothes do get dry but it is taking forever on cooldown.Any suggestions would be helpful.
  #2 (permalink)
Old 09-19-2012, 10:59 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Based on the info you provided the problem is with the timer.
Please provide the complete model number of the dryer.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-26-2012, 08:50 PM
Junior Member
Default
the model number for this dryer is LER7646JQ0 serial number MK2129825 looking to get this job done this friday!. Really starting to think that the problem is the timer. Is this a tricky job?
  #4 (permalink)
Old 09-27-2012, 11:02 AM
Expert
Default
Hi.
It's most likely the timer Part number: 8299766
Use the video clip for the instructions.
Here are the breakdown diagrams and http://www.appliancepartspros.com/pa...odel_id=242005
Post the results.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool duet electric dryer works but no heat sbfire370 Dryer Repair 2 04-13-2011 12:59 PM
Hotpoint electric Dryer only starts on cooldown cycle JoeNIndy Dryer Repair 5 03-23-2010 08:22 AM
whirlpool dryer works,but no hear john437 Dryer Repair 2 05-24-2009 01:32 PM
Dryer stops in middle of cooldown cycle alan93 Dryer Repair 2 01-19-2009 07:01 AM
Dryer shuts down just before cooldown mrmeld Dryer Repair 3 01-21-2008 03:56 AM
