Discuss
Disassembly of cover
 in
Dryer Repair
You are welcome. We're glad to hear we could help you out. If there is anything else we can help
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Disassembly of cover
  #11 (permalink)
Old 09-25-2012, 01:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. We're glad to hear we could help you out. If there is anything else we can help you with, drop us a line.
Ads By Google
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 09-26-2012, 04:04 AM
Junior Member
leighmcg1 is on a distinguished road
Default
Got the front cover off, checked everything out. The heating elements work, the blower wheel spins, the drum turns, no funny noises. Assuming the exhaust vent is clear (I'll check it tonight after work) what would cause it to take almost 2 hours to dry a load of laundry?
  #13 (permalink)
Old 09-27-2012, 12:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely there is a restricted air flow. Disconnect the vent hose on the back of the dryer and run a load as you usually do.
__________________
  #14 (permalink)
Old 10-02-2012, 05:43 PM
Junior Member
askmelater is on a distinguished road
Default
Gene, I replace the motor and I still have the same symptoms.
It won't spin on it's own, but will spin if you hold down the door switch and give it a hand. Could it be the belt?
Is there anything electronic that would determine the power going to the motor? I don't hear anything unusual. I might hear a click when it starts the blower. No heat until I manually help it along.
  #15 (permalink)
Old 10-02-2012, 05:53 PM
Junior Member
Default
I can order a new belt for $25 with shipping. Should I remove the top and see if the belt is moving at all first.
Could it be a spring in the two white pulley's or tension?
What do you think?
  #16 (permalink)
Old 10-02-2012, 07:15 PM
Junior Member
Default
Gene, it could be the capacity couldn't it.
If it might be.. I'm thinking about replacing the Belt, Spring on the Pulleys and the Capacity.... #632 on diagram.
Blower & drive assembly replacement parts for General Electric DPVH880EJ0MG ELECTRIC DRYER | AppliancePartsPros.com
What do you think?
Quote:
  #17 (permalink)
Old 10-03-2012, 12:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Bryan,
How freely the drum moves when you turn it manually?
If you can feel any restrictions then check how the belt was installed and the conditions of the idler pulley.
If it moves freely, measure the current drawn by the drive motor while it's trying to start. It suppose to be no more than 3 amps. If it's more than that with the new motor, very likely the power board causing the problem.
Post the results.
__________________
  #18 (permalink)
Old 10-03-2012, 01:02 PM
Junior Member
Default
The drum doesn't spin freely. I think the belt is alright.
I just ordered a new Belt, Spring and Capacitor. It's $58 delivered. Not bad.
I'm going to take it apart one more time and replace those items. I'm thinking it's the capacitor or spring. I don't recall seeing a spring on the two pulley's so I'll take a closer look.
If that doesn't work.. I'll call someone. It should be easy to take apart and put together this time. I'll let you know.
It's a $1000 dryer so new Motor, Belt and parts is worth it. I have old motor as backup. It's also champagne colored so matching will be difficult :-))
  #19 (permalink)
Old 10-31-2012, 01:11 PM
Junior Member
Default
GENE!
I still haven't fixed my Dryer. Good thing I have another one in the guest house.
I replaced the motor, capacitor and belt. Belt just because.
It won't run unless I manually help it at first.
I took out the drum and ran it without anything. The motor doesn't turn unless I use a stick and just gently push the blade to help it. Then it turns.
You mentioned the Board. Could anything else cause this? The heater comes on and everything works once it gets a little help.
  #20 (permalink)
Old 10-31-2012, 05:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would like you to measure the current drawn by the motor and post the result.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
agitator disassembly abe1951 Washer Repair 1 03-07-2012 02:27 PM
disassembly Christopherk Washer Repair 0 11-16-2010 11:43 AM
remove timer cover and damper cover fle Refrigerator & Freezer Repair 1 02-09-2010 05:23 PM
disassembly andymu Washer Repair 3 10-03-2009 10:07 AM
Disassembly wstronks Dryer Repair 0 04-25-2009 06:25 AM
