Discuss
Kenmore 400 Dryer Heat no good
 in
Dryer Repair
I have a Kenmore that stopped putting out heat recently. Prior to this my wife would find the dryer on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore 400 Dryer Heat no good
  #1 (permalink)
Old 09-11-2012, 09:14 PM
Junior Member
thebestman is on a distinguished road
Default Kenmore 400 Dryer Heat no good
Model Number: 110.69422801   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore that stopped putting out heat recently. Prior to this my wife would find the dryer on at night or random times of the day. I suspected the heater element and changed it out along with the thermal and high limit thermostats. No go at first, then it worked all of a sudden.... then after one use it died again. I went and bought a multimeter and started testing. my new parts tested out fine, re-wired things again, switched the breakers etc.... it worked again for 1 time only.... So having already tested the new parts and seeing they where still good, I now replaced the small white Thermal Fuse and Cycling thermostat... all parts test good continuity... tested the Start switch as well..... Everything so far tests fine and the dryer turns on and blows air but NO HEAT.....
WHAT THE HECK am I missing???
NEW Parts on Dryer: VIEW PHOTO
Thermal Fuse
Cycling Thermostat
Thermal cut-off and High Limit Thermostat Kit
Heating Element
Basically every single part on the back of the DRYER is new and replaced.
I checked the power coming from the breaker and get: 240, 120, 120 on the three cables so that is fine also.... I even checked the start switch... ( I hold it down to check continuity correct?)
What am I missing? Is it the Timer unit? Or is my dryer just DEAD? I have all new parts and no heat unless its some random time when it happens to work.......
The only other thing is, I might not have put the wires back exactly the way they where on the original parts.... but that doesnt matter correct? Or else, why would it randomly work? Please help me, I am new at this and have learned everything so far over the last few days...
Ads By Google
Related Models
Kenmore 110.70012000  COMMERCIAL GAS DRYER
Kenmore 110.70012001  COMMERCIAL GAS DRYER
Kenmore 110.7017000  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.7017010  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.7017011  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.7017012  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.7017013  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.70172000  COMMERCIAL GAS DRYER
Kenmore 110.70172001  COMMERCIAL GAS DRYER
Kenmore 110.7018000  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.7018010  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.7018011  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.7018012  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.70182000  COMMERCIAL GAS DRYER
Kenmore 110.70232000  COMMERCIAL GAS DRYER
Kenmore 110.70232001  COMMERCIAL GAS DRYER
Kenmore 110.7117030  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.7117031  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.7117032  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.7118030  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.7118031  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.72182100  COMMERCIAL GAS DRYER
Kenmore 110.72182101  GAS DRYER
Kenmore 110.72182102  GAS DRYER
Kenmore 110.723120  DISHWASHER
Kenmore 110.76051690  COMMERCIAL GAS DRYER
Kenmore 110.76051691  COMMERCIAL GAS DRYER
Kenmore 110.76058690  COMMERCIAL GAS DRYER
Kenmore 110.76058691  COMMERCIAL GAS DRYER
Kenmore 110.76071690  COMMERICAL GAS DRYER
Kenmore 110.76071691  COMMERCIAL GAS DRYER
Kenmore 110.76402110  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.76402410  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.76402610  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.76406110  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.76406410  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.76406610  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.773811  UNDERCOUNTER DISHWASHER
Kenmore 110.773812  UNDERCOUNTER DISHWASHER
Kenmore 110.773813  UNDERCOUNTER DISHWASHER
Kenmore 110.773881  UNDERCOUNTER DISHWASHER
Kenmore 110.773882  UNDERCOUNTER DISHWASHER
Kenmore 110.773883  UNDERCOUNTER DISHWASHER
Kenmore 110.79012990  COMMERICAL GAS DRYER
Kenmore 110.79032990  COMMERICAL GAS DRYER
Kenmore 110.82182200  COMPACT ELECTRIC DRYER
Kenmore 110.82722200  COMPACT ELECTRIC DRYER
Kenmore 110.82822100  ELECTRIC DRYER
Kenmore 110.82822101  ELECTRIC DRYER
Kenmore 110.82822102  ELECTRIC DRYER
Kenmore 110.82824100  ELECTRIC DRYER
Kenmore 110.82824101  ELECTRIC DRYER
Kenmore 110.82824102  ELECTRIC DRYER
Kenmore 110.82826100  ELECTRIC DRYER
Kenmore 110.82826101  ELECTRIC DRYER
Kenmore 110.82826102  ELECTRIC DRYER
Kenmore 110.82832100  DRYER
Kenmore 110.82834100  DRYER
Kenmore 110.82836100  DRYER
Kenmore 110.83679630  ELECTRIC DRYER
Kenmore 110.84832200  ELECTRIC DRYER
Kenmore 110.84832201  ELECTRIC DRYER
Kenmore 110.84834200  ELECTRIC DRYER
Kenmore 110.84834201  ELECTRIC DRYER
Kenmore 110.84836200  ELECTRIC DRYER
Kenmore 110.84836201  ELECTRIC DRYER
Kenmore 110.86015100  ELECTRIC DRYER
Kenmore 110.86015110  ELECTRIC DRYER
Kenmore 110.86015120  ELECTRIC DRYER
Kenmore 110.86030100  ELECTRIC DRYER
Kenmore 110.86030110  ELECTRIC DRYER
Kenmore 110.86030120  ELECTRIC DRYER
Kenmore 110.86070100  ELECTRIC DRYER
Kenmore 110.86070110  ELECTRIC DRYER
Kenmore 110.86405160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86405860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407140  ELECTRIC DRYER
Kenmore 110.86407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407840  ELECTRIC DRYER
Kenmore 110.86407860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
  #2 (permalink)
Old 09-12-2012, 03:14 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Remove one wire from the heater, turn the dryer on and trace the wire without the 120VAC.Normally one leg goes from the timer through the thermostats and another one - through the motor switch.
You can jump timer contacts C-A to check if it's the timer.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-15-2012, 07:54 PM
Junior Member
cazrcon is on a distinguished road
Default
something simple to check to is is your exhaust pipe clean. I have a rental and had no heat at dryer. the dryer was 5-6 years old but exhaust not cleaned for a while. pulled 2 big handfulls of dirt and lint from exhaust and now have heat again. when first turned on heat would come on but shut off. make sure pipes are not clogged and filter is clean too.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no heat all sensors ohm good?????????????? ratcliff22 Dryer Repair 11 11-03-2010 05:18 AM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
No heat in oven, ignitor good joebuehler Oven Repair (including Ranges and Cooktops) 3 12-12-2009 04:37 PM
no heat heating element good mikesracecar Dryer Repair 1 10-29-2009 10:17 AM
Heat but not drying, seems like heat is not blowing good Papa1 Dryer Repair 2 10-07-2007 10:11 AM
