Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Maytag Cable Change (http://forum.appliancepartspros.com/dryer-repair/499865-maytag-cable-change.html)
bish07 09-11-2012 06:24 PM
Maytag Cable Change
Help Please...
I am helping a friend change out a 3 terminal cable on her dryer to a 4 terminal cable. The ground runs out of the center post and connects into a solderless terminal and back out the same side into the green screw but there is also a white cable that runs out the opposite side of the solderless terminal that runs up to the front on the unit(I think to the door latch switch). I am unsure what to do with the ground coming from the front of the unit. Any help would be appreciated.
denman 09-12-2012 02:09 AM
Here is the operators manual. It has electrical hook-up info
https://www.maytag.com/digitalassets...W10150608A.pdf
