Discuss
Whirlpool Electric Dryer, replaced timer, will not advance
 in
Dryer Repair
our timer wasn't advancing on our dryer (timed dry only, our dryer has no sensor), so i replaced it... it
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Electric Dryer, replaced timer, will not advance
  #1 (permalink)
Old 09-10-2012, 03:08 PM
Junior Member
muttonchop is on a distinguished road
Default Whirlpool Electric Dryer, replaced timer, will not advance
Model Number: LER5636EQ3   Brand: Whirlpool   Age: 5 - 10 years
our timer wasn't advancing on our dryer (timed dry only, our dryer has no sensor), so i replaced it... it still wont advance, it just stays in the same place... any idea what's wrong? thanks for your help...
Ads By Google
Related Models
Whirlpool LER5636EQ3 ELECTRIC DRYER
Whirlpool LER5636EZ0 ELECTRIC DRYER
Whirlpool LER5636EZ01 ELECTRIC DRYER
Whirlpool LER5636EZ1 DRYER
Whirlpool LER5636EZ2 ELECTRIC DRYER
Whirlpool LER5636EZ3 ELECTRIC DRYER
Whirlpool LER5636JQ0 ELECTRIC DRYER
Whirlpool LER5636JT0 ELECTRIC DRYER
Whirlpool LER5636KQ0 RESIDENTIAL DRYER
Whirlpool LER5636KQ1 RESIDENTIAL DRYER
Whirlpool LER5636KT0 RESIDENTIAL DRYER
Whirlpool LER5636KT1 RESIDENTIAL DRYER
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"ELECTRIC DRYER
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"ELECTRIC DRYER
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"ELECTRIC DRYER
Whirlpool LER5636PQ1 29"ELECTRIC DRYER
Whirlpool LER5636PT0 29"ELECTRIC DRYER
Whirlpool LER5636PT1 29"ELECTRIC DRYER
Whirlpool LER5638AN1 ELECTRIC DRYER
Whirlpool LER5638AN2 ELECTRIC DRYER
Whirlpool LER5638AN3 ELECTRIC DRYER
Whirlpool LER5638AW0 Residential Dryer
Whirlpool LER5638AW1 ELECTRIC DRYER
Whirlpool LER5638AW2 ELECTRIC DRYER
Whirlpool LER5638AW3 ELECTRIC DRYER
Whirlpool LER5644AN1
Whirlpool LER5644AN2 ELECTRIC DRYER
Whirlpool LER5644AW0 Residential Dryer
Whirlpool LER5644AW1
Whirlpool LER5644AW2 ELECTRIC DRYER
Whirlpool LER5644EQ0 ELECTRIC DRYER
Whirlpool LER5644EQ1 ELECTRIC DRYER
Whirlpool LER5644EQ2 ELECTRIC DRYER
Whirlpool LER5644EZ0 ELECTRIC DRYER
Whirlpool LER5644EZ1 ELECTRIC DRYER
Whirlpool LER5644EZ2 ELECTRIC DRYER
Whirlpool LER5644JQ0 DRYER
Whirlpool LER5644JQ1 DRYER
Whirlpool LER5644JQ2 RESIDENTIAL DRYER
Whirlpool LER5644JQ3 29"ELECTRIC DRYER
Whirlpool LER5644JT0 DRYER
Whirlpool LER5644JT1 DRYER
Whirlpool LER5644JT2 RESIDENTIAL DRYER
Whirlpool LER5644JT3 29"ELECTRIC DRYER
Whirlpool LER5644PQ0 29"ELECTRIC DRYER
Whirlpool LER5644PQ1 29"ELECTRIC DRYER
Whirlpool LER5700KQ0 RESIDENTIAL DRYER
Whirlpool LER5700KQ1 RESIDENTIAL DRYER
Whirlpool LER5700KT0 RESIDENTIAL DRYER
Whirlpool LER5700KT1 RESIDENTIAL DRYER
Whirlpool LER5848EQ0 ELECTRIC DRYER
Whirlpool LER5848EQ1 ELECTRIC DRYER
Whirlpool LER5848EQ2 ELECTRIC DRYER
Whirlpool LER5848EQ3 DRYERS
Whirlpool LER5848EQ4 DRYERS
Whirlpool LER5848EQ5 ELECTRIC DRYER
Whirlpool LER6611LQ0 RESIDENTIAL DRYER
Whirlpool LER6611LQ1 29"ELECTRIC DRYER
Whirlpool LER6611PQ0 29" ELECTRIC DRYER
Whirlpool LER6620PQ0 29"ELECTRIC DRYER
Whirlpool LER6620PQ1 29"ELECTRIC DRYER
Whirlpool LER6620PT0 29"ELECTRIC DRYER
Whirlpool LER6620PT1 29"ELECTRIC DRYER
Whirlpool LER6621PQ0 29" ELECTRIC DRYER
Whirlpool LER6634BN0 ELECTRIC DRYER
Whirlpool LER6634BN1 ELECTRIC DRYER
Whirlpool LER6634BN2 ELECTRIC DRYER
Whirlpool LER6634BQ0 ELECTRIC DRYER
Whirlpool LER6634BQ1 ELECTRIC DRYER
Whirlpool LER6634BQ2 ELECTRIC DRYER
Whirlpool LER6634BW0 ELECTRIC DRYER
Whirlpool LER6634BW1 ELECTRIC DRYER
Whirlpool LER6634BW2 ELECTRIC DRYER
Whirlpool LER6634DQ0 ELECTRIC DRYER
Whirlpool LER6634DQ1 ELECTRIC DRYER
Whirlpool LER6634DW0 ELECTRIC DRYER
Whirlpool LER6634DW1 ELECTRIC DRYER
Whirlpool LER6634DZ0 ELECTRIC DRYER
Whirlpool LER6634DZ1 ELECTRIC DRYER
Whirlpool LER6636PW0 29" ELECTRIC DRYER
Whirlpool LER6636PW1 29" ELECTRIC DRYER
Whirlpool LER6638DQ0 ELECTRIC DRYER
Whirlpool LER6638DQ1 ELECTRIC DRYER
Whirlpool LER6638DW0 ELECTRIC DRYER
Whirlpool LER6638DW1 ELECTRIC DRYER
Whirlpool LER6638DZ0 ELECTRIC DRYER
Whirlpool LER6638DZ1 ELECTRIC DRYER
Whirlpool LER6644DQ0 ELECTRIC DRYER
Whirlpool LER6644DQ1 ELECTRIC DRYER
Whirlpool LER6644DZ0 ELECTRIC DRYER
Whirlpool LER6644DZ1 ELECTRIC DRYER
Whirlpool LER6646BN0 ELECTRIC DRYER
Whirlpool LER6646BN1 ELECTRIC DRYER
Whirlpool LER6646BN2 ELECTRIC DRYER
Whirlpool LER6646BW0 ELECTRIC DRYER
Whirlpool LER6646BW1 ELECTRIC DRYER
Whirlpool LER6646BW2 ELECTRIC DRYER
Whirlpool LER6646DN1 ELECTRIC DRYER
Whirlpool LER6646DW1 ELECTRIC DRYER
Whirlpool LER6646PW0 29" ELECTRIC DRYER
Whirlpool LER6646PW1 29" ELECTRIC DRYER
Whirlpool LER6848AN1 ELECTRIC DRYER
Whirlpool LER6848AN2 ELECTRIC DRYER
Whirlpool LER6848AQ2 ELECTRIC DRYER
Whirlpool LER6848AW0 Residential Dryer
Whirlpool LER6848AW1 ELECTRIC DRYER
Whirlpool LER6848AW2 ELECTRIC DRYER
Whirlpool LER6848AZ2 ELECTRIC DRYER
Whirlpool LER7620KQ0 RESIDENTIAL DRYER
Whirlpool LER7620KQ1 ELECTRIC DRYER
Whirlpool LER7620KT0 DRYER
Whirlpool LER7620KT1 ELECTRIC DRYER
Whirlpool LER7620LG0 RESIDENTIAL DRYER
Whirlpool LER7620LG1 29"ELECTRIC DRYER
Whirlpool LER7620LQ0 RESIDENTIAL DRYER
Whirlpool LER7620LW0 RESIDENTIAL DRYER
  #2 (permalink)
Old 09-11-2012, 02:45 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Replacement parts for Whirlpool LER5636EQ3 ELECTRIC DRYER | AppliancePartsPros.com
I could not find one for an EQ3 so it is for an EQ2 but is probably the same as yours.
Although your unit does not have a sensor it has auto modes which do sort of the same thing.
In a timed dry mode, the timer motor gets power directly through Timer Switch 0 contacts TM/WB.
In auto modes it gets power through the heating coil when the coil is shut off through Timer Switch contacts TM/OR. The 5000 ohm resistor is there to drop the 240 volts down to 120 volts so it does not blow the timer motor. There are a number of things that can cause it to not advance in auto re: a blown resistor, a grounded element etc.
So does it also not advance on a timed dry cycle?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric Dryer Not Producing Heat & Timer Does Not Advance in Auto Dry Settings hifroggyjenn Dryer Repair 1 01-12-2012 08:33 PM
Whirlpool gas dryer, no heat, timer doesn't advance jeffmaaske Dryer Repair 1 09-05-2011 05:04 PM
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes. XtremeRob Dryer Repair 17 08-02-2011 09:34 PM
Fridgaire electric dryer timer won't advance, heats occasionally aja1234 Dryer Repair 3 12-30-2008 01:30 PM
Whirlpool dryer timer won't advance Hzep Dryer Repair 1 01-28-2008 03:22 PM
