Discuss
Drum slamming around
 in
Dryer Repair
The drum on my dryer is banging around inside the dryer how does is secure to the dryer. does the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Drum slamming around
  #1 (permalink)
Old 09-09-2012, 05:31 PM
Junior Member
tuthemax is on a distinguished road
Default Drum slamming around
Model Number: 1108510081   Brand: Kenmore   Age: More than 10 years
The drum on my dryer is banging around inside the dryer how does is secure to the dryer. does the rear seal belts and roller hold it on place ?
I am a rookie on this and do not have a sniff
so if ya cam please help a noob
Related Models
Kenmore 11085155100 SEARS ELECTRIC WASHER
Kenmore 11085156100 SEARS ELECTRIC WASHER
Kenmore 11085165100 SEARS ELECTRIC WASHER
Kenmore 11085165400 SEARS ELECTRIC WASHER
Kenmore 11085165600 SEARS ELECTRIC WASHER
Kenmore 11085165800 SEARS ELECTRIC WASHER
Kenmore 11085166100 ELECTRIC WASHER
Kenmore 11085175100 SEARS ELECTRIC WASHER
Kenmore 11085175200 SEARS ELECTRIC WASHER
Kenmore 11085175400 SEARS ELECTRIC WASHER
Kenmore 11085175600 SEARS ELECTRIC WASHER
Kenmore 11085175800 SEARS ELECTRIC WASHER
Kenmore 11085185100 SEARS ELECTRIC WASHER
Kenmore 11085185400 SEARS ELECTRIC WASHER
Kenmore 11085185600 SEARS ELECTRIC WASHER
Kenmore 11085185800 SEARS ELECTRIC WASHER
Kenmore 11085257100 ELECTRIC WASHER
Kenmore 11085365100 WASHER
Kenmore 11085365200 WASHER
Kenmore 11085365400 WASHER
Kenmore 11085365600 WASHER
Kenmore 11085365800 WASHER
Kenmore 11085861400 RESIDENTIAL DRYER
Kenmore 11085861401 RESIDENTIAL DRYER
Kenmore 11085862400 RESIDENTIAL DRYER
Kenmore 11085862401 RESIDENTIAL DRYER
Kenmore 11085866400 RESIDENTIAL DRYER
Kenmore 11085866401 RESIDENTIAL DRYER
Kenmore 11085871400 RESIDENTIAL DRYER
Kenmore 11085872400 RESIDENTIAL DRYER
Kenmore 11085872401 RESIDENTIAL DRYER
Kenmore 11085874400 RESIDENTIAL DRYER
Kenmore 11085874401 RESIDENTIAL DRYER
Kenmore 11085876400 RESIDENTIAL DRYER
Kenmore 11085876401 RESIDENTIAL DRYER
Kenmore 11086015100 ELECTRIC DRYER
Kenmore 11086015110 ELECTRIC DRYER
Kenmore 11086015120 ELECTRIC DRYER
Kenmore 11086030100 ELECTRIC DRYER
Kenmore 11086030110 ELECTRIC DRYER
Kenmore 11086030120 ELECTRIC DRYER
Kenmore 11086070100 ELECTRIC DRYER
Kenmore 11086070110 ELECTRIC DRYER
Kenmore 11086070200 ELECTRIC DRYER
Kenmore 11086070210 ELECTRIC DRYER
Kenmore 11086070400 ELECTRIC DRYER
Kenmore 11086070410 ELECTRIC DRYER
Kenmore 11086070600 ELECTRIC DRYER
Kenmore 11086070610 ELECTRIC DRYER
Kenmore 11086070800 ELECTRIC DRYER
Kenmore 11086070810 ELECTRIC DRYER
Kenmore 11086071100 ELECTRIC DRYER
Kenmore 11086071110 ELECTRIC DRYER
Kenmore 11086071120 ELECTRIC DRYER
Kenmore 11086071130 ELECTRIC DRYER
Kenmore 11086071200 ELECTRIC DRYER
Kenmore 11086071210 ELECTRIC DRYER
Kenmore 11086071220 ELECTRIC DRYER
Kenmore 11086071230 ELECTRIC DRYER
Kenmore 11086071400 ELECTRIC DRYER
Kenmore 11086071410 ELECTRIC DRYER
Kenmore 11086071420 ELECTRIC DRYER
Kenmore 11086071430 ELECTRIC DRYER
Kenmore 11086071600 ELECTRIC DRYER
Kenmore 11086071610 ELECTRIC DRYER
Kenmore 11086071620 ELECTRIC DRYER
Kenmore 11086071630 ELECTRIC DRYER
Kenmore 11086071800 ELECTRIC DRYER
Kenmore 11086071810 ELECTRIC DRYER
Kenmore 11086071820 ELECTRIC DRYER
Kenmore 11086071830 ELECTRIC DRYER
Kenmore 11086082100 ELECTRIC DRYER
Kenmore 11086082110 ELECTRIC DRYER
Kenmore 11086082120 ELECTRIC DRYER
Kenmore 11086082200 ELECTRIC DRYER
Kenmore 11086082210 ELECTRIC DRYER
Kenmore 11086082220 ELECTRIC DRYER
Kenmore 11086082400 ELECTRIC DRYER
Kenmore 11086082410 ELECTRIC DRYER
Kenmore 11086082420 ELECTRIC DRYER
Kenmore 11086082600 ELECTRIC DRYER
Kenmore 11086082610 ELECTRIC DRYER
Kenmore 11086082620 ELECTRIC DRYER
Kenmore 11086082800 ELECTRIC DRYER
Kenmore 11086082810 ELECTRIC DRYER
Kenmore 11086082820 ELECTRIC DRYER
Kenmore 11086093100 ELECTRIC DRYER
Kenmore 11086093110 ELECTRIC DRYER
Kenmore 11086093200 ELECTRIC DRYER
Kenmore 11086093210 ELECTRIC DRYER
Kenmore 11086093400 ELECTRIC DRYER
Kenmore 11086093410 ELECTRIC DRYER
Kenmore 11086093600 ELECTRIC DRYER
Kenmore 11086093610 ELECTRIC DRYER
Kenmore 11086093800 ELECTRIC DRYER
Kenmore 11086093810 ELECTRIC DRYER
Kenmore 11086094100 ELECTRIC DRYER
Kenmore 11086094110 ELECTRIC DRYER
Kenmore 11086094120 ELECTRIC DRYER
Kenmore 11086094150 ELECTRIC DRYER
Kenmore 11086094200 ELECTRIC DRYER
Kenmore 11086094210 ELECTRIC DRYER
Kenmore 11086094220 ELECTRIC DRYER
Kenmore 11086094250 ELECTRIC DRYER
Kenmore 11086094400 ELECTRIC DRYER
Kenmore 11086094410 ELECTRIC DRYER
Kenmore 11086094420 ELECTRIC DRYER
Kenmore 11086094450 ELECTRIC DRYER
Kenmore 11086094600 ELECTRIC DRYER
Kenmore 11086094610 ELECTRIC DRYER
Kenmore 11086094620 ELECTRIC DRYER
Kenmore 11086094650 ELECTRIC DRYER
Kenmore 11086094800 ELECTRIC DRYER
Kenmore 11086094810 ELECTRIC DRYER
Kenmore 11086094820 ELECTRIC DRYER
Kenmore 11086094850 ELECTRIC DRYER
Kenmore 11086115100 ELECTRIC DRYER
Kenmore 11086130100 ELECTRIC DRYER
Kenmore 11086130110 ELECTIC DRYER
Kenmore 11086151100 ELECTRIC DRYER
  #2 (permalink)
Old 09-10-2012, 03:36 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot find any info on the given model number, please check it.
On most units gravity and the belt tension hold the drum down.
On the front they are often supported by a couple glides (plastic tabs).
On the back they have either a center bearing or two support rollers.
Odds are your unit has the rollers as a common fault is when the go they cause banging.
Also check that the fins in the drum are secure.
Since you are a noob following are a couple suggestions.
1. Since you have to open the unit up you may as well give it an overhaul so also check the belt, the glides, the idler wheel, the drum seals etc for wear. If you need a lot of parts it may not be worth fixing.
2. Give the interior including the blower wheel a good cleaning.
3. This is also a good time to check/clean your vent system.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum banging around /belt cutting into drum tunnel123 Washer Repair 1 05-18-2012 12:12 AM
Removing rear drum from outer drum on front load washer laker59 Washer Repair 1 02-08-2012 06:20 PM
Drum lip on dryer has become so sharp, it's cutting the drum glide and bracket dnh_repairgirl Dryer Repair 1 02-07-2012 05:26 AM
Clothes get hung between drum and front drum bearing jackpeg Dryer Repair 3 07-30-2011 06:07 AM
Compressor slamming floridajetsfan Refrigerator & Freezer Repair 2 04-02-2011 02:26 AM
